Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Errors during source build
Errors during source build [message #483341] Tue, 01 September 2009 04:56 Go to next message
Hello!
From time to time, I get strange and annoying errors during simply build
my project source.
First error is (info from Error Log view):
Message:
de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on: Archive
file is read-only!
Exception Stack Trace:
java.io.FileNotFoundException:
file is read-only!
at
de.schlichtherle.io.ArchiveController.createOutputStream(Arc hiveController.java:579)
at
de.schlichtherle.io.FileOutputStream.createOutputStream(File OutputStream.java:164)
at de.schlichtherle.io.FileOutputStream.<init>(FileOutputStream.java:124)
at
org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .createManifestFile(Unknown
Source)
at
org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .updatePackage(Unknown
Source)
at
org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .doBuild(Unknown
Source)
at
org.eclipse.mtj.internal.core.build.MTJIncrementalProjectBui lder.build(Unknown
Source)
at
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
at
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
at org.eclipse.core.internal.resources.Project$1.run(Project.ja va:522)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at
org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:502)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate$1.r un(LaunchConfigurationDelegate.java:423)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate.bui ldProjects(LaunchConfigurationDelegate.java:430)
at
org.eclipse.debug.core.model.LaunchConfigurationDelegate.bui ldForLaunch(LaunchConfigurationDelegate.java:126)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:821)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on:
Archive file is read-only!
at
de.schlichtherle.io.ArchiveFileSystem$LinkDelta.<init>(ArchiveFileSystem.java:487)
at
de.schlichtherle.io.ArchiveFileSystem$LinkDelta.<init>(ArchiveFileSystem.java:478)
at de.schlichtherle.io.ArchiveFileSystem.link(ArchiveFileSystem .java:469)
at de.schlichtherle.io.ArchiveFileSystem.link(ArchiveFileSystem .java:403)
at
de.schlichtherle.io.ArchiveController.createOutputStream0(Ar chiveController.java:620)
at
de.schlichtherle.io.ArchiveController.createOutputStream(Arc hiveController.java:570)
... 30 more
Session Data:
eclipse.buildId=I20090611-1540
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=ru_RU
Framework arguments: -product org.eclipse.epp.package.java.product
-showlocation
Command-line arguments: -os win32 -ws win32 -arch x86 -product
org.eclipse.epp.package.java.product -showlocation -debug
And the second problem is:
Message:
D:\Work\PocketMSS\PocketMSS\.mtj.tmp\emulation\PocketMSS.jar (couldn't
preserve last modification time)
de.schlichtherle.io.ArchiveWarningException:
at
de.schlichtherle.io.UpdatingArchiveController.update(Updatin gArchiveController.java:907)
at
de.schlichtherle.io.UpdatingArchiveController.umount0(Updati ngArchiveController.java:697)
at
de.schlichtherle.io.UpdatingArchiveController.umount(Updatin gArchiveController.java:642)
at
de.schlichtherle.io.ArchiveControllers.umount(ArchiveControl lers.java:318)
at de.schlichtherle.io.File.umount(File.java:1099)
at
Source)
at
Source)
at
Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Session Data:
-showlocation
If I Clean all project and Rebuild it this helps for some time.
My question is how can I avoid this errors at all?
Re: Errors during source build [message #483351 is a reply to message #483341] Tue, 01 September 2009 05:48 Go to previous messageGo to next message
Originally posted by: news.s237965939.online.de
Andrey Krivtsun wrote:
> Hello!
> build my project source. First error is (info from Error Log view):
> Message:
> file is read-only!
It seems you're using some 3rd patry software. I think it would be a
good idea to contact their tech support. I guess it is at
http://www.schlichtherle.de
Hans
Re: Errors during source build [message #483408 is a reply to message #483351] Tue, 01 September 2009 10:21 Go to previous messageGo to next message
I don't use nothing from Schlichtherle.de. I suppose that MTJ or eve
Eclipse use something from there for their internal purposes.
Re: Errors during source build [message #483410 is a reply to message #483351] Tue, 01 September 2009 10:23 Go to previous messageGo to next message
I'm right.
See this plugins that MTJ uses
http://wiki.eclipse.org/DSDP/MTJ/Developer_Resources/Configu ring_the_Workspace#Plug-ins_2
So, problem is within MTJ
Re: Errors during source build [message #483439 is a reply to message #483410] Tue, 01 September 2009 11:39 Go to previous messageGo to next message
Moreover, I've install MTJ 1.0.1 RC on another Eclipse - all works fine
with my sources, but if I Enable JMUnit support just got that exceptions.
