Home » Eclipse Projects » Mylyn » Automatic changesets aren't, well, doing anything
Automatic changesets aren't, well, doing anything [message #490388] Thu, 08 October 2009 10:14 Go to next message
I suspect user error, but I don't know what I'm doing wrong. I have automatic changeset management turned on in my preferences. If I activate a task from a project that's linked with an SVN repository, open a file, make a change, and save it, I see the change in the Synchronize view, but it's not associated with any changeset (none are created). I can right-click on it and manually assign it to a new changeset, but by itself it's not creating one.
Since it's all automagic, I'm not sure how to troubleshoot this. Any tips?
Eclipse Galileo 20090621-0832
Mylyn 3.2.2
Subclipse 1.6.5
Mylyn Team Support is installed
Re: Automatic changesets aren't, well, doing anything [message #490404 is a reply to message #490388] Thu, 08 October 2009 10:36 Go to previous messageGo to next message
> Mylyn 3.2.2
> Subclipse 1.6.5
Are you closing the editor? That removes the file from the changeset.
Mark
Re: Automatic changesets aren't, well, doing anything [message #490405 is a reply to message #490404] Thu, 08 October 2009 10:38 Go to previous messageGo to next message
This is not true. If you close the editor, the file is removed from the
current context, but NOT from the changeset.
Mauro.
Re: Automatic changesets aren't, well, doing anything [message #490413 is a reply to message #490405] Thu, 08 October 2009 10:58 Go to previous messageGo to next message
Either way, no, I'm not. Smile
Is there some delay before a changeset is created and a change becomes part of it? I've tried letting things settle for several minutes, changing multiple files thinking maybe one wasn't enough...nothing seems to be doing it.
Oh, and I should note that I also have "Show changesets" enabled on the Synchronize view. I've tried fiddling with it, turning it off and back on. Nothing.
[Updated on: Thu, 08 October 2009 11:00] by Moderator
Re: Automatic changesets aren't, well, doing anything [message #490426 is a reply to message #490413] Thu, 08 October 2009 11:45 Go to previous messageGo to next message
I found changeset feature to be buggy or perhaps not well thought through. See my earlier post for details. Don't yet know if any of the issues were addressed in 3.2.2.
[Updated on: Thu, 08 October 2009 11:47] by Moderator
Re: Automatic changesets aren't, well, doing anything [message #490431 is a reply to message #490413] Thu, 08 October 2009 11:49 Go to previous messageGo to next message
> to be doing it.
Well, it's strange. It works for me except sometimes in the following cases:
- when you delete a file, it often goes to "no change set" instead of
the current one
- when you do a refactor or an action that causes indirect modifications
to other files, sometimes some of those files fall to "no change set"
instead of the current one
Maybe your problem is Subclipse? Maybe you have to install some kind of
Mylyn-integration for it?
I'm working with CVS.
Mauro.
Re: Automatic changesets aren't, well, doing anything [message #490433 is a reply to message #490431] Thu, 08 October 2009 11:58 Go to previous messageGo to next message
I sometimes have to switch between changeset presentation mode to Java and back to fix incorrect placement - there seem to be a refresh issue.
Re: Automatic changesets aren't, well, doing anything [message #490446 is a reply to message #490431] Thu, 08 October 2009 12:37 Go to previous messageGo to next message
Mauro Molinari wrote on Thu, 08 October 2009 11:49
Mauro.
Those were the magic words. I wasn't aware of it until you said this and I went searching, but it turns out the Tigris Subclipse 1.6 update site (http://subclipse.tigris.org/update_1.6.x) offers a package called "Subclipse Integration for Mylyn 3.x." I installed version 3.0.0 of this package and now it's working.
For some reason I had to go into my prefs and turn off automatic changeset management, apply settings, and then turn it back on. As soon as I did that it started working.
Thank you so much!
[Updated on: Thu, 08 October 2009 12:37] by Moderator
Re: Automatic changesets aren't, well, doing anything [message #490457 is a reply to message #490446] Thu, 08 October 2009 13:26 Go to previous messageGo to next message
>> Mauro.
> For some reason I had to go into my prefs and turn of automatic
> Thank you so much!
I am sorry for not suggesting that. In your original email I read this:
"Mylyn Team Support is installed"
and for some reason I read it as that you had installed the
Subclipse/Mylyn integration. This integration should also cause
references to tasks within your log messages in the History view to
open in Mylyn.
Glad it is working.
