Home » Modeling » M2T (model-to-text transformation) » Invoking Expand generator from Java
Invoking Expand generator from Java [message #484710] Tue, 08 September 2009 16:17 Go to next message
As I develop a generator with Xtext, I'm curious about options to reduce
the resource requirements. One thing that seems expensive in my scenario
is initializing the workflow for each model file. My project has several
thousand model files, so it looks like significant time may go into
initializing the MWE workflow.
Since I'm running the process from a Java application that is already
invoking the parser directly (through XtextResourceSet), I wonder if there
is a reasonable API to invoke the Xpand without starting an MWE Workflow.
What I'm not clear on is how I may provide the the instance with the model
instance that will drive template expansion. I see
org.eclipse.xpand2.XpandFacade, but its JavaDoc is bare and searches don't
yield any apparently useful references.
Thanks for you advice!
John
Re: Invoking Expand generator from Java [message #485227 is a reply to message #484710] Thu, 10 September 2009 16:37 Go to previous message
Hi John,
you're on the right track :-)
The XpandFacade can be used like this:
// create an execution context
XpandExecutionContextImpl execCtx = new
XpandExecutionContextImpl(output, null);
execCtx.setFileEncoding("iso-8859-1"); //$NON-NLS-1$
execCtx.registerMetaModel(new JavaBeansMetaModel());
// create a facade
XpandFacade facade = XpandFacade.create(execCtx);
// invoke a template definition
facade.evaluate("foo:bar::MyTemplate::definition", myObject);
Hope that helps.
Sven
> scenario is initializing the workflow for each model file. My project
> has several thousand model files, so it looks like significant time may
> go into initializing the MWE workflow.
> there is a reasonable API to invoke the Xpand without starting an MWE
> Workflow. What I'm not clear on is how I may provide the the instance
> with the model instance that will drive template expansion. I see
> don't yield any apparently useful references.
> John
Previous Topic:[XPAND] 50 % slowdown compared to OAW XPAND
Next Topic:[Acceleo] Downcasting issue again
Current Time: Sat Jul 19 10:40:49 EDT 2025
Powered by FUDForum. Page generated in 0.03434 seconds
