Home » Modeling » M2T (model-to-text transformation) » Re: Code generation in a Standalone Java Application
Re: Code generation in a Standalone Java Application [message #491133] Tue, 13 October 2009 08:36 Go to next message
Hi Asha,
I'm forwarding this one the m2t newsgroup.
Sebastian
Asha R schrieb:
> Not sure whether this is the right newsgroup or not to post this question.
> Is there something similar to JET that can be used programmatically in
> Java?
> The problem with JET is we can create a project and set some destination
> folder where templates get generated based on an action.
> But we need to implement something almost similar to what a JET does.
> So, is there any API that can be used to generate the code?
> Thank you in advance.
> Asha.
Re: Code generation in a Standalone Java Application [message #491138 is a reply to message #491133] Tue, 13 October 2009 08:47 Go to previous messageGo to next message
--------------010105010804040208000605
Hi Asha,
I don't know if you've got a specific m2t engine in view, and I don't
know if XPand allows for standalone generation of code. I do know
however that Acceleo supports both "runtime" generation within Eclipse
and "standalone" generation outside of Eclipse (with a single 'required'
dependency to Eclipse jars for "org.eclipse.core.runtime").
Laurent Goubet
Obeo
Sebastian Zarnekow a écrit :
> Hi Asha,
> Regards,
> Sebastian
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyLyI+T2JlbzwvYT4NCmVtYWls O2ludGVybmV0
OmxhdXJlbnQuZ291YmV0QG9iZW8uZnINCnVybDpodHRwOi8vd3d3Lm9iZW8u ZnINCnZlcnNp
b246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------010105010804040208000605--
Re: Code generation in a Standalone Java Application [message #491161 is a reply to message #491138] Tue, 13 October 2009 09:27 Go to previous message
Yes, Xpand as well can be used and executed in any Java process.
No Eclipse dependency and no need to compile templates before executing
them, since Xpand templates are interpreted.
Sven
laurent Goubet schrieb:
> Hi Asha,
> Laurent Goubet
> Obeo
>> Hi Asha,
>> Regards,
>> Sebastian
Previous Topic:[JET] OCL/Profiles
Next Topic:Transforming emx files (RSM)
Current Time: Sun Jul 20 14:23:45 EDT 2025
Powered by FUDForum. Page generated in 0.03618 seconds
