Home » Eclipse Projects » Eclipse Platform » shift/control + click on tree views(Linux/GTK: Tree views collapse/expand on shift/control + click instead of selecting multiple items)
shift/control + click on tree views [message #488736] Tue, 29 September 2009 23:02 Go to next message
Hi!
In the latest release of Eclipse (3.5.1) every time I control-click or shift-click on a tree view I get this tree collapse or expand some of its nodes (usually the first one). The expected behavior is to select a range of items (with shift+click) or select/de-select an item (with control+click). I used to use Eclipse under windows before - this kind of things never happened there; under Linux/GTK I have experienced this behavior from time to time (it was quite annoying, but after a few clicks I was getting it to work). But after updating to SR1 it happens all the time, no matter how or where I click.
Is this an intended behavior or is it a bug and should it be reported?
Thanks!
Re: shift/control + click on tree views [message #488813 is a reply to message #488736] Wed, 30 September 2009 06:41 Go to previous messageGo to next message
Yuriy Malchenko wrote:
> Hi!
Are you sure you don't click twice on the node (this does
expand/collapse). Another cause could be a defective mouse. If that's
not the case then please file a bug report with steps to reproduce.
Dani
> Thanks!
Re: shift/control + click on tree views [message #488823 is a reply to message #488813] Wed, 30 September 2009 08:26 Go to previous messageGo to next message
I frequently see this behavior on Linux/GTK too (started maybe around
3.5.0 or around my latest Kubuntu upgrade, not sure).
I have no more details on how to reproduce than:
1. select on element in any tree view
2. ctrl-click or shift-click on any other element in the same tree
However, I have a workaround to avoid that annoying collapsing:
When you do ctrl-click first press ctrl, then move the mouse just
a little (while holding ctrl) and only then click.
Do you still see the collapsing with a little motion in between?
Stephan
Re: shift/control + click on tree views [message #488849 is a reply to message #488823] Wed, 30 September 2009 09:45 Go to previous messageGo to next message
It seems to show up when using GTK+ 2.14
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255126
Re: shift/control + click on tree views [message #488953 is a reply to message #488823] Wed, 30 September 2009 16:21 Go to previous message
Stephan Herrmann wrote on Wed, 30 September 2009 08:26
Actually no, if I move the mouse a little - it works. Thanks for this workaround!
Previous Topic:Concurrency help (modifying the workspace)
Next Topic:How To Determine Whether A Folder is Linked
Current Time: Sat Jul 19 15:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.03329 seconds
