Home » Modeling » M2T (model-to-text transformation) » How include objects into new set
How include objects into new set [message #486635] Fri, 18 September 2009 09:33 Go to next message
Dears,
Sorry for the previuose message.please consider it as a canceled one.
I want to create empty set then add specific objects to it.
I used the code below but I has some errors.
any help is highly appreciated.
Omran
[let ss:Set(ViewColumn)= Set{}]////error1 Invalid Type:Set(ViewColumn)
[for (vc:ViewColumn|mv.columns) ]
[if (vc.oclIsTypeOf(ViewExpColumn))]
[let vec : ViewExpColumn = vc.oclAsType(ViewExpColumn)]
[if not (vec.expression.trim().toUpper().startsWith('SUM(') or
vec.expression.trim().toUpper().startsWith('AVG(') or
vec.expression.trim().toUpper().startsWith('MIN(')or
vec.expression.trim().toUpper().startsWith('MAX') or
vec.expression.trim().toUpper().startsWith('COUNT('))]
[ss->including(vec.oclAsType(ViewColumn))/]///error2 Cannot find
operation (including(ViewColumn)) for the type (Set())
[/if]
[/let]
[/if]
[if (vc.oclIsTypeOf(SimpleViewColumn))]
[ss->including(vc.oclAsType(ViewColumn))/]//error3 Cannot find operation
[/if]
[/for];
[for (vc:ViewColumn|ss) separator(',')]///error4 The 'no null' constraint
is violated
[vc.name/]
[/for]
[/let]
Re: How include objects into new set [message #486670 is a reply to message #486635] Fri, 18 September 2009 10:57 Go to previous message
--------------010309010409090307010104
Omran,
First of all, please add the [Acceleo] prefix when asking questions
about Acceleo on this newsgroup, this will save some trouble to everyone
sorting the posts ;).
"Set(ViewColumn)" was not considered an "OclType" and thus couldn't be
used for variable definitions in Acceleo in previous versions of Acceleo
(or OCL, don't remember how we fixed this) you need to update to the
most recent 0.9 Acceleo builds to fix this (and update to Eclipse 3.5 if
this doesn't do the trick). This should solve all four errors.
Laurent Goubet
Obeo
Omran a
Previous Topic:Check/Xtend: Regular Expression syntax
Next Topic:The xpand/xtend editors do not work for me!
Current Time: Sun Jul 20 07:07:23 EDT 2025
Powered by FUDForum. Page generated in 0.03341 seconds
