Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [EcoreTools] Multiple packages(Multiple packages in one ecore file)
[EcoreTools] Multiple packages [message #491732] |
Thu, 15 October 2009 11:34  |
I'm new to Ecore Tools. I need to create three different packages (actually complete metamodels) inside one ecore file. How can i do this with Ecore Tools?
thx in advance, Milan
Re: [EcoreTools] Multiple packages [message #491775 is a reply to message #491764] |
Thu, 15 October 2009 14:36   |
Dear Ed,
thank you on answer.
I need three packages in one file, because I have two languages and their metamodels (let say UML and BPMN), and I want to create the third language by using concepts from both languages (some hybrid of these two). Then, I need to generate GMF app from this (one) ecore file.
Is this good solution?
thx, Milan
Ed Merks wrote on Thu, 15 October 2009 13:25 | Milan,
I can't imagine why you'd need to create three packages in one Ecore
file. Personally I'd suggest that's a bad idea. One package per file
seems better. Certainly one root package per file is pretty much
necessary, so you could create one root package with three subpackages,
but again, I'd advise against that. Perhaps you should explain why you
consider this a need?
Milan Milanovich wrote:
Re: [EcoreTools] Multiple packages [message #491793 is a reply to message #491775] |
Thu, 15 October 2009 16:57   |
Milan,
Comments below.
> Dear Ed,
The need for three Ecore models, i.e., three EPackages, in no way
implies a need for three models in one file, regardless of how these
three models might be related to each other.
It sounds like you're focus on the wrong detail. You can have three
package is three different files and those packages can be related in
any arbitrary way...
> thx, Milan
>> Milan,
>> file seems better. Certainly one root package per file is pretty
>> much necessary, so you could create one root package with three
>> subpackages, but again, I'd advise against that. Perhaps you should
>> explain why you consider this a need?
>> > Hi,
>> > I'm new to Ecore Tools. I need to create three different packages >
>> (actually complete metamodels) inside one ecore file. How can i do >
>> > -- > thx in advance, Milan
Re: [EcoreTools] Multiple packages [message #491829 is a reply to message #491808] |
Fri, 16 October 2009 00:54   |
--------------030403090803000808060903
Milan,
Comments below.
> Dear Ed,
> sorry on my bad EMF knowledge.
No problem.
> That would be better solution for me. So, I can connect a model
> elements in one ecore file to model elements in another file?
Absolutely. This tutorial will help you understand a little better maybe:
Tutorial: Generating an Extended EMF Model
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/slibmod/slibmod.html>
> And also, to show all of these elements in one ecore diagram (as i
> want to define it in this way),
Yes, you drag and drop things from the outline onto the canvas. And
there's a Load Resource... action for loading in other Ecore models so
you can refer to them and display them.
> and later to generate GMF app from this?
Yes, the above tutorial will help prepare the EMF GenModel you'll need.
Note that if you have mutually dependent Ecore models, they'll need to
be contained by a single GenModel. For one way dependencies, you can
put them in separate GenModels as in the tutorial above.
> Thx, Milan
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Milan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hb87kc$brh$1@build.eclipse.org" type="cite">Dear
Ed,
<br>
<br>
sorry on my bad EMF knowledge. </blockquote>
No problem.<br>
<blockquote cite="mid:hb87kc$brh$1@build.eclipse.org" type="cite">That
would be better solution for me. So, I can connect a model elements in
one ecore file to model elements in another file? </blockquote>
maybe:<br>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/slibmod/slibmod.html">Tutorial:
Generating an Extended EMF Model</a></blockquote>
<blockquote cite="mid:hb87kc$brh$1@build.eclipse.org" type="cite">And
also, to show all of these elements in one ecore diagram (as i want to
define it in this way), </blockquote>
you can refer to them and display them.<br>
<blockquote cite="mid:hb87kc$brh$1@build.eclipse.org" type="cite">and
<br>
</blockquote>
need. Note that if you have mutually dependent Ecore models, they'll
need to be contained by a single GenModel. For one way dependencies,
you can put them in separate GenModels as in the tutorial above.<br>
<blockquote cite="mid:hb87kc$brh$1@build.eclipse.org" type="cite"><br>
<br>
Thx, Milan
<br>
</blockquote>
</body>
</html>
--------------030403090803000808060903--
Re: [EcoreTools] Multiple packages [message #491871 is a reply to message #491829] |
Fri, 16 October 2009 06:02   |
Dear Ed,
Yes, I read this tutorial already, but obviously I missed this part with split files.
Ed Merks wrote on Fri, 16 October 2009 00:54 |
Can you tell me ho to make single GenModel from multiple mutually dependant Ecore models?
Best regards, Milan
Re: [EcoreTools] Multiple packages [message #491899 is a reply to message #491871] |
Fri, 16 October 2009 09:20   |
--------------070809040303060101000909
Milan,
Comments below.
> Dear Ed,
>> > Dear Ed,
>> > sorry on my bad EMF knowledge. No problem.
