Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Is it possible to persist hybrid model using Teneo?
Is it possible to persist hybrid model using Teneo? [message #487842] Thu, 24 September 2009 10:37 Go to next message
Originally posted by: lifesting.gmail.com
For example, A normal Java Class is defined as below:
Public class MyStore{
Book book;
Assume that Book is an EMF class, which is referenced by the JavaBean
class MyStore, how to save them all by Teneo?
Thanks a lot!
Re: Is it possible to persist hybrid model using Teneo? [message #487925 is a reply to message #487842] Thu, 24 September 2009 16:32 Go to previous messageGo to next message
Hi David,
This should work but you have to extend the HbSessionDataStore/HbEntityDataStore class, override the mapModel method and
add your own classes/mapping files to the configuration. Something like this:
protected void mapModel() {
super.mapModel();
// and then add your own classes/mapping by getting the Configuration object
// by calling getHibernateConfiguration/getConfiguration
Btw, I think this is an interesting case to support so feel free to post any obstacles you encounter, then I can solve them.
Are you using hibernate annotations or hbm.xml for your non-EMF classes?
Last thing, support for Teneo is given on the main emf newsgroup which I added as cc.
gr. Martin
> Book book;
> Thanks a lot!
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Is it possible to persist hybrid model using Teneo? [message #488279 is a reply to message #487925] Sun, 27 September 2009 07:49 Go to previous messageGo to next message
Martin Taal wrote:
> Hi David,
> and add your own classes/mapping files to the configuration. Something
> like this:
> super.mapModel();
> added as cc.
> gr. Martin
>> Book book;
>> Thanks a lot!
Marten, so thanks for your reply! In general, I use hbm.xml as mapping
configuration, but I think that using hibernate annotations is more
suitable if the non-EMF classes is generated by Tool/Compiler.
What are the differences between annotations and *.hbm.xml files in Teneo?
Regards!
Re: Is it possible to persist hybrid model using Teneo? [message #488292 is a reply to message #488279] Sun, 27 September 2009 14:16 Go to previous message
Hi David,
Teneo works with JPA annotations in the model and not in the generated code. Internally Teneo translates the annotations
to a hbm which is passed on to Hibernate.
I am not sure if you want to combine non-EMF code (with JPA code) with EMF code which uses Teneo. If so: the key is that
for Teneo/EMF you have to use the HbSessionDataStore/HbEntityDataStore which means that you have to use the
SessionFactory/EntityManagerFactory created by these classes. I think that you can add the JPA annotated classes to the
Configuration object (see the getConfiguration() methods in the DataStore classes). So then you can use one
EntityManager for both Teneo and the non-EMF classes.
gr. Martin
> Martin Taal wrote:
>> Hi David,
>> method and add your own classes/mapping files to the configuration.
>> super.mapModel();
>> I added as cc.
>> gr. Martin
>>> Book book;
>>> Thanks a lot!
> Regards!
The Netherlands
Re: Is it possible to persist hybrid model using Teneo? [message #621394 is a reply to message #487842] Thu, 24 September 2009 16:32 Go to previous message
Hi David,
super.mapModel();
gr. Martin
> Book book;
> Thanks a lot!
The Netherlands
Re: Is it possible to persist hybrid model using Teneo? [message #621405 is a reply to message #487925] Sun, 27 September 2009 07:49 Go to previous message
Martin Taal wrote:
> Hi David,
> like this:
> super.mapModel();
> added as cc.
> gr. Martin
>> Book book;
>> Thanks a lot!
Regards!
Re: Is it possible to persist hybrid model using Teneo? [message #621406 is a reply to message #488279] Sun, 27 September 2009 14:16 Go to previous message
Hi David,
gr. Martin
> Martin Taal wrote:
>> Hi David,
>> super.mapModel();
>> I added as cc.
>> gr. Martin
>>> Book book;
>>> Thanks a lot!
> Regards!
The Netherlands
Previous Topic:Generated editor and XSD syntax
Next Topic:[MWE] I cannot use my own extension for workflow files?
Current Time: Sat Jul 19 08:32:58 EDT 2025
Powered by FUDForum. Page generated in 0.03602 seconds
