Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Problem with SWT Browser and IE7(Works in debug, but not in standalone RCP app)
Problem with SWT Browser and IE7 [message #491563] Wed, 14 October 2009 23:59 Go to next message
I have a problem with using the SWT browser that is really weird. My project involves building a RCP application which embeds a SWT browser in the UI. The application runs in a network environment that requires proxy access (configured using a pac script; no authentication required).
When I run the application in Eclipse from source, the application behaves as expected (the browser loads the URL specified) However, when I build the application and run it as standalone RCP application, the browser opens the IE "This program cannot display the webpage" page (res://ieframe.dll/dnserrordiagoff_webOC.htm#<my URL>)
I am running this under Windows XP, tried running the process as unrestricted, but no luck. The same web site works fine in Internet Explorer and when running inside Eclipse, so I don't think it's a network issue. I configured the proxy settings using the org.eclipse.core.net package, and in Java code I am able to connect to the server, but it seems like IE is not able to connect.
I am using Eclipse 3.4.
I checked and make sure the Eclipse version is the same between my Eclipse environment and standalone environment. It's running under the same JVM as well, with same configuration settings (e.g., Xmx, Xms).
Any advices? I have been stuck on this for a long time and I can't figure out what the difference could be between running the application in Eclipse vs running in my RCP app...
Adrian
Re: Problem with SWT Browser and IE7 [message #491942 is a reply to message #491563] Fri, 16 October 2009 11:54 Go to previous messageGo to next message
Hi Adrian,
Though I've never used a pac script before, it's likely that your script is
not being found in the RCP case. Can you add a line to print "Hello!" to
your FindProxyForURL() implementation to prove/disprove this? A resource
not being found is usually the cause when a behaviour changes when run in a
different environment. I can't imagine embedded IE behaving any differently
otherwise in an eclipse context vs. an RCP one.
HTH,
Grant
<adrian.pang@sap.com> wrote in message
news:hb66n4$12k$1@build.eclipse.org...
> Hello,
> Adrian
Re: Problem with SWT Browser and IE7 [message #491949 is a reply to message #491942] Fri, 16 October 2009 13:12 Go to previous message
If I debug into the proxy code, it seems like Eclipse is able to find the proxy correctly (it detected the right proxy to use and the port number). If I connect using java.net.URL, it works as expected. However, it's only the embedded IE that cannot open internet web sites.
I tried upgrading to IE 8, which has the same problem, but if I downgrade to IE 6, the problem goes away -- I would assume it's something broken in IE 7, but that doesn't explain why it works in debug mode.
Very confused...
Adrian
Previous Topic:Get which TreeItem has focus in a Tree ?
Next Topic:Problem when including combo boxes as subitems in multi column tree.
Current Time: Sat Jul 19 17:40:52 EDT 2025
Powered by FUDForum. Page generated in 0.03063 seconds
