Home » Modeling » EMF » [Teneo] CurrentSession problem with spring managed transactions
[Teneo] CurrentSession problem with spring managed transactions [message #491132] Tue, 13 October 2009 08:36 Go to next message
Hello, I'm facing problems with Spring managed Txs when working with
HbSessionDataStore. Problem is caused by
sessionFactory.getCurrentSession() failing in transactional scope. My
session factory is configured in Spring context as HbSessionDataStore
and transactions are provided by HibernateTransactionManager.
When trying to save new entity to DB by invoking
sessionFactory.getCurrentSession().saveOrUpdate(entity), test fails with
org.hibernate.HibernateException: No CurrentSessionContext configured!
This is strange since the call is in transactional scope. I've tried to
setup transactions either with Spring TransactionTemplate or
@Transactional annotation or AspectJ style is Spring context (none of it
helped).
When invoking the same test case with standard POJO entities and session
factory configured with Spring AnnotationSessionFactoryBean (no
Teneo), sessionFactory.getCurrentSession() returns working session and
transaction commits without errors.
Part of my spring context config follows:
<bean id="sessionFactory"
class="org.eclipse.emf.teneo.hibernate.HbSessionDataStore"
init-method="initialize">
<property name="name" value="test-store" />
<property name="hibernateProperties">
<props>
<prop key="hibernate.dialect">${hibernate.dialect}</prop>
<prop key="hibernate.show_sql">false</prop>
<prop key="hibernate.hbm2ddl.auto">create</prop>
<prop key="hibernate.generate_statistics">true</prop>
<prop key="hibernate.connection.datasource">java:comp/env/jdbc/teneo </prop>
</props>
</property>
<property name="EPackageClasses">
<list>
<value>eu.collectionspro.test.entity.impl.EntityPackageImpl </value>
</list>
</property>
</bean>
<bean id="transactionManager"
class=" org.springframework.orm.hibernate3.HibernateTransactionManag er ">
<property name="sessionFactory" ref="sessionFactory" />
</bean>
Thanks for help,
David
Re: [Teneo] CurrentSession problem with spring managed transactions [message #491156 is a reply to message #491132] Tue, 13 October 2009 09:32 Go to previous messageGo to next message
Hi David,
Maybe it is a default configuration setting difference, can you try the following extra hibernate configuration setting:
<prop key="hibernate.current_session_context_class">thread</prop >
there are also two other values: jta and managed. I am not sure which one would work with Spring transactional scopes.
Let me know if this helped, or not...
gr. Martin
> helped).
> factory configured with Spring AnnotationSessionFactoryBean (no Teneo),
> <props>
> </props>
> </property>
> <list>
> </list>
> </property>
> </bean>
> </bean>
> Thanks for help,
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] CurrentSession problem with spring managed transactions [message #491187 is a reply to message #491156] Tue, 13 October 2009 10:54 Go to previous messageGo to next message
Hi Martin,
thanks for hint but it did not help. I'm runnig my test locally so I
can't use JTA session context. Setting the current_session_context_class
to thread produces different exception:
org.hibernate.HibernateException: saveOrUpdate is not valid without
active transaction
at
org.hibernate.context.ThreadLocalSessionContext$TransactionP rotectionWrapper.invoke(ThreadLocalSessionContext.java:338)
at $Proxy4.saveOrUpdate(Unknown Source)
at eu.collectionspro.dao.GenDaoHib.save(GenDaoHib.java:47)
at
eu.collectionspro.test.PopulateDbTest$3.doInTransactionWitho utResult(PopulateDbTest.java:147)
at
org.springframework.transaction.support.TransactionCallbackW ithoutResult.doInTransaction(TransactionCallbackWithoutResul t.java:33)
at
org.springframework.transaction.support.TransactionTemplate. execute(TransactionTemplate.java:128)
The last line of stack trace shows that my code is actually enclosed in
transaction managed by HibernateTransactionManager. There still must be
some other difference between Teneo session factory config/behavior and
Spring AnnotationSessionFactoryBean.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
>> with org.hibernate.HibernateException: No CurrentSessionContext
>> configured! This is strange since the call is in transactional scope.
>> I've tried to setup transactions either with Spring
>> TransactionTemplate or @Transactional annotation or AspectJ style is
>> Spring context (none of it helped).
