Home » Modeling » EMF » [CDO] Possibilities and constraints of using CDO
[CDO] Possibilities and constraints of using CDO [message #488546] |
Tue, 29 September 2009 04:28  |
I'm trying to understand how the possibilities and constraints of using
CDO. The context of this is the toolkit model of e4, so a model in this
context corresponds to a (live) UI, possibly with a related data model.
It's my understanding that there's two ways to get a CDO-ready model:
you either use dynamic instances or generate CDO-supporting code using
an edited genmodel. (replacing the superclass of the interface and
implementation). Hence, if you want to support using the model in two
modes, one without CDO and one with, you must generate two versions, one
with and one without CDO-support? How should these to versions (naming,
package uri, ...) be handled to ensure the correct factory and/or
resource is used?
I'm considering the following scenario: I have a large model which
supports containment proxies, so a large EObject hierarchy can easily be
split into several resources, each containing a sub-tree. Now I want to
1) select a sub-tree, press a "Share..." button and prompt for a CDO
repository location
2) somehow copy that sub-tree into a CDO-managed resource in the
provided repository
3) replace the in-memory sub-tree by the CDO-managed resource and
4) send a link (CDO uri) to the person I want to share that resource
with. The other person will load that resource (without the surrounding
tree) and take part in a shared editing session.
Is it possible to support such a mode, where a sub-tree (resource) is
managed by CDO and the rest isn't? Would I instead have to share the
whole model, but still be able to split it into smaller resources, to
limit the scope of sharing (by not revealing the uri to the whole model)?
Hallvard
Re: [CDO] Possibilities and constraints of using CDO [message #488593 is a reply to message #488546] |
Tue, 29 September 2009 07:41   |
Hi Hallvard,
I'm currently not in the office, but below some brief comments...
Hallvard Trætteberg schrieb:
> using CDO. The context of this is the toolkit model of e4, so a model
> in this context corresponds to a (live) UI, possibly with a related
> data model.
Cool that e4 starts thinking about CDO. I'll have more time to assist
you later on.
> implementation).
We'll have a third option available soon: legacy model support. But some
of CDO's advanced functions and characteristics will not be available
with "normal" Ecore models.
> Hence, if you want to support using the model in two modes, one
> without CDO and one with, you must generate two versions, one with and
> one without CDO-support? How should these to versions (naming, package
> uri, ...) be handled to ensure the correct factory and/or resource is
> used?
You can also use the CDO'ified version of the model without CDO.
> be split into several resources, each containing a sub-tree. Now I
> want to
> repository location
> provided repository
That should be easy. Even external cross references are supported by CDO.
Maybe this can work with containment proxies, but I never tried it. Can
you test it?
> surrounding tree) and take part in a shared editing session.
Perfectly possible. But keep in mind, that the CDO URI format references
a repository only by its well-known repo UUID! In other words the URI
does not specify *how* to connect to this repository. Usually
application code is necessary to open the needed CDOSession and
CDOTransaction. There are advanced approaches that use e.g. the
extension registry. Do you need more info on this?
Containment proxies are the only possibility that pops into my mind.
> Would I instead have to share the whole model, but still be able to
> split it into smaller resources, to limit the scope of sharing (by not
Cross references could easily interfere with this policy! But CDO does
support arbitrary partitioning of the object graph in a repository into
multiple Resources.
Hope that helps for now ;-)
Cheers
/Eike
Re: [CDO] Possibilities and constraints of using CDO [message #488683 is a reply to message #488593] |
Tue, 29 September 2009 13:50   |
>> data model.
> you later on.
I hope to make some progress in the coming weeks. Cloud computing, here
we come!
That'll be great!
Yes, but then you still reference CDO classes and require CDO plugins?
Wouldn't it be possible to use some class loading tricks (AOP) to set
the correct interface and superclass, so you can delay the choice?
>> repository location
>> provided repository
> you test it?
I'm not sure how this is done in practice, perhaps Ed has a recipe? What
happens if we just take the root object of a resource and add it to a
container that supports proxies, but in a different resource.
Yes, I think you answered this question in a different thread. I think I
recall seeing a discussion about a different CDO URI format with
connection-oriented information. Isn't one of the problems that the URI
doesn't reference an input source, i.e. something for which you can
return an InputStream? Hence, the URI must be handled earlier in the
process of resolving it?
I'll perhaps have more specific questions later.
Hallvard
Re: [CDO] Possibilities and constraints of using CDO [message #488764 is a reply to message #488683] |
Wed, 30 September 2009 04:09   |
Hallvard,
Comments below.