Re: Errors during source build [message #483451 is a reply to message #483439] Tue, 01 September 2009 12:13 Go to previous messageGo to next message
It seams you are facing problems with the read/write permissions of the folders/files of you project. take some time and check if all folders have read/write access.
Re: Errors during source build [message #483462 is a reply to message #483451] Tue, 01 September 2009 12:47 Go to previous messageGo to next message
Sure. All my files/folders have that rights.
I suppose what problem somewhere in MTJ because I got these problems on
two different computers.
Re: Errors during source build [message #483471 is a reply to message #483462] Tue, 01 September 2009 13:16 Go to previous messageGo to next message
Could you open a new bug for us?
Diego
Re: Errors during source build [message #483484 is a reply to message #483471] Tue, 01 September 2009 13:39 Go to previous messageGo to next message
Done
I've added
https://bugs.eclipse.org/bugs/show_bug.cgi?id=288289
Pls, change bug attributes in needed.
Re: Errors during source build [message #483486 is a reply to message #483484] Tue, 01 September 2009 13:44 Go to previous messageGo to next message
thanks
Re: Errors during source build [message #483503 is a reply to message #483486] Tue, 01 September 2009 15:00 Go to previous messageGo to next message
I've played with this bug again. I've created new fresh J2me project via
template DisplayManager. It builds fine. But if I switch on Enable JMUnit
I have that exceptions. And even I Disable JMUnit I still have exceptions.
So, I couldn't build simple project at all. :( Very bad :(
Re: Errors during source build [message #490259 is a reply to message #483503] Thu, 08 October 2009 03:00 Go to previous messageGo to next message
I've facing this too. So, I've dicided to install a fresh eclipse 3.5.1 and MTJ 1.0.1 . Right after install devices and Mtj I've try to create my first midlet project Guess what. Right after click finish on "Create a MIdlet Project" tab I got the message "couldn't preserve last modified time..." . After that nothing more worked.
Any news?
thanks in advance.
Re: Errors during source build [message #515647 is a reply to message #483341] Fri, 19 February 2010 11:01 Go to previous messageGo to next message
Is any progress with this bug?
I've started new j2me project and got the same problem again.
Re: Errors during source build [message #530367 is a reply to message #515647] Thu, 29 April 2010 10:05 Go to previous messageGo to next message
Hi Andrey,
unfortunately we don't have enough resources to fix some of the bugs filed against MTJ in time for the 1.1 release. You could send an email to our mailing list requesting this bug to be fixed.
Sorry for the inconvenience,
Diego
Re: Errors during source build [message #532145 is a reply to message #530367] Fri, 07 May 2010 06:46 Go to previous messageGo to next message
Strange answer. You haven't resources to fix critical bug but have them to create new version. Well, where should I write letter for fix bug?
[Updated on: Fri, 07 May 2010 06:46] by Moderator
Re: Errors during source build [message #532329 is a reply to message #530367] Sat, 08 May 2010 03:41 Go to previous messageGo to next message
Originally posted by: krischik.users.sourceforge.net
Am 29.04.2010, 16:05 Uhr, schrieb Diego Madruga Sandin
<diegosandin@gmail.com>:
Well, if you short on resources how about joining the pyx4me maven team.
You would not need to care about the build process any more and could
concentrate on other integration issues like editor, debugger and emulator
support.
Martin
Martin Krischik
mailto://krischik@users.sourceforge.net
https://sourceforge.net/users/krischik
Re: Errors during source build [message #533659 is a reply to message #532145] Fri, 14 May 2010 21:11 Go to previous messageGo to next message
unfortunately the guy that implemented this part of the code is not an active commiter anymore, and since we work on MTJ in our spare time there not a lot of time left to understand / reproduce this issue and work on a fix. as member of this community i apologize for that.
i really hope that this was fixed before. i sent an email to MTJ developer list to see if anyone else is able to work on this fix .
PS.: generating a build is much easier since i did a good part of it Smile
Re: Errors during source build [message #577080 is a reply to message #483341] Tue, 01 September 2009 05:48 Go to previous messageGo to next message
> Hello!
> Message:
> file is read-only!
Hans
Re: Errors during source build [message #577141 is a reply to message #483351] Tue, 01 September 2009 10:21 Go to previous messageGo to next message
Re: Errors during source build [message #577162 is a reply to message #483351] Tue, 01 September 2009 10:23 Go to previous messageGo to next message
I'm right.
