Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Re: Bizarre issue with tab order in a ToolBar
Re: Bizarre issue with tab order in a ToolBar [message #479849] Wed, 12 August 2009 13:12 Go to next message
Copying to the SWT newsgroup, eclipse.platform.swt
Brian Fitzpatrick wrote:
> Hi all...
> I'm guessing I'm just missing something simple. But I have a Toolbar
> with two ToolItems in it. When the user goes to tab through the toolbar,
> they can tab to the first button but not the second. There is no
> difference with how I'm adding the two buttons, but the tab order just
> skips to the next control on the page.
> I'm not using complicated logic here...
> toolBar = new ToolBar(this.mPanel, SWT.FLAT);
> if (flag1) {
> item1 = new ToolItem(toolBar, SWT.PUSH);
> if (flag2) {
> item2 = new ToolItem(toolBar, SWT.PUSH);
> I've tried adjusting the TabList on the ToolBar instance, but can't set
> it for some reason without throwing an
> "java.lang.IllegalArgumentException: Argument not valid" exception.
> Any ideas would be great.
> Thanks in advance!
> --Fitz
Re: Bizarre issue with tab order in a ToolBar [message #479859 is a reply to message #479849] Wed, 12 August 2009 14:15 Go to previous messageGo to next message
>> Hi all...
>> toolbar, they can tab to the first button but not the second. There is
>> no difference with how I'm adding the two buttons, but the tab order
>> just skips to the next control on the page.
>> if (flag1) {
>> if (flag2) {
>> set it for some reason without throwing an
>> Thanks in advance!
>> --Fitz
Thanks Eric!
Re: Bizarre issue with tab order in a ToolBar [message #484516 is a reply to message #479859] Mon, 07 September 2009 22:41 Go to previous message
My experience with SWT's ToolBar is that you can tab into and out of it, but to actually navigate between ToolItems you have to switch to using arrow keys (left/right).
Ben Gold
Previous Topic:Accessible behavior of Label + Combo
Next Topic:SWT on snow leopard osx 10.6 with older programs
Current Time: Sun Jul 20 08:38:06 EDT 2025
Powered by FUDForum. Page generated in 0.24905 seconds
