Home » Eclipse Projects » Rich Client Platform (RCP) » ComboBox Editor toolbar contribution Problems
ComboBox Editor toolbar contribution Problems [message #483810] Thu, 03 September 2009 03:25 Go to next message
I have an RCP application that uses an editor in the standard sort of way.
I have a EditorActionBarContributor which provides a number of specific
actions for the editor. Now I have added a Combo to the Toolbar as
follows.
_aircraftSelectionContribution = new ControlContribution("aicraft-combo") {
protected Control createControl(Composite parent) {
Combo combo = new Combo(parent, SWT.DROP_DOWN);
HierarchicalConfiguration aircraftConfig =
FGFPApplication.getInstance().getAircraftConfig();
List aircraftList =
aircraftConfig.getList("aircrafts.aircraft[@name]");
for (Iterator iterator = aircraftList.iterator(); iterator.hasNext();)
String name = (String) iterator.next();
combo.add(name);
return combo;
toolBarManager.add(_aircraftSelectionContribution);
This works, but the control seems shared across all instances of the
editor. What I want is for the selection in the combo to be related to
each editor instance but I cannot see how I can do this.
Re: ComboBox Editor toolbar contribution Problems [message #484684 is a reply to message #483810] Tue, 08 September 2009 13:59 Go to previous messageGo to next message
You would have to write code to determine which editor you are dealing with. i.e. EditorActionBarContributors have a setActiveEditor(*) method ... you would update your control/list in that method (that would be a place to start).
PW
Re: ComboBox Editor toolbar contribution Prob lems [message #486290 is a reply to message #484684] Thu, 17 September 2009 03:49 Go to previous message
Thanks for the tip. In setActiveEditor I have been able to add code to
get the required value from the active editor and set the selection on the
combo box. I have one remaining problem however.
I am not able to set the selection when the first Editor appears, as the
Control is not actually available at the time the setActiveEditor() is
called at the when the editor first opens. A new editor is fine, as long
as it isn't the first. That is the createControl(Composite parent) of my
ControlContribution gets called after setActiveEditor(). I tried adding
extra code in the createControl(Composite parent) but that also raised
"Widget disposed too early!" exception.
Previous Topic:listening to resource changes caused by team synchronization
Next Topic:Content outline context menu
Current Time: Sun Jul 20 12:03:13 EDT 2025
Powered by FUDForum. Page generated in 0.03828 seconds
