Change a reference from the owner, after creating a new object in one command (EMF/GEF/GMF)? [message #484468] |
Mon, 07 September 2009 11:21  |
Originally posted by: dennis.freese.gmx.net
Hello all,
I'm a bit confused about the command handling in EMF/GEF/GMF. Maybe
somebody can help me with that.
My problem is, I want to set a reference of the owner object after
creating a new object.
For example: When a new object o1 is created it should be added to the
owners list(this is automatically done) and also the owners reference
owner.startObject should also be set. (I can't do it in the creation
command, because of an exception with the historyStack). This is clear.
I know if a new object will be created then a XXXCreateCommand will be
called. This is a GMF-Command.
If an attribute/reference in the property editor will be changed an EMF
command will be created.
Why is the first command a gmf and the second one an emf one?
It should be better if they were both gmf commands, or isn't it?
It is possible to create a CompoundCommand with a new XXXCreateCommand
and adding a SetValueCommand, but how can I get the created object when
creating the setValueCommand? The command isn't executed when creating it.
Maybe I have to write a new command which is derived from
AbstractCommand? Or maybe from the gmf/emf command
AbstractTransactionalCommand? When I try this, where I have to integrate
it? Is the XXXItemSemanticEditPolicy the correct place?
After looking in the newsgroups and some website's (e.g.
http://help.eclipse.org/galileo/index.jsp,
http://wiki.eclipse.org/index.php/GMF_Tips#Creating_New_Elem ents_And_Corresponding_Views),
I found very much posts and hints but no answers to the questions. Maybe
I don't see the answer after reading much entries.
Help is very appreciated. I will be grateful to get answers.
With best regards
Dennis
Re: Change a reference from the owner, after creating a new object inone command (EMF/GEF/GMF)? [message #484882 is a reply to message #484881] |
Wed, 09 September 2009 11:27   |
Hello Alex,
I also tried your approach, but this didn't work. I have one main object
(where all elements from this editor will be saved). Additionally I have
a list with objects (containments) and a reference which I want set to a
new object (when it is a special type).
When I try your hint with the "childrenFeature" I don't have the option
to set the reference from the main object.
thanks for your answers.
Dennis
Dennis F schrieb:
> Hello Alex,
> I have tried to reproduce my error to get the exception, but no error
> occurs. So I think my problem is resolved. :)
> I want to ask you if you have some information about my further
> questions like:
> and adding a SetValueCommand. But how can I get the created object when
> Is this possible or is this way of using a CompoundCommand not correct?
> When I want to write a special command and I derive it from
> AbstractTransactionalCommand, where I have to integrate it? Is the
> I think there aren't much informations about this topic.
> Maybe you have some hints, like a website so I can get the information.
> Thank you very much
> Dennis
> Alex Shatalin schrieb:
>> Hello Dennis,
>> First of all, if you need to set additional refrence of the parent
>> element to point to the child one - try specifying this reference as
>> "childrenFeature" in a corresponding NodeReference.
>> Can you post this exception here?
>> I suggest you modifying GMF-generated ???CreateCommand (but i suppose
>> the best solution is to use GMF way to set this reference for the
>> created element - see above).
>> Alex Shatalin
FUDForum. Page generated in 0.04174 seconds
