Home » Eclipse Projects » DTP » Programmatically DB access connection via DTP on Eclipse 3.5 (Galileo)(Programmatically DB access connection via DTP on Eclipse 3.5 (Galileo))
Programmatically DB access connection via DTP on Eclipse 3.5 (Galileo) [message #490663] Fri, 09 October 2009 11:33 Go to next message
I don't understand how to connect code-side to my Connection Profile created in the Database Development Perspective.
My tree is here:
Database Connections
- test (MySQL v. 5.0.0)
-- test
---Authorization IDs
---Schemas
I changed perspective to Plug-in development coding
IConnectionProfile profile = ProfileManager.getInstance().getProfileByName("test");
without any result.
I also tried this:
IConnectionProfile[] profile = ProfileManager.getInstance().getProfiles();
logger.info("!! profiles " + profile.length);
for (IConnectionProfile iConnectionProfile : profile) {
logger.info("!! iConnectionProfile ************************ ");
logger.info("!! getName "+iConnectionProfile.getName());
logger.info("!! getDescription "+iConnectionProfile.getDescription());
logger.info("!! getInstanceID "+iConnectionProfile.getInstanceID());
but the length of profiles is always empty (returning 0).
What else can I do? Neutral
Thank you in advance,
Le
Re: Programmatically DB access connection via DTP on Eclipse 3.5 (Galileo) [message #491503 is a reply to message #490663] Wed, 14 October 2009 15:42 Go to previous message
That's very odd...
If "test" is showing up as a database profile in the data source
explorer... This should do the trick:
Can you tell me a bit about the code where you're trying to get the
profile handle from? Is it in a RCP app? If so, can you try doing the
same thing in the Eclipse Workbench?
--Fitz
> My tree is here:
> -- test
> ---Schemas
> without any result.
> I also tried this:
> What else can I do? :|
> Le
Previous Topic:Programmatically access a JDBC connection via DTP
Next Topic:Programmatically DB access connection via DTP on Eclipse 3.5 (Galileo)
Current Time: Sat Jul 19 18:50:28 EDT 2025
Powered by FUDForum. Page generated in 0.24075 seconds
