Update connection when target-attribute changes [message #484365] |
Mon, 07 September 2009 04:56  |
I've got a connection, that is not defined by an element with source/target attributes, but only as target-attribute of the source-node.
Something like
<node name="Node1">
<link target="Node2" />
</node>
<node name="Node2" />
where node is represented as a Node, link as Border-Node and target as connection.
This works fine, but when the user changes the target-attribute, the connection still points to the old node. When I press F5 on the connection, it is removed.
I can react to this change in handleNotificationEvent, but what do I have to do have the connection revalidated (or removed and re-added)?
Thanks!
Re: Update connection when target-attribute changes [message #484813 is a reply to message #484396] |
Wed, 09 September 2009 08:31  |
Hello Peter,
> Out of curiosity, where and how would I set the target view?
You can create new command calling Edge.setTarget() method with an appropriate
(new) target view from this method listening to underlying domain model notifications.
Alex Shatalin
FUDForum. Page generated in 0.03675 seconds