Mark
Re: Automatic changesets aren't, well, doing anything [message #490466 is a reply to message #490457] Thu, 08 October 2009 14:04 Go to previous messageGo to next message
Mark Phippard wrote on Thu, 08 October 2009 13:26
No need for apologies - I appreciate everyone's help. Smile
open in Mylyn.
That actually doesn't work, but I suspect that's a failing of my repository connector. I use Redmine, and the plugins for that are pretty young and not yet very robust.
However it is writing my commit comments for me automatically, which is nice.
Re: Automatic changesets aren't, well, doing anything [message #490479 is a reply to message #490466] Thu, 08 October 2009 15:02 Go to previous messageGo to next message
> No need for apologies - I appreciate everyone's help. :)
>> This integration should also cause references to tasks within your log
>> messages in the History view to open in Mylyn.
In your project properties, Mylyn contributes a page that lets you
associate the project with a Task Repository. Try that. Also, I think
it only works if you do Show History from your working copy (as opposed
to from the SVN Repositories view).
Mark
Re: Automatic changesets aren't, well, doing anything [message #490481 is a reply to message #490479] Thu, 08 October 2009 15:18 Go to previous messageGo to next message
Mark Phippard wrote on Thu, 08 October 2009 15:02
Mark
After doing that it still wasn't working, but it might have been because of the formatting style I was using in my commit comments. I would write:
Redmine 1234 - some commit comment
Mylyn is writing:
task 1234: some commit comment (which is the task description)
For tasks that I let it write the commit comment for, it's able to open the corresponding task from history.
Thanks again...
Re: Automatic changesets aren't, well, doing anything [message #490485 is a reply to message #490481] Thu, 08 October 2009 15:42 Go to previous messageGo to next message
Did you try changing the format of the commit comment template?
Re: Automatic changesets aren't, well, doing anything [message #490487 is a reply to message #490485] Thu, 08 October 2009 15:47 Go to previous message
Vladimir Grishchenko wrote on Thu, 08 October 2009 15:42
I don't really see a need to do that, since what it's doing now already works. It's only the hand-written comments I created before I got changesets working that aren't linked to a task. When Mylyn creates the commit message, everything works fine. I have no complaint. Smile
Re: Automatic changesets aren't, well, doing anything [message #599505 is a reply to message #490388] Thu, 08 October 2009 10:36 Go to previous message
> Mylyn 3.2.2
> Subclipse 1.6.5
Mark
Re: Automatic changesets aren't, well, doing anything [message #599514 is a reply to message #490404] Thu, 08 October 2009 10:38 Go to previous message
Mauro.
Re: Automatic changesets aren't, well, doing anything [message #599516 is a reply to message #490405] Thu, 08 October 2009 10:58 Go to previous message
Either way, no, I'm not. :)
Re: Automatic changesets aren't, well, doing anything [message #599533 is a reply to message #599516] Thu, 08 October 2009 11:45 Go to previous message
Re: Automatic changesets aren't, well, doing anything [message #599545 is a reply to message #599516] Thu, 08 October 2009 11:49 Go to previous message
> to be doing it.
the current one
Mauro.
Re: Automatic changesets aren't, well, doing anything [message #599551 is a reply to message #490431] Thu, 08 October 2009 11:58 Go to previous message
Re: Automatic changesets aren't, well, doing anything [message #599558 is a reply to message #490431] Thu, 08 October 2009 12:37 Go to previous message
> Mauro.
For some reason I had to go into my prefs and turn of automatic changeset management, apply settings, and then turn it back on. As soon as I did that it started working.
Thank you so much!
Re: Automatic changesets aren't, well, doing anything [message #599567 is a reply to message #599558] Thu, 08 October 2009 13:26 Go to previous message
>> Mauro.
> Thank you so much!
open in Mylyn.
Glad it is working.
Mark
Re: Automatic changesets aren't, well, doing anything [message #599575 is a reply to message #490457] Thu, 08 October 2009 14:04 Go to previous message
> open in Mylyn.
Re: Automatic changesets aren't, well, doing anything [message #599582 is a reply to message #599575] Thu, 08 October 2009 15:02 Go to previous message
Mark
Re: Automatic changesets aren't, well, doing anything [message #599590 is a reply to message #490479] Thu, 08 October 2009 15:18 Go to previous message
> Mark
Mylyn is writing:
Thanks again...
Previous Topic:How to populate people content assist?
Next Topic:is sharing the mylyn DB folder between eclipse instances ok?
Current Time: Sat Jul 19 11:01:23 EDT 2025
Powered by FUDForum. Page generated in 0.09886 seconds
