Home » Eclipse Projects » Mylyn » Automatic changesets aren't, well, doing anything
Automatic changesets aren't, well, doing anything [message #490388] |
Thu, 08 October 2009 10:14  |
I suspect user error, but I don't know what I'm doing wrong. I have automatic changeset management turned on in my preferences. If I activate a task from a project that's linked with an SVN repository, open a file, make a change, and save it, I see the change in the Synchronize view, but it's not associated with any changeset (none are created). I can right-click on it and manually assign it to a new changeset, but by itself it's not creating one.
Since it's all automagic, I'm not sure how to troubleshoot this. Any tips?
Eclipse Galileo 20090621-0832
Mylyn 3.2.2
Subclipse 1.6.5
Mylyn Team Support is installed
Re: Automatic changesets aren't, well, doing anything [message #490404 is a reply to message #490388] |
Thu, 08 October 2009 10:36   |
> Mylyn 3.2.2
> Subclipse 1.6.5
Are you closing the editor? That removes the file from the changeset.
Mark
Re: Automatic changesets aren't, well, doing anything [message #490479 is a reply to message #490466] |
Thu, 08 October 2009 15:02   |
On 2009-10-08 14:04:17 -0400, Bill <bkocik@gmail.com> said:
> Mark Phippard wrote on Thu, 08 October 2009 13:26
>> I am sorry for not suggesting that. In your original email I read this:
>> "Mylyn Team Support is installed"
>> and for some reason I read it as that you had installed the
>> Subclipse/Mylyn integration.
> No need for apologies - I appreciate everyone's help. :)
>> This integration should also cause references to tasks within your log
>> messages in the History view to open in Mylyn.
> That actually doesn't work, but I suspect that's a failing of my
> repository connector. I use Redmine, and the plugins for that are
> pretty young and not yet very robust.
> However it is writing my commit comments for me automatically, which is nice.
In your project properties, Mylyn contributes a page that lets you
associate the project with a Task Repository. Try that. Also, I think
it only works if you do Show History from your working copy (as opposed
to from the SVN Repositories view).
Mark
Re: Automatic changesets aren't, well, doing anything [message #599505 is a reply to message #490388] |
> Mylyn 3.2.2
> Subclipse 1.6.5
Mark
Re: Automatic changesets aren't, well, doing anything [message #599545 is a reply to message #599516] |
Thu, 08 October 2009 11:49  |
Bill ha scritto:
> Is there some delay before a changeset is created and a change becomes
> part of it? I've tried letting things settle for several minutes,
> changing multiple files thinking maybe one wasn't enough...nothing seems
> to be doing it.
Well, it's strange. It works for me except sometimes in the following cases:
- when you delete a file, it often goes to "no change set" instead of
the current one
- when you do a refactor or an action that causes indirect modifications
to other files, sometimes some of those files fall to "no change set"
instead of the current one
Maybe your problem is Subclipse? Maybe you have to install some kind of
Mylyn-integration for it?
I'm working with CVS.
Mauro.
Re: Automatic changesets aren't, well, doing anything [message #599558 is a reply to message #490431] |
Thu, 08 October 2009 12:37  |
Mauro Molinari wrote on Thu, 08 October 2009 11:49
> Mauro.
Those were the magic words. I wasn't aware of it until you said this and I went searching, but it turns out the Tigris Subclipse 1.6 update site (http://subclipse.tigris.org/update_1.6.x) offers a package called "Subclipse Integration for Mylyn 3.x." I installed version 3.0.0 of this package and now it's working.
For some reason I had to go into my prefs and turn of automatic changeset management, apply settings, and then turn it back on. As soon as I did that it started working.
Thank you so much!
Re: Automatic changesets aren't, well, doing anything [message #599567 is a reply to message #599558] |
Thu, 08 October 2009 13:26  |
>> Mauro.
> Thank you so much!
Subclipse/Mylyn integration. This integration should also cause
references to tasks within your log messages in the History view to
open in Mylyn.
Glad it is working.
Mark
Re: Automatic changesets aren't, well, doing anything [message #599575 is a reply to message #490457] |
Thu, 08 October 2009 14:04  |
> open in Mylyn.
That actually doesn't work, but I suspect that's a failing of my repository connector. I use Redmine, and the plugins for that are pretty young and not yet very robust.
Re: Automatic changesets aren't, well, doing anything [message #599582 is a reply to message #599575] |
Mark
Re: Automatic changesets aren't, well, doing anything [message #599590 is a reply to message #490479] |
Thu, 08 October 2009 15:18  |
Mark Phippard wrote on Thu, 08 October 2009 15:02
> Mark
After doing that it still wasn't working, but it might have been because of the formatting style I was using in my commit comments. I would write:
Redmine 1234 - some commit comment
Mylyn is writing:
task 1234: some commit comment (which is the task description)
For tasks that I let it write the commit comment for, it's able to open the corresponding task from history.
Thanks again...
Current Time: Sat Jul 19 05:45:25 EDT 2025
Powered by FUDForum. Page generated in 0.07562 seconds
