Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Select folder dialog box .
Select folder dialog box . [message #480138] Fri, 14 August 2009 02:04 Go to next message
i want to export files from my application to a selected folder on machine.
But i dont know how 2 show a select folder dialog box .
we hav file select dialogbox but no folder select dialogbox .
Plz tell me how 2 show a folder select dialogbox
which also provide way to create new folder if needed
Thanks in Advance
Neha
Re: Select folder dialog box . [message #480153 is a reply to message #480138] Fri, 14 August 2009 03:49 Go to previous messageGo to next message
On 14/08/2009 07:04, Neha wrote:
> Thanks in Advance
> Neha
DirectoryDialog?
Derek
Re: Select folder dialog box . [message #490867 is a reply to message #480138] Mon, 12 October 2009 01:48 Go to previous message
HI Neha,
Use following code snippet, i hope it will work for you.
String fileFilterPath=getProjectPath();
FileDialog fileDialog = new FileDialog(getShell(), SWT.SINGLE);
fileDialog.setFilterPath(fileFilterPath);
fileDialog.setFilterExtensions(new String[]{"*.csv","*.tsv"});
String firstFile = fileDialog.open();
if(firstFile != null) {
fileFilterPath = fileDialog.getFilterPath();
String[] selectedFiles = fileDialog.getFileNames();
String fileName=null;
if(selectedFiles.length>0){
fileName=selectedFiles[0];
csvFile.setText(fileFilterPath+"\\"+fileName.toString());
Prakash
Previous Topic:How to integrate eclipse help system with own plug-in UI
Next Topic:[MACOSX] Error handling events on GMF diagrams
Current Time: Sat Jul 19 17:43:38 EDT 2025
Powered by FUDForum. Page generated in 0.04132 seconds
