Home » Eclipse Projects » Eclipse Platform » Failed To Load HTML From Bundle Using Browser
Failed To Load HTML From Bundle Using Browser [message #486486] Thu, 17 September 2009 15:52 Go to next message
Originally posted by: runzhou.li.gmail.com
I'm doing something like below to open up html pages from the plugin bundle
using browser:
Bundle bundle = WidgetPlugin.getDefault().getBundle();
IPath path = new Path( "/test/index.html" );
URL url = FileLocator.find( bundle, path, null );
IWorkbenchBrowserSupport support =
PlatformUI.getWorkbench().getBrowserSupport();
try {
url = FileLocator.toFileURL( url );
IWebBrowser browser = support.createBrowser(
IWorkbenchBrowserSupport.AS_EDITOR, "testPage", null, null );
browser.openURL( url );
} catch( PartInitException e ) {
} catch( IOException e ) {
which works fine in dev environment, however in actual build, when I looked
into ./configuration/org.eclipse.osgi/bundles/xxx/1/test, there is only one
index.html while there are supposed to be other resources like js, css and
images.
So it appears to be very weird ugly page opened up in the actual build,
while in dev environment it works perfectly.
Please help, thank you in advance.
Runzhou Li
Re: Failed To Load HTML From Bundle Using Browser [message #486548 is a reply to message #486486] Fri, 18 September 2009 03:32 Go to previous messageGo to next message
> looked into ./configuration/org.eclipse.osgi/bundles/xxx/1/test, there
> is only one index.html while there are supposed to be other resources
> like js, css and images.
Check the other resources in your build.properties. They might not have
been included.
- Prakash
Platform UI Team, IBM
http://blog.eclipse-tips.com
Re: Failed To Load HTML From Bundle Using Browser [message #486563 is a reply to message #486486] Fri, 18 September 2009 04:54 Go to previous messageGo to next message
Are you deploying your plugin as a Jar? In that case,
FileLocator.toFileURL will actually extract the indicated file from the
JAR file, but of course it won't know about any other related files.
Running your plugin from source (in what I assume is what you call the
'environment') doesn't have this issue, because the plugin is always
'deployed' as a folder and FileLocator.toFileURL just uses the files
that are there and does not do any copying.
I've had a few annoying experiences with this inconsistent behaviour in
the past, too, but have yet to find a completely satisfactory solution.
Steffen
Runzhou Li wrote:
> bundle using browser:
> try {
> build, while in dev environment it works perfectly.
> Runzhou Li
Re: Failed To Load HTML From Bundle Using Browser [message #486734 is a reply to message #486563] Fri, 18 September 2009 16:30 Go to previous messageGo to next message
Yes Steffen. Your understanding to this issue has given me an okay
workaround.
The workaround is basically pass in another path
IPath path2 = new Path( "/test" );
And make that an url
URL url2 = FileLocator.find( bundle, path, null );
And then use toFileUrl(url2) just to extract the contents out, but not
really using it programmatically.
Hope some one can tell me there is a method that does just what I needed,
instead of this workaround that doesn't make perfect logical sense :)
"Steffen Zschaler" <szschaler@acm.org> 写入消息
news:h8vhre$pfi$1@build.eclipse.org...
> Cheers,
> Steffen
> Runzhou Li wrote:
>> Hi,
>> try {
>> Runzhou Li
Re: Failed To Load HTML From Bundle Using Browser [message #486741 is a reply to message #486734] Fri, 18 September 2009 16:46 Go to previous messageGo to next message
Glad you found a way to make this work. Actually, this does sound quite
sensible, as you are effectively asking FileLocator to extract the
complete directory. I wasn't aware it would do that, so thanks for
allowing me to learn something, too.
Steffen
> workaround.
> needed, instead of this workaround that doesn't make perfect logical
> sense :)
>> Hi,
>> Cheers,
>> Steffen
>> Runzhou Li wrote:
>>> Hi,
>>> try {
>>> Runzhou Li
Re: Failed To Load HTML From Bundle Using Browser [message #486742 is a reply to message #486741] Fri, 18 September 2009 17:05 Go to previous message
All about open source community helps ;p
Thank you and you're welcome.
news:h90rk3$750$1@build.eclipse.org...
> Steffen
>> workaround.
>> sense :)
>>> Hi,
>>> Cheers,
>>> Steffen
>>> Runzhou Li wrote:
>>>> Hi,
>>>> try {
>>>> Runzhou Li
Previous Topic:java debug - breakpoint
Next Topic:Plugin to share icons and strings
Current Time: Sun Jul 20 10:03:40 EDT 2025
Powered by FUDForum. Page generated in 0.24257 seconds
