How to change property of action defined in plugin.xml in other components? [message #483477] |
Tue, 01 September 2009 13:28  |
I have several actions that are defined as an action in an actionset in
the plugin.xml file. An event elsewhere in the app can cause some
property to need to change on an action (ie. text, icon, checked state,
etc.). Is there a registry or listing that I can search to obtain the
action object reference based on the action ID? I've done some searching
around, but haven't found much that applies to my situation; perhaps I'm
not searching for the right thing.
Ryan
Re: How to change property of action defi ned in plugin.xml in other components? [message #484216 is a reply to message #483489] |
Fri, 04 September 2009 11:29  |
Well, I got it working.
I know it's not right, but it is a horrible hack for now.
Going in through here
PlatformUI.getWorkbench().getActiveWorkbenchWindow()).getCoo lBarManager2().getItems()
I was able to eventually drill down and get the reference to the IAction
that I needed. In the process, I had several restricted warnings. It's a
good thing this code is just a hack and will be replaced soon enough.
FUDForum. Page generated in 0.14974 seconds
