Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] URI Similarity?
[EMF Compare] URI Similarity? [message #491491] Wed, 14 October 2009 14:51 Go to next message
I'm running into a problem where the diff engine is thinking that two of my references are the same
because they have similar (but different URIs). I'm working on overriding that behavior by creating
my own diff engine, so how to "fix" the problem is not my question.
Instead, I'm wondering why similar, but different URIs would ever be considered the same? It seems
to me that if the path in the URI is different, than the URI is different. The only place I can
think of that you could have differences that don't matter is in the server name (authority?)
portion. But I spend most of my time thinking about URIs that are HTTP URLs.
Are there some case I'm not considering here?
Thanks.
--Stephen
Re: [EMF Compare] URI Similarity? [message #491586 is a reply to message #491491] Thu, 15 October 2009 03:45 Go to previous messageGo to next message
--------------010102090708060100060307
Hi Stephen,
There are two places where we compare URIs within EMF Compare, and in
both two different URIs does not always mean different Objects.
The first of these two places is when we try to match resources together
within a given resource set. These URIs can take a number of shapes :
platform scheme URIs, file scheme URIs, ... http urls are in fact the
rarest. We consider two such URIs "similar" even when they are "not
equal" as the very same model could have been moved from one directory
to the other between the two versions. AFAIU, HTTP scheme URIs can have
a segment differing for the same cause : changed directory on the server.
The second place where we compare URIs is when trying to match two nodes
contained in two distinct models... and the very same as above : the
node could have changed parent ... and be the same anyway.
Let's take a class diagram as an example, named "model1.ecore". We have
a package "p1" in it containing a class "ClassA". The URI of this class
would be either :
file:/<path>/model1.ecore#//p1/ClassA
platform:/resource/<path>/model1.ecore#//p1.ClassA
platform:/plugin/<path>/model1.ecore#//p1.ClassA
http://server/<path>/model1.ecore#//p1.ClassA
.... you catch the drift.
now what if we change the name of our package to "package"? And at the
same time let's say we moved the model to the directory "models". URIs
are now :
file:/<path>/models/model1.ecore#//package/ClassA
So when comparing the URIs, we simply cannot assume that distinct URIs
_always_ point to objects that don't match, whether we're comparing the
URI itself or the fragment.
If I didn't understand the question, feel free to correct me; but I
can't think of another place we compare URIs within EMF Compare ;).
Laurent Goubet
Obeo
Stephen McCants a
Re: [EMF Compare] URI Similarity? [message #491807 is a reply to message #491586] Thu, 15 October 2009 18:24 Go to previous messageGo to next message
Hi Laurent,
Thanks for the explanation. That makes sense. If it becomes a problem in my specific cases, then
I can always override/extend the DiffEngine. It was giving me trouble because my unit tests have
artificially simple URIs that usually differ by one character (for example
file:///tmp/testobject1.xml). By making my URIs more distinct, I can work around it and continue to
test against the GenericDiffEngine.
Also, on a different note, thank you for getting those three fixes committed to HEAD yesterday!
--Stephen
laurent Goubet wrote:
> Hi Stephen,
> would be either :
> are now :
> Laurent Goubet
> Obeo
> Stephen McCants a écrit :
>> Hello,
>> two of my references are the same because they have similar (but
>> be considered the same? It seems to me that if the path in the URI is
>> different, than the URI is different. The only place I can think of
>> name (authority?) portion. But I spend most of my time thinking about
>> Thanks.
>> --Stephen
Re: [EMF Compare] URI Similarity? [message #491843 is a reply to message #491807] Fri, 16 October 2009 03:14 Go to previous message
--------------000401080207070206070407
Hi Stephen,
Comments inlined.
Laurent Goubet
Obeo
Stephen McCants a
Re: [EMF Compare] URI Similarity? [message #621477 is a reply to message #491491] Thu, 15 October 2009 03:45 Go to previous message
Hi Stephen,
would be either :
are now :
Laurent Goubet
Obeo
Stephen McCants a
Re: [EMF Compare] URI Similarity? [message #621485 is a reply to message #491586] Thu, 15 October 2009 18:25 Go to previous message
Hi Laurent,
--Stephen
> Hi Stephen,
> would be either :
> are now :
> Laurent Goubet
> Obeo
>> Hello,
>> Thanks.
>> --Stephen
Re: [EMF Compare] URI Similarity? [message #621488 is a reply to message #621485] Fri, 16 October 2009 03:14 Go to previous message
Hi Stephen,
Comments inlined.
Laurent Goubet
Obeo
Stephen McCants a
Previous Topic:[EcoreTools] Multiple packages
Next Topic:[EMF Compare] Getting started
Current Time: Sun Jul 20 12:13:50 EDT 2025
Powered by FUDForum. Page generated in 0.06087 seconds
