Home » Eclipse Projects » Eclipse Platform » Unicode - General OS question
Unicode - General OS question [message #487841] Thu, 24 September 2009 10:37 Go to next message
Hi there,
The RCP application we are building will use a great deal of unicode, Armenian alphabets and what have you.
As a test, I attempted to paste the character "♀" in a SWT Text field in an instance of our application running on my Windows machine (didn't work) and then on the Mac machine of a colleague (success). I can paste it successfully in Word, Firefox, etc. on my Windows.
Note that this has (as yet) nothing to do with using unicode in a file being edited - hence, the VM arguments "-Dfile.encoding=UTF-8 -Dsun.jnu.encoding=UTF-8" unsurprisingly have no effect.
What am I missing here? What determines whether an instance of an RCP application - above all its SWT Controls - can handle unicode?
Many thanks in advance,
Pepe Ciardelli
Re: Unicode - General OS question [message #487852 is a reply to message #487841] Thu, 24 September 2009 11:07 Go to previous messageGo to next message
Pepe Ciardelli wrote:
> Hi there,
> (didn't work)
Make sure that the font you use contains that character.
Dani
> Pepe Ciardelli
Re: Unicode - General OS question [message #487867 is a reply to message #487852] Thu, 24 September 2009 11:32 Go to previous messageGo to next message
Aha, indeed! Thanks very much.
The obvious followup question then: is there a way to change the default text for all controls from the default system font to something unicode-compliant in one fell swoop?
Re: Unicode - General OS question [message #487890 is a reply to message #487867] Thu, 24 September 2009 13:37 Go to previous messageGo to next message
Just wanted to share what I found:
SWT controls set their font with Display#getSystemFont() and there's no way to set a different default font for all controls. Therefore, the appearance settings on Windows machines that don't have a unicode-compliant system font must be changed.
The first step is to make sure that a unicode-compliant font is installed on the user's Windows system. This explains how: http://unicode.org/help/display_problems.html.
Then do the following:
1. Right-click on desktop
2. Choose "Properties"
3. Appearance -> Advanced (this is where you want to be: http://delltech.150m.com/XP/desktop/desktop.advanced.png)
4. Item: "Message Box"
5. Font: Arial Unicode MS
After settings are updated, unicode will be visible in Eclipse applications.
Re: Unicode - General OS question [message #487962 is a reply to message #487890] Fri, 25 September 2009 01:52 Go to previous messageGo to next message
Or you change your default OS font. SWT will pick that up.
Dani
> applications.
Re: Unicode - General OS question [message #1780678 is a reply to message #487841] Thu, 25 January 2018 11:31 Go to previous message
Try to add the line:
to your eclipse.ini file and reboot the Eclipse.
Previous Topic:No more handles [gtk_init_check() failed]
Next Topic:newbie questions: Navigator and projects
Current Time: Sun Jul 20 10:44:45 EDT 2025
Powered by FUDForum. Page generated in 0.04133 seconds
