Home » Modeling » EMF » [CDO] [DB] Optimization ([CDO] [DB] Optimization )
[CDO] [DB] Optimization [message #486835] Sat, 19 September 2009 13:45 Go to next message
I'm starting to use DB and I found that the following is VERY VERY SLOW
If I'm adding 20000 thousand at the end of a list...I look at the code and it will do the following for each entry.
NonAuditListTableMapping
move1up(accessor, id, index, UNBOUNDED_MOVE);
insertValue(accessor, id, index, value);
move1up is EXTREMELY slow to run....
My Question... when we add at the end of the list... why
need to be executed for ALL elements ???
(I'm using H2)
Re: [CDO] [DB] Optimization [message #486836 is a reply to message #486835] Sat, 19 September 2009 13:57 Go to previous messageGo to next message
I did a test to see if it was really the problem by adding a lookup if the previous size in bigger then the new one...
private void move1up(IDBStoreAccessor accessor, CDOID id, int index, int upperIndex)
PreparedStatement stmt = null;
CDORevision readRevision = accessor.getStore().getRepository().getRevisionManager().get Revision(id, -1);
int size = readRevision.data().size(getFeature());
if (size > index)
...NORMAL CODE
and now it is 10000 times faster.
it need probably to be smarter than that... but still !
So this is a problem in there !! Smile
Re: [CDO] [DB] Optimization [message #486874 is a reply to message #486836] Sun, 20 September 2009 10:56 Go to previous messageGo to next message
Hi Simon,
That really sounds like something we should optimize. Can you file a
bugzilla against DBStore?
Cheers
/Eike
> int upperIndex)
> Revision(id, -1);
> if (size > index)
> ...NORMAL CODE
> So this is a problem in there !! :)
Re: [CDO] [DB] Optimization [message #486955 is a reply to message #486836] Mon, 21 September 2009 05:51 Go to previous messageGo to next message
Hi Simon,
nice one. I was aware of the problem, but I did not know about a way to
get hold of the revision and -- hence -- the size of the list to
implement the condition.
With your way, I can even simplify the whole thing, because if I know
the size of the list, I don't need to make a difference between move1up
w/ or w/o upper bound.
Stefan
> int upperIndex)
> Revision(id, -1);
> if (size > index)
> ...NORMAL CODE
Re: [CDO] [DB] Optimization [message #486957 is a reply to message #486955] Mon, 21 September 2009 06:01 Go to previous messageGo to next message
Guys,
Do we have a bugzilla for this?
Cheers
/Eike
Stefan Winkler schrieb:
> Hi Simon,
> Cheers,
> Stefan
>> int upperIndex)
>> Revision(id, -1);
>> if (size > index)
>> ...NORMAL CODE
Re: [CDO] [DB] Optimization [message #486964 is a reply to message #486957] Mon, 21 September 2009 06:48 Go to previous message
Bugzilla created
https://bugs.eclipse.org/bugs/show_bug.cgi?id=289985
Previous Topic:Ecore2Ecore data migration when reference's type is removed
Next Topic:[CDO] Timeout while getting worker Thread?!
Current Time: Sun Jul 20 04:18:11 EDT 2025
Powered by FUDForum. Page generated in 0.04503 seconds
