Home » Eclipse Projects » Rich Client Platform (RCP) » General Question about Handlers & Commands
General Question about Handlers & Commands [message #484494] Mon, 07 September 2009 14:25 Go to next message
I can set state to a command using the State object, but what is the exact
same paradigm for a handler? In other words how to I set set State or
something similiar to a handler. The handler parameters will not work for
me because they only support strings.
thanks.
Re: General Question about Handlers & Commands [message #484523 is a reply to message #484494] Tue, 08 September 2009 01:40 Go to previous messageGo to next message
I'm not sure if that is your question but you can use your own
AbstractSourceProvider for example to enable your commands.
This is described here:
http://www.vogella.de/articles/EclipseCommands/article.html# commmands_sourceprovider
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
> exact same paradigm for a handler? In other words how to I set set State
> or something similiar to a handler. The handler parameters will not work
> for me because they only support strings.
> thanks.
Re: General Question about Handlers & Commands [message #485205 is a reply to message #484523] Thu, 10 September 2009 15:24 Go to previous messageGo to next message
thanks, very interesting article.
Re: General Question about Handlers & Commands [message #485365 is a reply to message #484494] Fri, 11 September 2009 09:53 Go to previous message
Once you inform the command that it has a state object, you can easily get access to the state by subclassing org.eclipse.core.commands.AbstractHandlerWithState
When a handler becomes active, it is handed the current state from the Command.
PW
Previous Topic:save editor state
Next Topic:How to set services into handler
Current Time: Sun Jul 20 11:07:32 EDT 2025
Powered by FUDForum. Page generated in 0.14856 seconds
