Home » Modeling » GMF (Graphical Modeling Framework) » Update the properties of a link when he is created
Update the properties of a link when he is created [message #486509] Thu, 17 September 2009 17:35 Go to next message
hi
I also have a problem with the class the following link:
@gmf.link(source="from",target="to")
abstract class Link extends PropertyHolderElement, TypedElement {
attr LinkNavigability navigability;
ref ConnectableElement[1] from;
ref ConnectableElement[1] to;
ref Component fromContext;
ref Component toContext;
I wish that I automatically are assigned the values of the 4 elements
from, to, fromContext, toContext.
for example if I create a component A with a connectable element B and
another element component C with a connectable element D.
If I create a link between A and C I want to have in the properties links
the following values:
from = b
to = c
fromContext = A
toContext = B
I adds a another source and target of the link?
Is there a way to solve this problem?
thank you very much
marco
Re: Update the properties of a link when he is created [message #486590 is a reply to message #486509] Fri, 18 September 2009 06:40 Go to previous messageGo to next message
Hello marco,
Try using feature sequence initializers for corresponding link mapping in
..gmfmap model. This should help you to initialize from/to references (it's
possible to properly configure link mapping to sed fromContext/toContext).
Then you can try solving a problems with link rerouting.
In case you canot implement corresponding functionality using ocl in feature
sequence initializer then you can modify generated code.
Alex Shatalin
Re: Update the properties of a link when he is created [message #486664 is a reply to message #486590] Fri, 18 September 2009 10:36 Go to previous messageGo to next message
I have already set up the link to / from
I wish I could add in the property value is also in the fields fromContext
and toContext just creates the link
Where can I see an example of the use of OCL?
thanks
marco
Re: Update the properties of a link when he is created [message #486897 is a reply to message #486664] Sun, 20 September 2009 16:13 Go to previous messageGo to next message
Hello marco,
you need to create feature sequence initializer initializing fromContext
reference in a way like: self.from.context
where "context" is a reference from "from" element to "fromContext" one...
Alex Shatalin
Re: Update the properties of a link when he is created [message #488347 is a reply to message #486897] Mon, 28 September 2009 07:09 Go to previous messageGo to next message
alex you please give me an example of what I create?
are not very experienced and I have not understood what I wanted to tell me.
I create a new file? if so, where?
Where can I study these things?
if you send my metamodel can indicate the changes that I should do?
thanks marco
Re: Update the properties of a link when he is created [message #488368 is a reply to message #488347] Mon, 28 September 2009 09:00 Go to previous messageGo to next message
Please give me an example of what I create?
In general you open your "???.gmfmap" file. Select the node (mapping) you want to initialize. Right click and insert an feature sequence initializer.
Examples can be found at http://wiki.eclipse.org/GMF_Tutorial_Part_2#Feature_Initiali zers
For more informations about OCL and some example code see http://wiki.eclipse.org/MDT-OCL#Examples.
sas
Re: Update the properties of a link when he is created [message #489171 is a reply to message #488368] Thu, 01 October 2009 13:08 Go to previous messageGo to next message
hi
i have create the feature sequence initializer....
feature sequence initializer<SAbinding(fromContext,toContext)>
reference new element spec <fromContenxt:= new Compoennt[1]>
feature sequence initializer<new SAcomponent(name)>
reference new element spec <name:= new EString[0]>
reference new element spec <toContenxt:= new Compoennt[1]>
I got this:
fromContext: SAcomponent
toContext: SAcomponent
there was no element name but only the type of item.
for example having a SAcomponent A and B SAcomponent I should get
fromContext: SAcomponent A
toContext: SAcomponent B
i send you two image of my implementation?
I tried to attach pictures here but I failed.
you leave your email?
thanks marco
Re: Update the properties of a link when he is created [message #489556 is a reply to message #489171] Sun, 04 October 2009 17:21 Go to previous message
marco wrote on Thu, 01 October 2009 13:08
hi
I got this:
thanks marco
Previous Topic:Connection between compartments
Next Topic:Problem wiht abstract class in the diagram
Current Time: Sun Jul 20 08:45:01 EDT 2025
Powered by FUDForum. Page generated in 0.25375 seconds
