Home » Modeling » M2T (model-to-text transformation) » [XPAND] Output transformation to string
[XPAND] Output transformation to string [message #488990] Thu, 01 October 2009 02:57 Go to next message
I am very new to the modeling project in general. I am trying to transform a diagram made using GMF to text by using XPAND. I've been able to do so but I am only able to ouptut the result to an external file. This is the code I use (I've found it on the net):
	public void convertToText() {
		EObject model = getDiagram().getElement();
		// configure outlets
		OutputImpl output = new OutputImpl();
		Outlet outlet = new Outlet("myOutput.txt");
		outlet.setOverwrite(true);
		output.addOutlet(outlet);
		// create execution context
		Map globalVarsMap = new HashMap();
		XpandExecutionContextImpl execCtx = new XpandExecutionContextImpl(
				output, null, globalVarsMap, null, null);
		EmfRegistryMetaModel metamodel = new EmfRegistryMetaModel() {
			protected EPackage[] allPackages() {
				return new EPackage[] { SodaPackage.eINSTANCE,
						EcorePackage.eINSTANCE };
		execCtx.registerMetaModel(metamodel);
		// generate
		XpandFacade facade = XpandFacade.create(execCtx);
		String templatePath = "templates::Pattern2Text::Main";
		try {
			facade.evaluate(templatePath, model);
		} catch (EvaluationException ee) {
			ee.printStackTrace();
The code works fine and I have the correct text transformation in my file. But, instead of outputing the result to a file, I need to have it as a string that I can use in my program.
Of course, I can always open the file and read its content but it seems a bit overkill. Is there a way to get the result directly, without needing to go to a temporary file ?
Cédric
Re: [XPAND] Output transformation to string [message #489002 is a reply to message #488990] Thu, 01 October 2009 03:38 Go to previous message
Hi Cédric,
this question came up a few days ago in this newsgroup. Please have a
look at the thread "How to generate into a string instead of a file with
xpand?"
Sebastian
C schrieb:
> Hello,
> @Override
> // generate
> try {
> Thanks
> Cédric
Previous Topic:Extend - Debuging extend script when you invoke M2M from runtime eclipse workbench
Next Topic:M2T with Xpand
Current Time: Sat Jul 19 11:21:09 EDT 2025
Powered by FUDForum. Page generated in 0.03011 seconds