>>> model in this context corresponds to a (live) UI, possibly with a
>>> related data model.
>> you later on.
> here we come!
> That'll be great!
Perhaps https://bugs.eclipse.org/bugs/show_bug.cgi?id=256706 will help
with that. We also expect to look into a CDO-enabled version of Ecore
itself, to fully enable a CDO-enabled version of UML which extends Ecore
and uses Ecore for Profiles.
>>> repository location
>>> provided repository
>> CDO.
>> Can you test it?
> What happens if we just take the root object of a resource and add it
> to a container that supports proxies, but in a different resource.
If a containment reference has resolveProxies true (you have to enable
generation of that) then any object in that reference can also be
directly contained by a different resource so this should "just work."
>> references a repository only by its well-known repo UUID! In other
>> words the URI does not specify *how* to connect to this repository.
> I recall seeing a discussion about a different CDO URI format with
> URI doesn't reference an input source, i.e. something for which you
> can return an InputStream? Hence, the URI must be handled earlier in
> the process of resolving it?
I always wondered if the streams could be used to communicate the
connection information...
>> There are advanced approaches that use e.g. the extension registry.
> Hallvard
Re: [CDO] Possibilities and constraints of using CDO [message #488787 is a reply to message #488683] |
Wed, 30 September 2009 04:51   |
Yes, these:
org.eclipse.emf.cdo
org.eclipse.emf.cdo.common
org.eclipse.net4j.util
Before 2.0 we've had such an approach, our CDOWeaver. But i found this
too fragile because it heavily relied on internals of EMF classes and
user model classes. Vik told me that his company also had BCE based
approach that worked well. I cc'ed him.
You're right, the main "problem" is that we agreed on a URI format for
resources that is agnostic to the way a repository is technically
*reached*. This is mainly because this way may be different on other
machines. Maybe we can introduce additional URI formats for resources
that are URIConverter'ed to the primary format after extracting
connection infos...
Cheers
/Eike
Re: [CDO] Possibilities and constraints of using CDO [message #488809 is a reply to message #488764] |
Wed, 30 September 2009 06:16   |
>>> Can you test it?
I tried it and it did just work! The only thing that wasn't as expected
was the serialization. The sub-tree that moved to a new resource,
included a reference to its container in the XMI:
<tm.widgets:Label xmi:version="2.0" text="Password:">
<composite xsi:type="tm.widgets:Composite" href="login.tm#/"/>
Normally, the container is implicitly the XML parent, but when the child
was the root object of an XMI resource, the reference to the parent in a
different resource was included. This must be handled if the sub-tree is
supposed to be loaded without the rest of the tree.
Would it make sense (and work) to make the container reference (the
opposite of the containment reference) transient?
You mean that the stream doesn't contain the actual resource, but
information about how to load the actual resource from the repository. I
guess the important thing is that the resource is populated with the
desired objects after loading from the stream.
Hallvard
Re: [CDO] Possibilities and constraints of using CDO [message #488839 is a reply to message #488809] |
Wed, 30 September 2009 09:15   |
Hallvard,
Comments below.
>>>> Can you test it?
>>> it to a container that supports proxies, but in a different resource.
>> enable generation of that) then any object in that reference can also
>> be directly contained by a different resource so this should "just
>> work."
Can't say I'm surprised. :-P
> The only thing that wasn't as expected was the serialization. The
> sub-tree that moved to a new resource, included a reference to its
> child was the root object of an XMI resource, the reference to the
> parent in a different resource was included. This must be handled if
> the sub-tree is supposed to be loaded without the rest of the tree.
It's generally important for cross document references to be serialized
at both ends, so the Ecore validator might complain...
>>> think I recall seeing a discussion about a different CDO URI format
>>> with connection-oriented information. Isn't one of the problems that
>>> the URI doesn't reference an input source, i.e. something for which
>>> you can return an InputStream? Hence, the URI must be handled
>>> earlier in the process of resolving it?
That was my suggestion, yes.
> I guess the important thing is that the resource is populated with the
Exactly.
> Hallvard
Re: [CDO] Possibilities and constraints of using CDO [message #488873 is a reply to message #488846] |
Wed, 30 September 2009 10:55   |
--------------050801030401020608050804
Eike,
Comments below.
