Home » Eclipse Projects » Remote Application Platform (RAP) » User UICallBack Problem
User UICallBack Problem [message #487693] Thu, 24 September 2009 03:40 Go to next message
Hi All,
My RAP application uses UICallBack Mechanism to asynchronously update
the browser UI from a server thread.Because I need to use this
UICallBack mechanism in different places in my application,so I add some
code in IEntryPoint's createUI method:
final String codeId=String.valueOf(display.hashCode());
RWT.getSessionStore().addSessionStoreListener(new SessionStoreListener() {
public void beforeDestroy(SessionStoreEvent event) {
UICallBack.activate(codeId);
// release resources
But I find that the beforeDestroy method never be called at the session
invalidated,and the UIThread Object didn't destroy.I can find there are
many UIThread in the JVM by the jconsole tool.
But if I remove the UICallBack.activate(codeId); line code,the
beforeDestroy method would be call and the UIThread object would be
destroyed.
I also add the code in the org.eclipse.rap.demo's createUI method,the
result is the same.
By the way,I use lRAP1.2RC4.
is it a bug in UICallBack mechanism,how can i fix the problem?
Theanks
Cheney
Re: User UICallBack Problem [message #487840 is a reply to message #487693] Thu, 24 September 2009 10:34 Go to previous messageGo to next message
Cheney,
I can reproduce what you describe. It may be related to this bug:
214464: [UICallback] Unable to close equinox if activated
https://bugs.eclipse.org/bugs/show_bug.cgi?id=214464
However, I can only reproduce the problem in Jetty (version 6.1.x,
others I don't know). In Tomcat a session is invalidated regardless
whether a UICallback is active or not.
Are you using Jetty for your production system?
Rüdiger
Cheney wrote:
> Hi All,
> destroyed.
> result is the same.
> Theanks
> Cheney
Re: User UICallBack Problem [message #487952 is a reply to message #487840] Thu, 24 September 2009 22:39 Go to previous messageGo to next message
Hi Rüdiger,
Thanks for your reply.
Yes,I use Jetty 6.1.5 for my application.
Because I know that deploy the RAP application and enable equinox osgi
console on tomcat/linux, it would flood the tomcat logs with "osgi>"
prompts(I don't test the last release tomcat, if you know the problem is
fixed in the last release, please tell me, and i also try to test it).
Thanks for your help again! I will try to deploy my rap application in
tomcat container.
Best Regards,
Cheney
Rüdiger Herrmann wrote:
> Cheney,
> Cheers,
> Rüdiger
> Cheney wrote:
>> Hi All,
>> some code in IEntryPoint's createUI method:
>> session invalidated,and the UIThread Object didn't destroy.I can find
>> there are many UIThread in the JVM by the jconsole tool.
>> But if I remove the UICallBack.activates(codeId); line code,the
>> destroyed.
>> result is the same.
>> Theanks
>> Cheney
Re: User UICallBack Problem [message #487969 is a reply to message #487952] Fri, 25 September 2009 02:41 Go to previous messageGo to next message
I think this issue is solved since Eclipse 3.4. At least, I haven't had
any problems with -console since that version.
Stefan.
Re: User UICallBack Problem [message #488217 is a reply to message #487969] Fri, 25 September 2009 21:45 Go to previous message
Hi Stefan,
Yes,this issue is solved,I have tested my application (use rap1.2RC4
target platform) in tomcat yestaday.
Best Regards,
Cheney
>> is fixed in the last release, please tell me, and i also try to test it).
> Regards,
> Stefan.
Previous Topic:Composite#computeSize produces faults between 5 and 10 percent. Bug?
Next Topic:Performance issue
Current Time: Sat Jul 19 10:09:28 EDT 2025
Powered by FUDForum. Page generated in 0.04117 seconds