>> session factory configured with Spring AnnotationSessionFactoryBean
>> (no Teneo), sessionFactory.getCurrentSession() returns working session
>> and transaction commits without errors.
>> <props> <prop
>> <prop
>> </props>
>> </property>
>> <list>
>> </list>
>> </property> </bean>
>> </bean>
>> Thanks for help,
>> David
Re: [Teneo] CurrentSession problem with spring managed transactions [message #491199 is a reply to message #491187] Tue, 13 October 2009 11:36 Go to previous messageGo to next message
Hi David,
Did you try the managed option?
A search on the internet also showed other options:
http://histos.net/blog/2008/12/on-hibernate-spring-sessions- and-transactions.html
(using a spring context)
And this one (but it talks about the opposite, a Spring wrapped sessionfactory outside of a spring managed transaction,
but maybe it gives usefull info):
http://www.theresearchkitchen.com/blog/archives/73
Let me know if this helps, otherwise I can try to reproduce it locally (with your help).
gr. Martin
David Polách wrote:
> Hi Martin,
> active transaction
> at
> at
> at
> at
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>>> session and transaction commits without errors.
>>> <props> <prop
>>> <prop
>>> </props>
>>> </property>
>>> <list>
>>> </list>
>>> </property> </bean>
>>> </bean>
>>> Thanks for help,
>>> David
The Netherlands
Re: [Teneo] CurrentSession problem with spring managed transactions [message #491321 is a reply to message #491199] Wed, 14 October 2009 03:17 Go to previous messageGo to next message
Hi Martin,
looks like we both find the same solution - correct hibernate property
setting is:
<prop
key="hibernate.current_session_context_class">org.springframework.orm.hibernate3.SpringSessionContext </prop>
I found this when debugging the Spring AnnotationSessionFactoryBean -
spring sets this property programatically when building spring managed
sessionFactory.
Thank you for your fast responses :)
David
Martin Taal wrote:
> Hi David,
> sessionfactory outside of a spring managed transaction, but maybe it
> (with your help).
> gr. Martin
> David Polách wrote:
>> Hi Martin,
>> current_session_context_class to thread produces different exception:
>> active transaction
>> at
>> at
>> at
>> at
>> in transaction managed by HibernateTransactionManager. There still
>> must be some other difference between Teneo session factory
>> config/behavior and Spring AnnotationSessionFactoryBean.
>> Thanks,
>> David
>> Martin Taal wrote:
>>> Hi David,
>>> gr. Martin
>>>> My session factory is configured in Spring context as
>>>> HbSessionDataStore and transactions are provided by
>>>> scope. I've tried to setup transactions either with Spring
>>>> <props> <prop
>>>> <prop
>>>> </props>
>>>> </property>
>>>> <list>
>>>> </list>
>>>> </property> </bean>
>>>> </bean>
>>>> Thanks for help,
>>>> David
Re: [Teneo] CurrentSession problem with spring managed transactions [message #491330 is a reply to message #491321] Wed, 14 October 2009 03:40 Go to previous message
Hi David,
Thanks for letting us know that it works! I will probably add this somewhere in the docs.
gr. Martin
David Polách wrote:
> Hi Martin,
> setting is:
> <prop
> sessionFactory.
> David
> Martin Taal wrote:
>> Hi David,
>> (with your help).
>> gr. Martin
>> David Polách wrote:
>>> Hi Martin,
>>> active transaction
>>> at
>>> at
>>> at
>>> at
>>> Thanks,
>>> David
>>> Martin Taal wrote:
>>>> Hi David,
>>>> gr. Martin
>>>>> with HbSessionDataStore. Problem is caused by
>>>>> is Spring context (none of it helped).
>>>>> <props> <prop
>>>>> <prop
>>>>> </props>
>>>>> </property>
>>>>> <list>
>>>>> </list>
>>>>> </property> </bean>
>>>>> </bean>
>>>>> Thanks for help,
>>>>> David
The Netherlands
Previous Topic:[Teneo] getReference throws MappingException: Unknown entity exception
Next Topic:Mapping a file to my own protocol resource
Current Time: Sun Jul 20 18:49:42 EDT 2025
Powered by FUDForum. Page generated in 0.04204 seconds
