Home » Modeling » Epsilon » [EuGENia] unable to create some elements(unable to create basic EuGENia elements in particular conditions sush as inheritances and number of iterations)
[EuGENia] unable to create some elements [message #486603] Fri, 18 September 2009 07:20 Go to next message
Hello
I have some trouble creating basic elements that I think are in the scope of elements processed by EuGENia.
The first one is a gmf.link (for EClass), the problem is
the class that is used to create the link inherits from an
abstract class that has no source or target, as I have found
that abstract elements should also have a representation for
EuGENia to function properly, I believe the problem lies in
ether this being really necessary with the impossibility of creating a link with foo="bar"
Abstract
|---NodeA - gmf.link( source="sourceA", target="targetA")
|      |---sourceA
|      |---targetA
|---NodeB - gmf.link( source="sourceB", target="targetB")
       |---sourceB
       |---targetB
The second problem is containments are not created by EuGENia, after its forth level. I have :
canvas
  ->container
        ->container
              ->container
                    ->container (this is no longer created in any file as container, but their contained nodes are in Graph and Tool)
                          ->node.
If there are any ways to get over these limitation I could use the help. Thank you.
Vasco
Re: [EuGENia] unable to create some elements [message #486604 is a reply to message #486603] Fri, 18 September 2009 07:25 Go to previous messageGo to next message
Hi Vasco,
Could you please post your .emf metamodel and indicate the specific
classes that are causing the problems?
Dimitris
Vasco Sousa wrote:
> Hello
> link with foo="bar"
> Abstract
> | |---sourceA
> | |---targetA
> |---sourceB
> |---targetB
> canvas
> ->container
> ->container
> ->container
> ->node.
> Thank you.
> Vasco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: [EuGENia] unable to create some elements [message #487325 is a reply to message #486604] Tue, 22 September 2009 14:48 Go to previous messageGo to next message
sorry for the delay I had to ask for permition as the metamodel is not mine,
here is the section in question, were I am unable to
create the containment in ApplyClass, but it creates the ApplyAttribute node in GMFGraph and GMFTool,
and unable to generate a link from ApplyAssociation.
thank you for the reply
Vasco
Re: [EuGENia] unable to create some elements [message #487597 is a reply to message #487325] Wed, 23 September 2009 12:42 Go to previous messageGo to next message
Hi Vasco,
Could you please also attach the metamodel you refer to so that I can
have a look?
Dimitris
> mine,
> here is the section in question, were I am unable to create the
> Vasco
Re: [EuGENia] unable to create some elements [message #487637 is a reply to message #487597] Wed, 23 September 2009 16:32 Go to previous messageGo to next message
couln't upload in any brouser so I'll post it here
@gmf(foo="bar")
@namespace(uri="http://metamodel/1.0", prefix="metamodel")
package metamodel;
@gmf.diagram(foo="bar")
class TransformationModel {
  val AbstractSource[*] source;
@gmf.node(foo="bar")
abstract class Layer extends AbstractSource {
  attr String description;
  @gmf.link(source.decoration="arrow")
  ref AbstractSource[+] previousSource;
  attr String outputFilePathURI;
  @gmf.compartment(layout ="free")
  val Rule[*] hasRule;
@gmf.node(label="className")
class ApplyClass extends AbstractClass {
  @gmf.containment(layout="free")
  val ApplyAttribute[*] attribute;
@gmf.node( color="255,255,163")
class ApplyModel {
  val ApplyClass[*] ~class;
  val ApplyAssociation[*] association;
//@gmf.link(source="source", target="target")
class ApplyAssociation extends Association {
  ref ApplyClass[1] source;
  ref ApplyClass[1] target;
abstract class AbstractClass {
  attr String className;
  attr String packageName;
//@gmf.link(source="", target="")
abstract class Association {
  attr String associationName;
@gmf.node(label="attributeName")
class ApplyAttribute {
  attr String[1] description;
  attr String attributeName;
abstract class AbstractSource {
@gmf.node(label="description")
class Rule {
  @gmf.compartment(layout ="list")
  val ApplyModel[1] apply;
@gmf.node(label="description", color="0,0,255")
class Sequential extends Layer {
PS:aditionaly today while showing the basic example of the EuGENia] page, I get a
Internal error: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EEnumLiteralImpl cannot be cast to org.eclipse.gmf.gmfgraph.LineKind
error and no links are generated, not shure if it has to do with my link problem
Re: [EuGENia] unable to create some elements [message #487645 is a reply to message #487637] Wed, 23 September 2009 17:22 Go to previous messageGo to next message
Hi Vasco,
The problem stems from the fact that you need to have one compartment
under ApplyModel that can hold the contents of both the ~class and
association containment references. This is not currently supported by
EuGENia but I'll have a look and see if this can be fixed with a custom
polishing EOL script
( http://epsilonblog.wordpress.com/2009/06/15/eugenia-polishin g-your-gmf-editor/).