>> > That would be better solution for me. So, I can connect a model >
>> maybe:
> with split files.
>> > want to define it in this way), Yes, you drag and drop things from
>> the outline onto the canvas. And there's a Load Resource... action
>> for loading in other Ecore models so you can refer to them and
>> display them.
You'll find you're unable *not *to do this. No matter which model you
load first, EMF will load all the ones it depends on and will force you
to create a GenModel for them all, or to locate an existing GenModel.
> Best regards, Milan
<html>
<head>
</head>
Milan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:hb9gcl$97u$1@build.eclipse.org" type="cite">Dear
Ed, <br>
<br>
<br>
<br>
<blockquote type="cite">Milan Milanovich wrote:
<br>
> Dear Ed,
<br>
<br>
<br>
maybe:
<br>
<br>
<br>
< <a class="moz-txt-link-freetext" href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips</a>
<br>
</blockquote>
<br>
<br>
with split files.
<br>
<br>
<br>
<blockquote type="cite">> And also, to show all of these elements
in one ecore diagram (as i > want to define it in this way), Yes,
you drag and drop things from the outline onto the canvas. And there's
a Load Resource... action for loading in other Ecore models so you can
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
You'll find you're unable <b>not </b>to do this. No matter which
model you load first, EMF will load all the ones it depends on and will
force you to create a GenModel for them all, or to locate an existing
GenModel.<br>
<blockquote cite="mid:hb9gcl$97u$1@build.eclipse.org" type="cite"><br>
<br>
Best regards, Milan
<br>
<br>
</blockquote>
</body>
</html>
--------------070809040303060101000909--
Re: [EcoreTools] Multiple packages [message #491934 is a reply to message #491764] |
Fri, 16 October 2009 11:28   |
Dear Ed,
thank you on your answers. I have one more question related to this subject, I need to define BPMN 2 metamodel related to its specification, but in spec. it includes some packages (activity, data, etc.). So, you propse not to put all of these in one file, e.g., bpmn2.ecore, but to have each package in its separate file?
thx, Milan
Re: [EcoreTools] Multiple packages [message #491958 is a reply to message #491934] |
Fri, 16 October 2009 13:25  |
Milan,
Personally I prefer separate packages. Sometimes people use nested
subpackages, but often that results in subtle issues because it's not so
well tested/used.
>> Milan,
>> > Hi,
> Dear Ed,
> thx, Milan
Re: [EcoreTools] Multiple packages [message #621483 is a reply to message #491764] |
Dear Ed,
thx, Milan
> Milan,
> > Hi,
Re: [EcoreTools] Multiple packages [message #621484 is a reply to message #491775] |
Milan,
Comments below.
> Dear Ed,
> thx, Milan
>> Milan,
>> > Hi,
Re: [EcoreTools] Multiple packages [message #621486 is a reply to message #491793] |
Thu, 15 October 2009 18:27  |
Dear Ed,
sorry on my bad EMF knowledge. That would be better solution for me. So, I can connect a model elements in one ecore file to model elements in another file? And also, to show all of these elements in one ecore diagram (as i want to define it in this way), and later to generate GMF app from this?
Thx, Milan
Re: [EcoreTools] Multiple packages [message #621487 is a reply to message #491808] |
Milan,
Comments below.
> Dear Ed,
No problem.
> Thx, Milan
<html>
<head>
</head>
Milan,<br>
<br>
Comments below.<br>
<br>
Ed,
<br>
<br>
No problem.<br>
maybe:<br>
<blockquote><a
<br>
</blockquote>
<br>
Thx, Milan
<br>
</blockquote>
</body>
</html>
Re: [EcoreTools] Multiple packages [message #621489 is a reply to message #491829] |
Fri, 16 October 2009 06:03  |
Dear Ed,
> > Dear Ed,
> No problem.
Best regards, Milan
Re: [EcoreTools] Multiple packages [message #621490 is a reply to message #621489] |
Milan,
Comments below.
> Dear Ed,
>> > Dear Ed,
>> maybe:
> with split files.
>> display them.
> Best regards, Milan
<html>
<head>
</head>
Milan,<br>
<br>
Comments below.<br>
<br>
Ed, <br>
<br>
<br>
<br>
<br>
> Dear Ed,
<br>
<br>
<br>
maybe:
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
with split files.
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
</blockquote>
GenModel.<br>
<br>
Best regards, Milan
<br>
<br>
</blockquote>
</body>
</html>
Re: [EcoreTools] Multiple packages [message #621493 is a reply to message #491764] |
> Milan,
> > Hi,
Dear Ed,
thx, Milan
Re: [EcoreTools] Multiple packages [message #621495 is a reply to message #621493] |
Milan,
well tested/used.
>> Milan,
>> > Hi,
> Dear Ed,
> thx, Milan
Current Time: Sun Jul 20 05:37:06 EDT 2025
Powered by FUDForum. Page generated in 0.05972 seconds
