Home » Archived » M2M (model-to-model transformation) » [ATL] result of undefined subSequence call
[ATL] result of undefined subSequence call [message #485701] Mon, 14 September 2009 10:32 Go to next message
Originally posted by: loic.fejoz.realtimeatwork.com
I got the following error:
Operation not found: [].notEmpty()
After investigation it is due to the call of notEmpty over the result of
subSequence(2, sizeOfSequence) with sizeOfSequence being strictly less
than 2.
My question is: what is the kind of this object []?
I would have expected the result to be either oclUndefined or the empty
sequence Sequence{}! Before calling notEmpty I checked for oclUndefiness
so it must be something.
Moreover looking at the code of ASMSequence, it seems that the result is
an ASMSequence anyway. So where is the bug?
< http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2m/org .eclipse.m2m.atl/plugins/org.eclipse.m2m.atl.engine.vm/src/o rg/eclipse/m2m/atl/engine/vm/nativelib/ASMSequence.java?revi sion=1.5&root=Modeling_Project&view=markup>
regards,
Loïc Fejoz
Re: [ATL] result of undefined subSequence call on EMF virtual machine [message #485703 is a reply to message #485701] Mon, 14 September 2009 10:44 Go to previous messageGo to next message
Oh by the way, I am using the EMF virtual machine!
Running with the regular machine does not throw an error but seem to
still result with error...
PS: the code was maybe not the one to look at...
regards,
Loïc Fejoz
Loïc Fejoz a écrit :
> than 2.
Re: [ATL] result of undefined subSequence call on EMF virtual machine [message #485712 is a reply to message #485703] Mon, 14 September 2009 11:20 Go to previous messageGo to next message
--------------050006010100090500040306
There seems to be a miss in the return type of subSequence(start, end)
when end < start. Could you report a bug about that ?
(https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2M)
Thanks in advance,
William
Lo
Re: [ATL] result of undefined subSequence call on EMF virtual machine [message #485799 is a reply to message #485712] Tue, 15 September 2009 02:40 Go to previous message
I opened bug #289416.
I look at the UML 2.0 OCL Specification (in the semantic part), it
should be oclUndefined. In MDT/OCL, they choose to return null (see bug
#244946 [2] and the discussion [3]).
Anyway both virtual machine are not consistent...
[1] <https://bugs.eclipse.org/bugs/show_bug.cgi?id=289416>
[2] <https://bugs.eclipse.org/bugs/show_bug.cgi?id=244946>
[3]
< http://dev.eclipse.org/newslists/news.eclipse.modeling.mdt.o cl/msg01451.html>
Loïc
William Piers a écrit :
> Hello,
> Thanks in advance,
> William
Previous Topic:Using a matched rule from a lazy rule
Next Topic:[QVTO] Help on "SimpleUML to RDB" example
Current Time: Sat Jul 19 22:30:17 EDT 2025
Powered by FUDForum. Page generated in 0.04424 seconds
