Home » Modeling » EMF » XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change"(XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change")
XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #490996] Mon, 12 October 2009 13:42 Go to next message
Hi All,
problem description : I am using EMF .4.x.v200902171115 - to develop a tool and I see that QNames are not getting resolved properly when I undo my change !
detail steps :
1. Lets assume : we have an EList mySpaces which hold a list of QNames
-- persisted as
<mydomain:myModel .. xmlns:xyz = "http://www/xyz.com/"
<mydomain:mySpace horizon="xyz:myQName" /> ...
2. somewhere in system a RecordingCommand fires to clear the list of qnames-
mySpacesEList.getHorizons().removeAll()
3. while removing the qname, emf prepares a List of changes and includes
removed qname value in that list as follows ...
-- ListChangeImpl#DataValueDelegatingList#
-- new DelegatingEList() {
-- validate(index, object)
-- ECoreUtil.convertToString(type, object)
-- XMLTypeFactoryImpl#convertQNameToString(type, instanceVal)
*** now here instanceVal is a QName
with targetNS =http://www/xyz.com/
localpart=myQName
prefix=xyz
*** returns "xyz:myQName"
** here its important to note that emf does not append targetNS in the
converted string !!
4. Next, I undo my change from UI .. so emf tries to retrieve the saved
changes and convert them back into relevant objects ..
-- resolve(index, object)
-- ECoreUtil.createFromString(type, (String)object)
-- XMLTypeFactoryImpl#createQNameFromString(type, val)
*** val is "xyz:myQName"
5. Now createQName("xyz:myQName")--
(i) simply checks if val startsWith "{" then it can resolve name space - which actually will never happen as
convertQNameToString() never appends targetNS to the
qnameLiteral
(ii) in the else part - createQName(val) does nothing !
**** actually, in the else block it should extract the prefix and query the xmlnsPrefixMap to find the namespace and - then create a QName with the resolved namespace and literal.
6. -- So finally, user gets a qname without targetNS which breaks the
functionality of the system.
Please let me know the solution for this issue and correct me if I failed
to understand the QName resolution logic.
Is there any way I can extend / register XMLTypeFactory to override
createQName() ? or can I register my own Data Converter ?
thanks
Kaniska
P.S. - I have to use only emf 2.4.x.v200902171115
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491049 is a reply to message #490996] Mon, 12 October 2009 23:49 Go to previous messageGo to next message
Kaniska,
Comments below.
Kaniska Mandal wrote:
> Hi All,
> undo my change !
> detail steps :
> -- persisted as
> qnames-
> localpart=myQName
> prefix=xyz
> converted string !!
QNames unfortunately are an odd ball data type where only the prefix and
the local name are part of the value (the serializer relies on that
behavior), while the namespace is recorded elsewhere in the serialization...
> qnameLiteral (ii) in the else part - createQName(val)
> does nothing !
Yes, I can imagine it working that way...
It sounds like an issue. I'm not sure what can be done about it;
special handling during the conversion step I suppose....
> createQName() ?
No, and changing that would break the serialization of QNames which
relies on the current behavior.
No. Open a bugzilla and I'll try to find time to figure out what a good
solution might be.
> thanks
> Kaniska
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491239 is a reply to message #491049] Tue, 13 October 2009 14:44 Go to previous messageGo to next message
Ed,
Thanks for the clarification.
I opened a bug - https://bugs.eclipse.org/bugs/show_bug.cgi?id=292182
I didn't understand ... the 'limitation of qname deserialization' .
Why - XMLTypeFactoryImpl#createQNameFromString() - should not resolve the targetNameSpace ( ... the else block can extract the prefix and query the xmlnsPrefixMap to find the namespace) ... and why the namespace should not be placed inside the returned QName
Kaniska
[Updated on: Tue, 13 October 2009 14:45] by Moderator
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491240 is a reply to message #491239] Tue, 13 October 2009 14:53 Go to previous messageGo to next message
Additional Notes :
1. This problem occurs only if we use RecordingCommand (emf), AbstractTransactionalCommand (gmf) or any IUndoableOperation
2. QName gets recreated properly upon Undoing changes, if we use 'AddCommand' and 'RemoveCommand' of EMF.
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491255 is a reply to message #491239] Tue, 13 October 2009 15:49 Go to previous messageGo to next message
Kaniska,
Comments below.
> Ed,
Did you look at the arguments to that method? There's only a String
argument, so how exactly are you imagining it could possibly resolve the
prefix?
> Kaniska
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491256 is a reply to message #491240] Tue, 13 October 2009 15:52 Go to previous messageGo to next message
Kaniska,
Comments below.
> Additional Notes :
The problem you described sounds like an issue with recording a QName as
a String...
So you have a workaround; I suppose and then it's not a blocker. In any
case, unless you provide a test case I can run, rather than describing
to me how to create a test case myself, I won't look at the problem.
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491461 is a reply to message #491256] Wed, 14 October 2009 13:14 Go to previous messageGo to next message
Sure I should provide the testcase asap.
Yah its true that actual issue boils down to - 'recording qname as string literal'
Regarding proposed solution - what I meant is ..
>> (1) say user created a qname with prefix "xyz"
>> (2) then converttStringToQName(val) .. will have an argument - "xyz:myQname",
>> (3) we can extract "xyz" from the argument ... and then >> (4) lookup xmlnsPrefixMap with the key "xyz" beause
>> (5) xmlns:xyz "http://www.examples.com" is already persisted in the model and xmlnsPrefixMap [xyz:targetNS] is available through extendedMetaData.
In case, the argument does not contain any nsPrefix, we won't have any targetNS as usual.
But if the user provides a prefix while firsttime creating a qname , he would expect that the namespace should be resolved from persisted metadata by using the prefix while reconstructing the qname.
Please let me know if my understanding is correct.
thanks
kaniska
Re: XMLTypeFactoryImpl fails to recreate QNames properly while "undoing change" [message #491532 is a reply to message #491461] Wed, 14 October 2009 17:42 Go to previous message
Kaniska,
Comments below.
> string literal'
>>> "xyz:myQname", (3) we can extract "xyz" from the argument ... and
>>> then >> (4) lookup xmlnsPrefixMap with the key "xyz" beause (5)
>>> extendedMetaData.
> targetNS as usual.
Well, an xmlns="xxx" declaration specifies a namespace for the
null/absent prefix, so I don't think this is true.
What's the context in which this is occurring? How does the user know
what prefixes are available and what they map to? I'm not I understand
how this user issue relates to this specific issue...
> thanks
> kaniska
Previous Topic:Mapping a file to my own protocol resource
Next Topic:[TENEO] PersistenceOptions.CASCADE_POLICY_ON_CONTAINMENT, "FALSE" and Addition of a new Ob
Current Time: Sun Jul 20 19:34:15 EDT 2025
Powered by FUDForum. Page generated in 0.03766 seconds
