How to use CopyCommand [message #487798] |
Thu, 24 September 2009 09:00  |
already searched the mailing list, the book and the internet but found
nothing appropriate to teach me how to use CopyCommand.
As naiv as I am I started with
CopyCommand.create(final EditingDomain domain, final Collection collection)
and immediately wondered where the destination of the copy operation
would have to go. Started anyway and got a
UnsupportedOperationException.
I probably need to flesh out some details of the copy operation but have
no idea how to go about that or what's the best practice here.
What's going to make the task even more complicated is the fact that the
copying is supposed to copy a tree of objects (the "Queries" tree) over
from one resource to another resource. The "Queries" tree contains
references to some other part (called "Schema") of the model instance
which will not be copied to the destination instance. However the
destination instance contains its own "Schema" part and the references
from the copied "Queries" tree need to be recreated by some algorithm.
A picture may make it clearer:
before the copying:
Source instance
|________
Queries Schema
/#1\ -->/#1\
^-- references
Destination instance
|________
Queries Schema
(empty) /\
/#2\
after the copying:
Source instance
|________
Queries Schema
/#1\ -->/#1\
^-- references
|________
Queries Schema
/#1\ -->/#2\
^-- recreated references
The whole copy operation should be undoable and the two resources be
independent from each other, i.e. not in the same ResourceSet.
Any pointers on how to deal with the CopyCommand in general and in our
special case would be very much appreciated.
Thanks and Regards,
Dirk
Re: How to use CopyCommand [message #488028 is a reply to message #487798] |
Fri, 25 September 2009 07:55   |
Some additions to the previous post:
1. The cause of the UnsupportedOperationException was the collection
passed to the create method being empty.
2. It came to my mind that it would be nice for the users being able to
use copy&paste as an additional means to perform the copy operation.
That would mean using the clipboard as the operartion spans two distinct
resources. The generated editor apparently doesn't provide that out of
the box. Could someone please provide some hints about how to achieve that?
3. The copy&paste idea brought me a bit further regarding the general
use of the CopyCommand (at least I believe so):
Looking at the code of the PasteFromClipboardCommand I found that
CopyCommand needs to be combined with AddCommand by putting them into a
CompoundCommand. I did it like so:
---- 8< -----------------
StrictCompoundCommand copyAndAddCommand =
new StrictCompoundCommand("Import Queries");
final Command copyCommand = CopyCommand.create(_editingDomain, queries);
copyAndAddCommand.appendAndExecute(copyCommand);
copyAndAddCommand.appendAndExecute(new CommandWrapper() {
protected Command createCommand() {
EReference feature =
SbqPackage.Literals.QUERIES__HOUSE_NQUERIES;
Command addCommand = AddCommand.create(_editingDomain,
_dstQueries, feature, copyCommand.getResult());
return addCommand;
CommandStack commandStack = _editingDomain.getCommandStack();
commandStack.execute(copyAndAddCommand);
---- >8 -----------------
This does a deep copy letting copied references point back into the
source model instance. So what I still have to implement is some method
to recreate the references so they point to the corresponding objects in
the destination instance, and of course the copy&paste thingy.
Thanks and Regards,
Dirk
Dirk Hoffmann schrieb:
> before the copying:
> Source instance
> |________
> Queries Schema
> /#1\ -->/#1\
> ^-- references
> |________
> Queries Schema
> (empty) /\
> /#2\
> after the copying:
> Source instance
> |________
> Queries Schema
> /#1\ -->/#1\
> ^-- references
> |________
> Queries Schema
> /#1\ -->/#2\
> Thanks and Regards,
> Dirk
Re: How to use CopyCommand [message #488048 is a reply to message #488028] |
Fri, 25 September 2009 08:35  |
Dirk,
Comments below.
> that?
You could override the AdapterFactoryEditingDomain.setClipboard to do
more than just cache the collection locally in the editing domain instance.
> a CompoundCommand. I did it like so:
> @Override
> return addCommand;
> method to recreate the references so they point to the corresponding
> objects in the destination instance, and of course the copy&paste thingy.
If you look closely at how the CopyCommand itself is factored, you'll
see CreateCopyCommand and InitializeCopyCommand are involved for the
individual parts of the deep structure, so you could focus on
specializing these. Note that the Helper is used for remapping, do
likely you can use that to redirect the references.
> Thanks and Regards,
> Dirk
>> Hi,
>> found nothing appropriate to teach me how to use CopyCommand.
>> collection)
>> have no idea how to go about that or what's the best practice here.
>> the copying is supposed to copy a tree of objects (the "Queries"
>> tree) over from one resource to another resource. The "Queries" tree
>> contains references to some other part (called "Schema") of the model
>> instance which will not be copied to the destination instance.
>> However the destination instance contains its own "Schema" part and
>> the references from the copied "Queries" tree need to be recreated by
>> some algorithm.
>> before the copying:
>> Source instance
>> |________
>> Queries Schema
>> /#1\ -->/#1\
>> ^-- references
>> |________
>> Queries Schema
>> (empty) /\
>> /#2\
>> after the copying:
>> Source instance
>> |________
>> Queries Schema
>> /#1\ -->/#1\
>> ^-- references
>> |________
>> Queries Schema
>> /#1\ -->/#2\
>> our special case would be very much appreciated.
>> Thanks and Regards,
>> Dirk
FUDForum. Page generated in 0.05759 seconds
