[CDO] [DB] Optimization [message #486835] |
Sat, 19 September 2009 13:45  |
I'm starting to use DB and I found that the following is VERY VERY SLOW
If I'm adding 20000 thousand at the end of a list...I look at the code and it will do the following for each entry.
NonAuditListTableMapping
move1up(accessor, id, index, UNBOUNDED_MOVE);
insertValue(accessor, id, index, value);
move1up is EXTREMELY slow to run....
My Question... when we add at the end of the list... why
need to be executed for ALL elements ???
(I'm using H2)
Re: [CDO] [DB] Optimization [message #486955 is a reply to message #486836] |
Mon, 21 September 2009 05:51   |
Hi Simon,
nice one. I was aware of the problem, but I did not know about a way to
get hold of the revision and -- hence -- the size of the list to
implement the condition.
With your way, I can even simplify the whole thing, because if I know
the size of the list, I don't need to make a difference between move1up
w/ or w/o upper bound.
Stefan
Simon Mc Duff schrieb:
> I did a test to see if it was really the problem by adding a lookup if
> the previous size in bigger then the new one...
> private void move1up(IDBStoreAccessor accessor, CDOID id, int index,
> int upperIndex)
> PreparedStatement stmt = null;
> CDORevision readRevision =
> accessor.getStore().getRepository().getRevisionManager().get
> Revision(id, -1);
> int size = readRevision.data().size(getFeature());
> if (size > index)
> ...NORMAL CODE
> and now it is 10000 times faster.
> it need probably to be smarter than that... but still !
> So this is a problem in there !! :)
Re: [CDO] [DB] Optimization [message #486957 is a reply to message #486955] |
Mon, 21 September 2009 06:01   |
Guys,
Do we have a bugzilla for this?
Cheers
/Eike
Stefan Winkler schrieb:
> Hi Simon,
> Cheers,
> Stefan
>> int upperIndex)
>> Revision(id, -1);
>> if (size > index)
>> ...NORMAL CODE
FUDForum. Page generated in 0.04386 seconds
