Home » Eclipse Projects » SWTBot » Using global variables(Using global variables)
Using global variables [message #484015] Thu, 03 September 2009 17:26 Go to next message
I'm new to community forums and SWTBot. I am a QA Analyst using this tool to create test scripts for Eclipse plug-ins that communicate with a mainframe. I set a global variable to an initial at the beginning of my test, change the value, and then base actions on this value. It appears as though the adjustment is not being propagated when the exception occurs. The statements under the IF are still being executed.
public class RecallDataset {
private static SWTWorkbenchBot bot;
String migrated = "Yes";
@Test
public void DatasetRecall() throws Exception {
try {
statements
catch (Exception e) {
Migrated = "No";
} // end of DatasetRecall
@Test
public void BrowseDataset() throws Exception {
if (migrated.equals("Yes")) {
statements, etc.
} // end of BrowseDataset
How do I pass values between public methods?
MK
Re: Using global variables [message #484044 is a reply to message #484015] Fri, 04 September 2009 00:13 Go to previous messageGo to next message
The problem here is that each of the tests use a different instance of
the RecallDataset class, if you'd like to share the same variable
instance across tests, you'd want to use either (a) static member
variables or (b) set the variable in a setup[1] or teardown method.
On a side note though, having tests coupled to each other is probably a
bad idea and may have weird repercussions when one of the tests failures
may cause other tests to fail. You may possibly want to look at the
junit faq[1] on how you could possibly decouple tests from the setup and
teardown.
[1] - http://junit.sourceforge.net/doc/faq/faq.htm#organize_3
Ketan
http://studios.thoughtworks.com/twist | http://twitter.com/ketanpkr
> @Test
> try {
> statements
> Migrated = "No";
> @Test
> statements, etc.
> MK
Re: Using global variables [message #485153 is a reply to message #484044] Thu, 10 September 2009 12:00 Go to previous message
Thanks Ketan. I went with redefining my global variable as static and the adjusted value was picked up just fine. I don't really understand yet how to put in Setups and Teardowns.
I don't know Java nor have a client/server background so figuring out even the simplest syntax has been difficult at times. Is there any chance someone is working on a "quick reference" or Help for SWTBot? The tip pop-ups have been helpful, but when you don't even know what the command does or how/where to use it makes things tedious. I do searches on this site, but the comments rarely include implicit syntax I can study.
Michelle
Previous Topic:Blank screen while running SWTBot tests
Next Topic:SWTBotText.typeText(final String text) is not working when you lock computer
Current Time: Sat Jul 19 14:17:17 EDT 2025
Powered by FUDForum. Page generated in 0.03636 seconds
