Home » Eclipse Projects » Nebula » GalleryTreeViewer & IEMFListProperty
GalleryTreeViewer & IEMFListProperty [message #491411] Wed, 14 October 2009 09:16 Go to next message
is it possible to set IEMFListProperty as the input for GalleryViewer ?
is there sample for integrate EMF databinding with GalleryTreeViewer ?
Thanks.
Re: GalleryTreeViewer & IEMFListProperty [message #491540 is a reply to message #491411] Wed, 14 October 2009 18:43 Go to previous messageGo to next message
You mean IEMFObservableList?
Matthew
Re: GalleryTreeViewer & IEMFListProperty [message #491633 is a reply to message #491540] Thu, 15 October 2009 06:29 Go to previous messageGo to next message
ya, i mean IEMFObservableList.
is there any sample for that ?
with GalleryTreeViewer or GalleryViewer.
Re: GalleryTreeViewer & IEMFListProperty [message #491688 is a reply to message #491633] Thu, 15 October 2009 09:22 Go to previous messageGo to next message
GalleryTreeViewer treeViewer = ...
// input object that contains the root tree elements as children
EObject inputObject = ..
IEMFListProperty childrenProp =
EMFProperties.list(inputObjectChildrenStructuralFeature);
IEMFValueProperty[] columnProps = new IEMFValueProperty[] {
EMFProperties.value(property1),
EMFProperties.value(property2),
EMFProperties.value(property3),
ViewerSupport.bind(treeViewer, inputObject, childrenProp, columnProps);
Hope this helps,
Matthew
Re: GalleryTreeViewer & IEMFListProperty [message #491748 is a reply to message #491688] Thu, 15 October 2009 12:12 Go to previous messageGo to next message
Hi, thanks for reply Smile
i have a model like :
Mail
- MailFolder (as root of group)
- MailEntry (as children)
here is my code :
GalleryTreeViewer viewer = new GalleryTreeViewer(parent);
EObject inputObject = mail;
IEMFListProperty childrenProp = EMFProperties.list(ModelPackage.Literals.PIM_MAIL__CURRENT_F OLDER);
EMFProperties.value(ModelPackage.Literals.MAIL_FOLDER__ENTRY ),
EMFProperties.value(ModelPackage.Literals.MAIL_ENTRY__CONTEN T)
ViewerSupport.bind(viewer, inputObject,childrenProp, columnProps);
return viewer;
that's code not work, that's only show the group of gallery Sad
can you tell me what is IEMFListProperty mean ?
Re: GalleryTreeViewer & IEMFListProperty [message #491782 is a reply to message #491748] Thu, 15 October 2009 15:16 Go to previous messageGo to next message
> Hi, thanks for reply :)
> i have a model like : Mail
> here is my code :
> return viewer;
> that's code not work, that's only show the group of gallery :(
Ok, you have a non-homogeneous tree structure. So you need to create a
list property that:
* For a Mail instance, observes the mail folders
* For a MailFolder instance, observes the mail entries
Use DelegatingListProperty:
IListProperty childrenProp = new DelegatingListProperty() {
IListProperty mailFolders = EMFProperties.list(
ModelPackage.Literals.PIM_MAIL__CURRENT_FOLDER);
IListProperty folderEntries = EMFProperties.list(
ModelPackage.Literals.PIM_MAIL_FOLDER__ENTRIES);
protected IListProperty doGetDelegate(Object source) {
if (source instanceof Mail)
return mailFolders;
if (source instanceof MailFolder)
return folderEntries;
This is just a specialized IListProperty extension interface that lets
you do property chaining using EMF structural features:
IEMFListProperty foldersProp =
IEMFListProperty folderNamesProp =
foldersProp.values(ModelPackage.Literals.PIM_MAIL_FOLDER__NA ME);
Using this second property you could:
IEMFObservableList folderNamesObs = folderNamesProp.observe(mail);
...which gives you an observable list of folder *names*. Property
chaining allows you to project a value property over all elements of the
master list.
Hope this helps,
Matthew
Re: GalleryTreeViewer & IEMFListProperty [message #491783 is a reply to message #491782] Thu, 15 October 2009 15:17 Go to previous messageGo to next message
> return mailFolders;
else return null :)
Re: GalleryTreeViewer & IEMFListProperty [message #492138 is a reply to message #491783] Mon, 19 October 2009 01:01 Go to previous messageGo to next message
Hi, Matthew
Thanks for reply and give me explanation about IEMFListProperty Smile and it's work now Smile
about Nebula Gallery :
when i move my application, it always refresh the viewer, how to make it not refresh the canvas when i move the application or minimize or maximize my application ?
about GalleryTreeViewer :
I have a model structure like a list, only 1 root and many list item, can it handle by GalleryTreeViewer ?
Re: GalleryTreeViewer & IEMFListProperty [message #598431 is a reply to message #491540] Thu, 15 October 2009 06:29 Go to previous messageGo to next message
Re: GalleryTreeViewer & IEMFListProperty [message #598438 is a reply to message #598431] Thu, 15 October 2009 09:22 Go to previous messageGo to next message
Hope this helps,
Matthew
Re: GalleryTreeViewer & IEMFListProperty [message #598441 is a reply to message #491688] Thu, 15 October 2009 12:12 Go to previous messageGo to next message
Mail
here is my code :
return viewer;
Re: GalleryTreeViewer & IEMFListProperty [message #598444 is a reply to message #598441] Thu, 15 October 2009 15:16 Go to previous messageGo to next message
> here is my code :
> return viewer;
list property that:
return mailFolders;
master list.
Hope this helps,
Matthew
Re: GalleryTreeViewer & IEMFListProperty [message #598451 is a reply to message #491782] Thu, 15 October 2009 15:17 Go to previous messageGo to next message
> return mailFolders;
else return null :)
Re: GalleryTreeViewer & IEMFListProperty [message #598469 is a reply to message #491783] Mon, 19 October 2009 01:01 Go to previous message
Hi, Matthew
Thanks for reply and give me explanation about IEMFListProperty :) and it's work now :)
Previous Topic:Gantt chart on seconds level
Next Topic:GridTableViewer Sorting
Current Time: Sun Jul 20 19:48:30 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
