Filter a model diagram? [message #489346] |
Fri, 02 October 2009 10:16  |
Originally posted by: formatzeh.gmx.de
I have a very big model diagram. Now I want to document it and need to
hide elements to show only concepts. Is it possible anyhow to put a
filter on my diagram or at least to create a new diagram into which I
can paste the desired concepts?
best regards,
Gilbert
Re: Filter a model diagram? [message #492412 is a reply to message #492400] |
Tue, 20 October 2009 07:25  |
I found out that when I add a new class to my meta model, save it and
remove it then drag and drop works again. But I don't know if it is an
always working workaround neither which causes this state.
Re: Filter a model diagram? [message #621412 is a reply to message #489346] |
Fri, 02 October 2009 10:33  |
Gilbert,
Yes, you can create any number of diagrams and you can delete things
from only the diagram without changing the model to produce filtered
diagrams.
> best regards,
> Gilbert
Re: Filter a model diagram? [message #621416 is a reply to message #489354] |
Sat, 03 October 2009 11:31  |
> diagrams.
I tried this and made the experience that my ecore file will be changed
when deleting elements. I do that with selecting elements I don't need
in my filtered diagram and then press delete. Is something wrong with
that procedure? Fortunately my project stands under version control and
I always can do a revert but that's not the best practice.
Re: Filter a model diagram? [message #621417 is a reply to message #489354] |
Sat, 03 October 2009 11:51  |
In this context I have also to ask if it is possible to do the other way
around. Imagine I deleted an association between two classes in the
diagram but the corresponding association still exists in the model. Can
I let the association re-appear in the diagram?
Re: Filter a model diagram? [message #621419 is a reply to message #489472] |
Sun, 04 October 2009 03:41  |
Gilbert,
You need to use Delete From Diagram, not Delete from Model. The
Navigate menu will help with restoring things, and you can drag and from
the outline.
Re: Filter a model diagram? [message #621421 is a reply to message #489502] |
Sun, 04 October 2009 04:45  |
Thanks Ed,
I thought that elements will be deleted from the diagram only when I
press the delete button on my keyboard. The fact with the outline is
interesting. It is new for me that I can use it for dragging and
dropping. But I tried to remove an composite association between two
classes in the diagram and after that drop it from the outline back into
the diagram. But there was no drop target in the diagram. How does it work?
Re: Filter a model diagram? [message #621422 is a reply to message #489505] |
Sun, 04 October 2009 07:31  |
I got it now. When an association was removed you have to remove a
associated class as well and drop it from the outline back into the
diagram. Then the association will be present again.
Re: Filter a model diagram? [message #621429 is a reply to message #489502] |
Tue, 06 October 2009 08:07  |
Under which condition isn't dragging and dropping from the outline
supported? I'm asking because it does not work now. I remove a class
from the diagram and want to drop it immediately back into it but the
diagram isn't active as drop target. Are there any conditions?
Re: Filter a model diagram? [message #621442 is a reply to message #489515] |
Wed, 07 October 2009 09:54  |
Gilbert,
You can also restore that link without having to remove and then restore
the EClass. Just use the "Navigate > Restore Related Elements" action
available from the contextual menu (see
http://wiki.eclipse.org/EcoreTools_New_Noteworthy#Improve_su pport_for_multi-model_diagrams
for more details). It will try to restore all incoming or outgoing
connections to the selected element.
Jacques
Re: Filter a model diagram? [message #621443 is a reply to message #489883] |
Wed, 07 October 2009 09:59  |
The only main restriction is about connections that could not be redrawn
by DND from the outline. Usually you should be able to DND an EClass
several times, as long a you are dropping on an EPackage element (the
diagram canvas is also considered as an EPackage element).
Can you open a bug against the Ecore Tools component in the EMFT project
: please, attach the erroneous model+diagram files and specify the
different steps.
Jacques
Re: Filter a model diagram? [message #621500 is a reply to message #490143] |
Tue, 20 October 2009 07:00  |
Hi Jacques,
I can't reproduce the error. The next day after my post it worked again.
Until today. Now I can't drag and drop any elements from the outline
into the canvas anymore :( Should I open a bug report anyway?
> different steps.
Re: Filter a model diagram? [message #621502 is a reply to message #492400] |
FUDForum. Page generated in 0.05077 seconds