Re the other issue, could it be the case that you have updated EuGENia
but not the rest of Epsilon?
Dimitris
> @gmf(foo="bar")
> package metamodel;
> class ApplyModel {
> class Rule {
> page, I get a Internal error: java.lang.ClassCastException:
> org.eclipse.gmf.gmfgraph.LineKind error and no links are generated, not
Re: [EuGENia] unable to create some elements [message #487646 is a reply to message #487645] Wed, 23 September 2009 17:49 Go to previous messageGo to next message
Hi Vasco,
On an update to this, I think I've figured out how to support such cases
in EuGENia. The new version will most likely be available mid-next week.
Dimitris
Dimitris Kolovos wrote:
> Hi Vasco,
> Cheers,
> Dimitris
>> @gmf(foo="bar")
>> package metamodel;
>> class ApplyModel {
>> class Rule {
Re: [EuGENia] unable to create some elements [message #487753 is a reply to message #487646] Thu, 24 September 2009 06:33 Go to previous messageGo to next message
Hi Vasco,
A new interim version that fixes this has just been made available. I've
slightly modified the metamodel, mainly to add a label to ApplyModel as
labels are mandatory for nodes. The modified version appears below.
Could you please update to the latest *interim* version of
Epsilon/EuGENia and let me know how it goes?
--- metamodel.emf ---
@gmf(foo="bar")
package metamodel;
@gmf.node(label="name", color="255,255,163")
class ApplyModel {
attr String name; // Added - all nodes must have a label
class Rule {
Dimitris
> Hi Vasco,
> Cheers,
> Dimitris
>> Hi Vasco,
>> custom polishing EOL script
>> Cheers,
>> Dimitris
>>> @gmf(foo="bar")
>>> package metamodel;
>>> class ApplyModel {
>>> class Rule {
Re: [EuGENia] unable to create some elements [message #487781 is a reply to message #487753] Thu, 24 September 2009 08:15 Go to previous messageGo to next message
I tried the metamodel you have provided and updated the Epsilon plugin to the latest *intermin*
I no longer have the error with the filesystem example
but in this metamodel the issues still apply, he doesn't create a
mapping for the ApplyAttribute nor the representation of the ApplyAttribute containment in ApplyClass on the Graph model
the apply association is still absent from the mapping file
(do I realy need to define a compartment for the link in
class ApplyModel {
I suspect that in the same manner I need to define nodes for the abstract classes for the flowing classes to be properly generated, the same would happen with the links, but the abstract class to the ApplyAssociation doesn't have the mandatory source and target.
PS: as for the mandatory label in nodes I usualy let EuGENia generate the mapping, and then stroll down the file deleting the label mappings the I don't need, or would give error messages, and it runs fine
Re: [EuGENia] unable to create some elements [message #487799 is a reply to message #487781] Thu, 24 September 2009 09:05 Go to previous messageGo to next message
Hi Vasco,
Please replace @gmf.containment(layout="free") with
@gmf.compartment(layout="free") in line 25 of the .emf to get this working.
> class ApplyModel {
None of these should be necessary. I'll check again and get back to you.
I'll have a look at this and see if we can make labels optional in EuGENia.
Re: [EuGENia] unable to create some elements [message #488363 is a reply to message #487799] Mon, 28 September 2009 08:33 Go to previous messageGo to next message
Hi Dimitrios
Thank you for spotting that error with the compartment, for some reason I couldn't spot it.
Anyhow all compartments are working within expected.
Vasco
Re: [EuGENia] unable to create some elements [message #488378 is a reply to message #488363] Mon, 28 September 2009 09:35 Go to previous messageGo to next message
Hi Vasco,
Thanks for the update. Could you perhaps add an enhancement request for
this "optional labels" feature in the bugzilla so that we can keep track
of this?
Dimitris
Vasco Sousa wrote:
> Hi Dimitrios
> I couldn't spot it.
