Home » Archived » MOFScript » [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths?
[MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #487886] Thu, 24 September 2009 13:00 Go to next message
I'm working with different projects and I usually define the
following directory structure.
Project
|----metamodel
|----model
|----transformations
The problem is that every time I want to change the project, I also
have to change the MofScript Preferences configuracion. I haven't found
any way of specifying different paths for different metamodels,
transformations, and so on. Is there any way to do this or to attach the
preferences to a concrete project?
Toñi
Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #489018 is a reply to message #487886] Thu, 01 October 2009 04:53 Go to previous messageGo to next message
Hello To
Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #489168 is a reply to message #489018] Thu, 01 October 2009 12:51 Go to previous messageGo to next message
But all the preferences, metamodel path, model path and transformation
path??
Gøran K. Olsen escribió:
> Hello Toñi,
> No there is not a way to do this. Normally I just set the preferences to the
> Workspace location.
> /Gøran
> "Toñi Reina Quintero" <reinaqu@lsi.us.es> wrote in message
> news:h9g8jg$dt$1@build.eclipse.org...
>> Hi,
>> I'm working with different projects and I usually define the following
>> Project
>> |----metamodel
>> |----model
>> |----transformations
>> Best regards,
>> Toñi
Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #490569 is a reply to message #489168] Fri, 09 October 2009 04:45 Go to previous message
I set the model and the transformation path to the workspace. The metamodel
path I set to a directory where I have collected the metamodels that are not
in the platform (or I use some plugin to load them manually e.g. ATL or
EPSILON).
This approach normally means that I will have to navigate 2-3 levels (the
first time i execute) depending on the structure of my project.
G
Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #580070 is a reply to message #487886] Thu, 01 October 2009 04:53 Go to previous message
Hello To
Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #580089 is a reply to message #489018] Thu, 01 October 2009 12:51 Go to previous message
path??
> Hello Toñi,
> Workspace location.
> /Gøran
>> Hi,
>> Project
>> |----metamodel
>> |----model
>> |----transformations
>> Best regards,
>> Toñi
Re: [MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths? [message #580105 is a reply to message #489168] Fri, 09 October 2009 04:45 Go to previous message
EPSILON).
G
Previous Topic:[MOFScript] Is there any way of configuring MOF Script to load metamodels from different paths?
Next Topic:MOFScript and UML State machines
Current Time: Sat Jul 19 21:12:32 EDT 2025
Powered by FUDForum. Page generated in 0.04946 seconds
