Possible Memory Leak in ViewerServlet [message #489314] |
Fri, 02 October 2009 08:04  |
Hi all.
I integrated the BIRT Viewer Servlet into my JSF Application. As described in http://www.eclipse.org/birt/phoenix/deploy/viewerUsage2.2.ph p.
After i copied all the necessary libs and plugins and so on i finally got it working (there should be a hint in the tutorial that the <birt:viewer> Tag is not to be placed within a form-tag because it renders it's own HTML form.) But that's not the problem i'd like to post about.
After Playing around and generating a few reports i got an OutOfMemory Exception saying something about PermGen like in this case http://dev.eclipse.org/newslists/news.eclipse.birt/msg20164. html.
So i opened the Windows Task-manager and observed the memory used by the JVM, which is becoming larger and larger. So i think there might be a memory leak in the viewerservlet.
Even the destruction of the session doesn't work.
I'm using the viewerExample of the birt-runtime-2_5_1 on a jboss-4.2.3. The managedBean behind the jsp page is feeding the report with parameters. I set the Bean to request scope but this didn't help.
Can anybody point me somewhere how to fix this?
have a nice weekend,
Michal
[Updated on: Fri, 02 October 2009 08:06] by Moderator
FUDForum. Page generated in 0.04403 seconds
