Home » Modeling » EMF » overload add operation in EMF generated editor
overload add operation in EMF generated editor [message #485994] Tue, 15 September 2009 16:33 Go to next message
Hello
I'm in need of overloading add operation in my generated EMF editor. I
have pretty standard code generated from an ECore model. Without
modifications.
Generaly. I'd like to do some things upon the addition on objects to my
model. I traced the whole "add" process to AddCommand class and am
wondering if it is ok, to overload it. And if yes, how should I do it
correctly.
The same thinkg I'd like to do with other commands, like Delete, or Copy.
So I'm especially looking for more generic solutions.
Thanks in advance for any answers.
Marcin
Re: overload add operation in EMF generated editor [message #486002 is a reply to message #485994] Tue, 15 September 2009 16:58 Go to previous messageGo to next message
Marcin,
Comments.
Marcin Cylke wrote:
> Hello
> modifications.
> my model. I traced the whole "add" process to AddCommand class and am
> correctly.
Yes. Just create a compound command that does the add and the other
stuff too.
> Copy. So I'm especially looking for more generic solutions.
Item providers act like a factory for commands so specializing those
commands to do additional things is fine.
> Marcin
Re: overload add operation in EMF generated editor [message #486865 is a reply to message #486002] Sun, 20 September 2009 06:52 Go to previous messageGo to next message
Hello
I'm having quite a problem with this thing.
I've added an ovveride of createAddCommand to my ObjectItemProvider. It executes, I can place a breakepoint in it, but with each addition to a model it executes n-times, where n is the current size of collection I'm adding it to. I don't understand this behavior.
I'd like to interact with the object that I'm currently adding, not with all the others. What am I doing wrong?
I also tried creating a command extension, but don't know how to use it in a generated emf editor to interact with generated model.
Help appreciated.
Marcin
Re: overload add operation in EMF generated editor [message #486872 is a reply to message #486865] Sun, 20 September 2009 10:09 Go to previous messageGo to next message
Marcin,
Comments below.
Marcin Cylke wrote:
> Hello
You mean createAddCommand itself or the command that's created?
I'm not even sure what you're describing. Surely the debugger will
answer this faster than I can. Look closely at all the arguments to the
call, or all the fields of the command being executed to understand what
they're doing...
I'm not sure what this means.
> Help appreciated.
> Marcin
Re: overload add operation in EMF generated editor [message #486894 is a reply to message #486872] Sun, 20 September 2009 15:10 Go to previous messageGo to next message
Well, I've managed to fix my problems with that. I misinterpreted You first reply, did some errors by myself. But eventually more debugging of the EMF behavior helped.
However I have some other problem. I have a generated model. I have a collection of objectA in it. Now, I have to put an instance of PXModel into my EMF model, so that I can govern its objects from other places.
I'd like to have collection from innerModel synchronized with types from Model. That is why I'd like to return that collection when types == null. Like this:
public EList<ObjectA> getTypes() {
		if (types == null) {
			types = innerModel.getCollection();
		return types;
But doing this way my model isn't updated - lacks behavior of EObjectContainmentEList. Is there a way of "casting" EList to EObjectContainmentEList. Or maybe there is some other solution?
I've tried to use eInverseAdd - but that doesn't work for me.
Well, it may look ugly, but seems like the fastest solution to my problem.
Here is the concept of the situation:
class Model {
   private PXModel innerModel;
   protected EList<ObjectA> types;
			types = new EObjectContainmentEList<ObjectA>(ObjectA.class, this,
					ModelPackage.PX_MODEL__TYPES);
		return types;
and
class PXModel {
   protected EList<ObjectA> collection;
   public EList<ObjectA> getCollection() {
      return collection;
Re: overload add operation in EMF generated editor [message #486975 is a reply to message #486894] Mon, 21 September 2009 07:16 Go to previous messageGo to next message
Marcin,
Comments below.
Marcin Cylke wrote:
> Hi
I'm not sure I follow what you're saying...
> == null. Like this:
> return types;
Is this list supposed to be a read only view or can it be modified.
It sounds more like you should attach an adapter to the inner model and
as the feature changes, make corresponding changes here.
> problem.
> class Model {
> types = new
> return types;
> and
> class PXModel {
> return collection;
Re: overload add operation in EMF generated editor [message #487339 is a reply to message #486975] Tue, 22 September 2009 15:32 Go to previous messageGo to next message
Ed Merks wrote on Mon, 21 September 2009 07:16
Marcin,
This is supposed to be a modifiable list.
Well, incorporating changes to the embeded object through adapter - or anything else, as you've described, would surely suffice. But how can I notice when the change on the collection occures? Since there is only a getter for it I don't know how should I find out about its contents change.
Marcin
Re: overload add operation in EMF generated editor [message #487453 is a reply to message #487339] Wed, 23 September 2009 06:10 Go to previous message
Marcin,
Comments below.
>> Marcin,
>> > But doing this way my model isn't updated - lacks behavior of >
>> EObjectContainmentEList. Is this list supposed to be a read only view
>> maybe > there is some other solution?
>> and as the feature changes, make corresponding changes here.
So the adapting/shadowing of changes needs to be in both directions?
> contents change.
All features notify of changes, not just single valued features. In the
case of multi-valued features, any change to the list produces
notifications, e.g., ADD, REMOVE, and SET.
> Marcin
Previous Topic:XSD to XMI?
Next Topic:"Link" attribute in a model
Current Time: Sun Jul 20 08:32:29 EDT 2025
Powered by FUDForum. Page generated in 0.05074 seconds