Re: Errors during source build [message #577182 is a reply to message #483410] Tue, 01 September 2009 11:39 Go to previous messageGo to next message
Re: Errors during source build [message #577247 is a reply to message #483439] Tue, 01 September 2009 12:13 Go to previous messageGo to next message
Re: Errors during source build [message #577284 is a reply to message #577247] Tue, 01 September 2009 12:47 Go to previous messageGo to next message
Re: Errors during source build [message #577307 is a reply to message #483462] Tue, 01 September 2009 13:16 Go to previous messageGo to next message
Could you open a https://bugs.eclipse.org/bugs/enter_bug.cgi?assigned_to=dsdp .mtj-inbox%40eclipse.org&blocked=&bug_file_loc=http% 3A%2F%2F&bug_severity=normal&bug_status=NEW&comm ent=Overview%3A%20%28More%20detailed%20restatement%20of%20su mmary%29%0D%0A%0D%0ASteps%20to%20Reproduce%3A%20%28Minimized %2C%20easy-to-follow%20steps%20that%20will%20trigger%20the%2 0bug%29%0D%0A%0D%0A%20%20%20%201%29%0D%0A%20%20%20%202%29%0D %0A%0D%0AActual%20Results%3A%20%28What%20MTJ%20did%20after%2 0performing%20the%20above%20steps%29%0D%0A%0D%0A%0D%0A%0D%0A Expected%20Results%3A%20%28What%20MTJ%20should%20have%20done %2C%20were%20the%20bug%20not%20present%29%0D%0A%0D%0A%0D%0A% 0D%0ABuild%20Date%20%26%20Platform%3A%20%28update%20with%20t he%20correct%20values%20from%20your%20workspace%29%0D%0A%20% 0D%0A%20Installation%20%3A%20eclipse-SDK-3.4.0%20%28I2008061 7-2000%29%20%0D%0A%20MTJ%20install%20%20%3A%20Runtime%20|%20 SDK%20|%20Examples%0D%0A%20java.runtime%20%3A%20Java%28TM%29 %20SE%20Runtime%20Environment%20%28build%201.6.0_07-b06%29%0 D%0A%20os.name%3A%20%20%20%20%20%3A%20Windows%20XP%20Profess ional%2C%20Service%20Pack%203%0D%0A%0D%0AAdditional%20Builds %20and%20Platforms%3A%20%28Whether%20or%20not%20it%20occurs% 20on%20other%20platforms%29%0D%0A%0D%0A%0D%0A%0D%0AAdditiona l%20Information%3A%20%28Any%20other%20useful%20information%2 9%0D%0A%0D%0A%0D%0A&contenttypeentry=&contenttypemet hod=autodetect&contenttypeselection=text%2Fplain&dat a=&dependson=&description=&flag_type-1=X&fla g_type-2=X&flag_type-4=X&flag_type-6=X&flag_type -7=X&flag_type-8=X&form_name=enter_bug&keywords= &maketemplate=Remember%20values%20as%20bookmarkable%20te mplate&op_sys=All&priority=P3&product=MTJ&qa _contact=&rep_platform=All&short_desc=&version=u nspecified for us?
Diego
Re: Errors during source build [message #577329 is a reply to message #483471] Tue, 01 September 2009 13:39 Go to previous messageGo to next message
Done
I've added
Re: Errors during source build [message #577352 is a reply to message #483484] Tue, 01 September 2009 13:44 Go to previous messageGo to next message
thanks
Re: Errors during source build [message #577434 is a reply to message #577352] Tue, 01 September 2009 15:00 Go to previous messageGo to next message
Re: Errors during source build [message #577814 is a reply to message #483503] Thu, 08 October 2009 03:00 Go to previous messageGo to next message
Any news?
thanks in advance.
Re: Errors during source build [message #579609 is a reply to message #483341] Fri, 19 February 2010 11:01 Go to previous messageGo to next message
Re: Errors during source build [message #580143 is a reply to message #579609] Thu, 29 April 2010 10:05 Go to previous messageGo to next message
Hi Andrey,
Diego
Re: Errors during source build [message #580163 is a reply to message #580143] Fri, 07 May 2010 06:46 Go to previous messageGo to next message
Strange answer. We haven't resources to fix critical bug but have them to create new version. Well, where should I write letter for fix bug?
Re: Errors during source build [message #580193 is a reply to message #580143] Sat, 08 May 2010 03:41 Go to previous messageGo to next message
support.
Martin
Martin Krischik
Re: Errors during source build [message #580370 is a reply to message #580163] Fri, 14 May 2010 21:11 Go to previous message
PS.: generating a build is much easier since i did a good part of it :)
Previous Topic:Unable to debug - LG
Next Topic:Unable to debug - LG
Current Time: Sat Jul 19 16:31:49 EDT 2025
Powered by FUDForum. Page generated in 0.30153 seconds