> Cheers,
> Vasco
Re: [EuGENia] unable to create some elements [message #489347 is a reply to message #488378] Fri, 02 October 2009 10:20 Go to previous messageGo to next message
I am sorry
I'm still preaty green with this
don't seem to find the right place to report
the feature request, I stil get lost in bugzilla
any news on not needing to map
the abstract classes ?
Cheers
Vasco
Re: [EuGENia] unable to create some elements [message #489387 is a reply to message #489347] Fri, 02 October 2009 14:14 Go to previous message
Hi Vasco,
Vasco Sousa wrote:
> I am sorry
To submit the feature request, please follow the "Report new bug" link
in the Epsilon homepage (http://eclipse.org/gmt/epsilon/)
If you remove @gmf.compartment from the following it should really work
If not, could you please send me a minimal example that reproduces this
because I'm not yet convinced I understand the problem completely.
> Cheers
> Vasco
Dimtiris
Re: [EuGENia] unable to create some elements [message #580906 is a reply to message #486604] Tue, 22 September 2009 14:48 Go to previous message
Vasco
Re: [EuGENia] unable to create some elements [message #580925 is a reply to message #487325] Wed, 23 September 2009 12:42 Go to previous message
Hi Vasco,
have a look?
Dimitris
> mine,
> Vasco
Re: [EuGENia] unable to create some elements [message #580944 is a reply to message #487597] Wed, 23 September 2009 16:32 Go to previous message
@gmf(foo="bar")
package metamodel;
class ApplyModel {
class Rule {
PS:aditionaly today while showing the basic example of the EuGENia] page, I get a Internal error: java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EEnumLiteralImpl cannot be cast to org.eclipse.gmf.gmfgraph.LineKind error and no links are generated, not shure if it has to do with my link problem
Re: [EuGENia] unable to create some elements [message #580952 is a reply to message #580944] Wed, 23 September 2009 17:22 Go to previous message
Hi Vasco,
Dimitris
> @gmf(foo="bar")
> package metamodel;
> class ApplyModel {
> class Rule {
Re: [EuGENia] unable to create some elements [message #580967 is a reply to message #487645] Wed, 23 September 2009 17:49 Go to previous message
Hi Vasco,
Dimitris
> Hi Vasco,
> Cheers,
> Dimitris
>> @gmf(foo="bar")
>> package metamodel;
>> class ApplyModel {
>> class Rule {
Re: [EuGENia] unable to create some elements [message #580984 is a reply to message #487646] Thu, 24 September 2009 06:33 Go to previous message
Hi Vasco,
@gmf(foo="bar")
package metamodel;
class ApplyModel {
class Rule {
Dimitris
> Hi Vasco,
> Cheers,
> Dimitris
>> Hi Vasco,
>> Cheers,
>> Dimitris
>>> @gmf(foo="bar")
>>> package metamodel;
>>> class ApplyModel {
>>> class Rule {
Re: [EuGENia] unable to create some elements [message #581001 is a reply to message #487753] Thu, 24 September 2009 08:15 Go to previous message
(do I realy need to define a compartment for the link in @gmf.node(label="name", color="255,255,163")
class ApplyModel {
Re: [EuGENia] unable to create some elements [message #581015 is a reply to message #487781] Thu, 24 September 2009 09:05 Go to previous message
Hi Vasco,
> class ApplyModel {
Re: [EuGENia] unable to create some elements [message #581034 is a reply to message #487799] Mon, 28 September 2009 08:33 Go to previous message
Hi Dimitrios
Vasco
Re: [EuGENia] unable to create some elements [message #581048 is a reply to message #488363] Mon, 28 September 2009 09:35 Go to previous message
Hi Vasco,
of this?
Dimitris
Vasco Sousa wrote:
> Hi Dimitrios
> I couldn't spot it.
> Cheers,
> Vasco
Re: [EuGENia] unable to create some elements [message #581288 is a reply to message #488378] Fri, 02 October 2009 10:20 Go to previous message
I am sorry
Cheers
Vasco
Re: [EuGENia] unable to create some elements [message #581305 is a reply to message #581288] Fri, 02 October 2009 14:14 Go to previous message
Hi Vasco,
Vasco Sousa wrote:
> I am sorry
> Cheers
> Vasco
Dimtiris
Previous Topic:ETL: creation of arbitrary number of target traceable elements
Next Topic:Nested Operations by importing EOL Files - using Java
Current Time: Sun Jul 20 02:24:39 EDT 2025
Powered by FUDForum. Page generated in 0.32165 seconds
