Link property with 4 field...i don't set all [URGENT] [message #490174] |
Wed, 07 October 2009 12:23  |
@namespace(uri="http://dually/a0", prefix="A0")
@gmf(foo="bar")
package A0;
@gmf.link(source="from",target="to")
abstract class Link extends Element{
ref InteractionPoint[1] from;
ref InteractionPoint[1] to;
ref Component fromContext;
ref Component toContext;
@gmf.node(figure="rectangle",label="name")
abstract class Component extends Element{
@gmf.affixed(foo="bar")
val InteractionPoint[*] points;
@gmf.node(figure="rectangle", size="20,20", label="name",
label.placement="external", label.icon="false")
class InteractionPoint extends Element{
class SAcomponent extends Component {
@gmf.node(figure="rounded",label="name")
class SAconnector extends Component {
@gmf.link(target.decoration="rhomb",source.decoration="rhomb ")
class SABinding extends Link {
class Element {
attr String name;
attr String description;
@gmf.diagram (foo="bar")
class A0Spec extends Element {
val Element[*] elements;
this is my metamodel.
I have the following problem.
I can not set the fromContext and toContext when I create a link.
I have a component to a InteractionPoint B (posted on the board).
I have another component C with a InteractionPoint D (posted on the board).
Once you create the link from B to D I have the following properties.
from = B
fromContext = A
to = D
toContext = C
told me to use feuture sequence initializer but I can not understand what to do.
I think the problem there is because the link is between two InteractionPoint and I need to go back to the component that has on board (poster) the InteractionPoint
please can someone help me?
I realize the editor for my thesis and I was a bit late.
thank
marco
Re: Link property with 4 field...i don't set all [URGENT] [message #490188 is a reply to message #490174] |
Wed, 07 October 2009 13:42   |
Hi Marco,
Why do you need to capture both the "from" InteractionPoint and the
"fromContext" Component? As far as I can see, this is redundant as
"fromContext" can be actually calculated (is the eContainer() or "from")
- and similarly for "to" and "toContext".
Dimitris
> @gmf(foo="bar")
> package A0;
> class Element {
> attr String name;
> from = B
> fromContext = A
> to = D
> toContext = C
> what to do.
> thank
> marco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Link property with 4 field...i don't set all [URGENT] [message #490744 is a reply to message #490732] |
Fri, 09 October 2009 21:23  |
Hi Marco,
You don't need to draw the eContainer() - this is a method of EObject
that returns the container of the given object. I suggest you leave this
out for now and worry about it later if/when you need to process your
models.
Dimitris
marco wrote:
> hi
> because in the metamodel whole may have some SAcomponent inside of other
> elements and then I need to know what they are.
> I tried to use feature sequence initializer but I failed.This was an
> attempt.
> feature sequence initializer<SAbinding(fromContext,toContext)>
> reference new element spec <fromContenxt:= new Compoennt[1]>
> feature sequence initializer<new SAcomponent(name)>
> reference new element spec <name:= new EString[0]>
> reference new element spec <toContenxt:= new Compoennt[1]>
> I got this:
> fromContext: SAcomponent
> toContext: SAcomponent
> you know tell me how can I initialize it to give me the name of the
> component that contains the interaction point?
> how to draw the Econtainer?
> thanks marco
Re: Link property with 4 field...i don't set all [URGENT] [message #581580 is a reply to message #490174] |
Hi Marco,
Dimitris
> @gmf(foo="bar")
> package A0;
> class Element {
> attr String name;
> from = B
> fromContext = A
> to = D
> toContext = C
> what to do.
> thank
> marco
Re: Link property with 4 field...i don't set all [URGENT] [message #581821 is a reply to message #490188] |
Fri, 09 October 2009 17:22  |
hi
because in the metamodel whole may have some SAcomponent inside of other elements and then I need to know what they are.
I tried to use feature sequence initializer but I failed.This was an attempt.
I got this:
you know tell me how can I initialize it to give me the name of the component that contains the interaction point?
thanks marco
Re: Link property with 4 field...i don't set all [URGENT] [message #581870 is a reply to message #581821] |
Hi Marco,
models.
Dimitris
marco wrote:
> hi
> attempt.
> I got this:
> thanks marco
FUDForum. Page generated in 0.03617 seconds
