Home » Modeling » EMF » Suppressing document root but loosing name of top element.
Suppressing document root but loosing name of top element. [message #489536] |
Sun, 04 October 2009 11:36  |
I have a DocumentRoot declared that references the top element of the document using a relationship with the name
'rmap'. Everything works as expected. The XML is serialized with a top element <rmap> and I can edit the model, save it,
and edit again.
I wanted to get rid of the DocumentRoot in my generated editor so I added the load option OPTION_SUPPRESS_DOCUMENT_ROOT
= true.
The editor loads correctly and the document root is no longer displayed. Nice. The problem however, is that when I
change something and then save the model, the name of the top element is changed. Instead of using the name 'rmap' I now
get the name of the type of that element. The type name is not the same as the element name so subsequent attempts to
load the model fails.
In some sense, I can understand why this happens. After all, it's the name of the relationship from the document root to
the topmost element that was used so when I suppress that, how can the serializer know what name it should use? Is there
some way to tell the serializer what the topmost element should be named?
If anyone has encountered this before and know what's missing, please help.
Thomas Hallgren
Re: Suppressing document root but loosing name of top element. [message #489537 is a reply to message #489536] |
Sun, 04 October 2009 11:48   |
Thomas,
Did you also use OPTION_ELEMENT_HANDLER? ElementHandlerImpl will likely
produce the correct result.
Thomas Hallgren wrote:
> document using a relationship with the name 'rmap'. Everything works
> edit the model, save it, and edit again.
> added the load option OPTION_SUPPRESS_DOCUMENT_ROOT = true.
> displayed. Nice. The problem however, is that when I change something
> Instead of using the name 'rmap' I now get the name of the type of
> subsequent attempts to load the model fails.
> name of the relationship from the document root to the topmost element
> what name it should use? Is there some way to tell the serializer what
> help.
> Regards,
> Thomas Hallgren
Re: Suppressing document root but loosing name of top element. [message #489540 is a reply to message #489537] |
Sun, 04 October 2009 12:50   |
Hi Ed,
Thanks. That helped. Not sure why though. What does the ElementHandlerImpl do in this case? Why isn't that the default
behavior? The documentation doesn't go into much detail.
Thomas Hallgren
On 10/04/2009 05:48 PM, Ed Merks wrote:
> Thomas,
>> Hi,
>> help.
>> Regards,
>> Thomas Hallgren
Re: Suppressing document root but loosing name of top element. [message #489543 is a reply to message #489540] |
Sun, 04 October 2009 13:16  |
Thomas,
It helps find a global element in the document root and from the type of
that element, it knows the type of object to create for the root object.
> Hi Ed,
> Regards,
> Thomas Hallgren
>> Thomas,
>>> Hi,
>>> help.
>>> Regards,
>>> Thomas Hallgren
Current Time: Sun Jul 20 05:45:06 EDT 2025
Powered by FUDForum. Page generated in 0.05372 seconds