>>>>> that the URI doesn't reference an input source, i.e. something for
>>>>> which you can return an InputStream? Hence, the URI must be handled
> Ok, putting the needed connection info into the resource URI and let
> "something" in CDO analyze that and create (re-use?) the CDOSession and
> the CDOView/Transaction is not too trivial since there are various ways
> to create such a connection. But in the end URIs are made for this, or
> was it URLs??
I wasn't suggesting to encode it in the URI itself but rather to encode
it in the bytes of the stream
> I wonder how/where we convert these connection-aware URIs to the
> normal(ized) ones. In the URIConverter?
Yes. In a URIHandler actually.
> would we have to cache the
> stripped information somewhere to be able to re-use the existing
> transaction for new resources instead of opening new transactions over
> and over again (which would not work since CDO has a restriction of a
> single view per resource set / repository!)...
It's just a vague idea, but yes, the opening of streams would just
transmit in the bytes of the stream the information for accessing the
appropriate shared transaction.
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Eike,<br>
<br>
Comments below.<br>
<br>
Eike Stepper wrote:
<blockquote cite="mid:h9vmfq$5na$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks schrieb:
</pre>
<blockquote type="cite">
<pre wrap="">Yes, I think you answered this question in a different thread. I
</pre>
</blockquote>
<pre wrap="">I always wondered if the streams could be used to communicate the
</pre>
</blockquote>
<pre wrap="">You mean that the stream doesn't contain the actual resource, but
</pre>
</blockquote>
<pre wrap="">That was my suggestion, yes.
</pre>
</blockquote>
<pre wrap=""><!---->Ok, putting the needed connection info into the resource URI and let
was it URLs??
</pre>
</blockquote>
it in the bytes of the stream<br>
<pre wrap="">
normal(ized) ones. In the URIConverter?</pre>
</blockquote>
Yes. In a URIHandler actually.<br>
<pre wrap=""> would we have to cache the
</pre>
</blockquote>
appropriate shared transaction.<br>
<pre wrap="">
Cheers
/Eike
<a class="moz-txt-link-freetext" href="http://thegordian.blogspot.com">http://thegordian.blogspot.com</a>
<a class="moz-txt-link-freetext" href="http://twitter.com/eikestepper">http://twitter.com/eikestepper</a>
</pre>
</blockquote>
</body>
</html>
--------------050801030401020608050804--
Re: [CDO] Possibilities and constraints of using CDO [message #489065 is a reply to message #488787] |
Thu, 01 October 2009 08:15   |
Guys,
comments below
What I successfully did was to substitute the bytecode of one class on
runtime, using ASM. Basically I contributed my own classloader, which
would look for an specific class to be loaded, then intercepts the call
and returns specially crafted bytecode.
ASM provides a great Eclipse View which provides you the sequence of ASM
ops to create certain piece of code. You only have to select the
modified code (for instance, EObjectImpl) and the view will show
automatically the ASM op sequence.
Then, from the custom classloader, you only have to call the static
method that contains all the sequence of ASM operations to obtain the
modified bytecode and return it to the default classloader.
Not sure if this is the best solution, but it works, at least.
If you need more info on this, don't hesitate pinging me.
> connection infos...
I love this idea. I've been struggling in maintaining in our products a
CDO URI translator facade, as we needed URIs meaninful to end users. I
think the URIConverter approach perfectly fit this requirement.
Should we raise a zilla?
ViK.
Re: [CDO] Possibilities and constraints of using CDO [message #489087 is a reply to message #489065] |
Thu, 01 October 2009 09:18   |
Hi Vik,
Please file a bugzilla for the URIConverter thing. And maybe we should
discuss your ASM approach some time via Skype...
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> Guys,
> comments below
> call and returns specially crafted bytecode.
> ASM ops to create certain piece of code. You only have to select the
> > connection infos...
> a CDO URI translator facade, as we needed URIs meaninful to end users.
> I think the URIConverter approach perfectly fit this requirement.
> Cheers,
> ViK.
Re: [CDO] Possibilities and constraints of using CDO [message #490084 is a reply to message #489087] |
Wed, 07 October 2009 05:38  |
Bug 291574 - Provide connection-aware URI format through
URIConverter/URIHandler
https://bugs.eclipse.org/bugs/show_bug.cgi?id=291574
Víctor.
Eike Stepper escribió:
> Hi Vik,
> Cheers
> /Eike
>> Guys,
>> comments below
>>> connection infos...
>> Cheers,
>> ViK.
Current Time: Sat Jul 19 10:47:02 EDT 2025
Powered by FUDForum. Page generated in 0.05370 seconds
