Home » Eclipse Projects » Remote Application Platform (RAP) » Registered resources are not loaded when installing bundles manualy?
icon5.gif  Registered resources are not loaded when installing bundles manualy? [message #489889] Tue, 06 October 2009 08:43 Go to next message
Hello Rich Ajax Community! Smile
I have a problem with registered resources to the extension point 'org.eclipse.rap.ui.resources'.
I followed the tutorial to create a custom google maps widget. When I start my run configuration with the widget bundle right from the beginning, the registered resources like the GMap.js is going to be registered by the ResourceManager (the getLocation method is invoked). Everything is ok.
But when I don't include my widget bundle in the run configuration and install and start that bundle manualy through the equinox console, no resource is going to be registered (getLocation method is not invoked). The widget can't find the java script class and throughs an error.
Why is the resource manager not able to register resource extensions on the fly while bundles are coming and going? I asume that the RM is scanning the extension registry once only at the beginning when equinox ist starting.
Is it possible to register ressources through the resource manager manualy in my code or is there any other trick that could solve this problem?
Best regards
Eduard
Re: Registered resources are not loaded when installing bundles manualy? [message #489924 is a reply to message #489889] Tue, 06 October 2009 10:02 Go to previous messageGo to next message
Eduard,
the resources extension (org.eclipse.rap.ui.resources) is read only
once when the first session is started.
To ResourceManager programmatically, call:
RWT#getResourceManager()
However, Javascript resources that are registered after the first
session was created will not be included in the index.html page.
HTH
Rüdiger
Eduard wrote:
> Hello Rich Ajax Community! :)
> Everything is ok.
> ist starting.
> problem?
> Best regards
> Eduard
Re: Registered resources are not loaded when installing bundles manualy? [message #489954 is a reply to message #489889] Tue, 06 October 2009 11:17 Go to previous messageGo to next message
Thank you for the fast reply Rüdiger.
And there is no way to solve this problem? RWT.getResourceManager().register("path") actually registers new ressources, but don't sends js files to the broweser?
Could I, theoreticaly, write some own java script in the widget renderInitialazation() method and load the js file that way instead using the helper methods from the JSWriter (writer.newWidget( "org.eclipse.rap.gmaps.GMap" ))?
Hmm, there is no description of the JSWriter in the API-Reference. Did somebody forgot that class? Smile
regards
Eduard
Re: Registered resources are not loaded when installing bundles manualy? [message #490441 is a reply to message #489954] Thu, 08 October 2009 12:14 Go to previous messageGo to next message
This is the way to go if you can't activate your bundle before
session startup.
> somebody forgot that class? :)
Ups, looks like we forgot to include them in the reference. We'll
fix that.
> regards
> Eduard
Re: Registered resources are not loaded when installing bundles manualy? [message #490552 is a reply to message #489889] Fri, 09 October 2009 02:53 Go to previous message
Hi Eduard,
i had the same problem and wrote my own ResourceManager to solve this.
I read in the javascript files manually with a streamreader, put all resources together in one big byte array and serve this to the browser using a servicehandler. This byte array is updated everytime a bundle comes or goes and makes a contribution to the ResourceManager
Additonally, I wrote a small static method in a qooxdoo class which is able to load and eval the js code from the service handler during runtime. (see qx.io.remote.Request(url))
Now you can invoke this method using a HtmlResponseWriter passing an url to it. I invoke the method every time a display is rendered using a PhaseListener.
Greetings
Onno
Previous Topic:Looking 4 Eclipselink/DataBinding Best Practice
Next Topic:Headless RAP application build example
Current Time: Sat Jul 19 19:14:05 EDT 2025
Powered by FUDForum. Page generated in 1.06008 seconds
