Home » Archived » BIRT » ReportScripting in BIRT 2.2.1 : Problem with the evaluation of an Expression
ReportScripting in BIRT 2.2.1 : Problem with the evaluation of an Expression [message #490610] Fri, 09 October 2009 08:00 Go to next message
I'm developping reports in BIRT 2.2.1 and i'm using some scripts to customize it. I would like to know how can I do to evaluate a NamedExpression on a Data item.
I know in BIRT 2.3, we can do this with : reportContext.evaluate(this.getNamedExpression("myNamedExpression ")).
But I'm not allowed to upgrade my BIRT for 2.3 version, so how can I evaluate a named expression in BIRT 2.2.1 because the evaluate() method does not exist in that version?
Thanks by advance,
Maghen
Re: ReportScripting in BIRT 2.2.1 : Problem with the evaluation of an Expression [message #490968 is a reply to message #490610] Mon, 12 October 2009 11:45 Go to previous message
Maghen,
Can you try just eval(this.getNamedExpression("myNamedExpression "));
I do not remember if this works in 2.2 but worth a try.
Jason
Maghen Calinghee wrote:
> Thanks by advance,
> Maghen
Previous Topic:Problem with syntax trying to pass parameter to Java Object
Next Topic:Error after creating the second report
Current Time: Sun Jul 20 13:05:12 EDT 2025
Powered by FUDForum. Page generated in 0.03729 seconds
