Project tasks [message #482792] |
Thu, 27 August 2009 21:36  |
I'm a newcomer to Eclipse and trying to create tasks in Mylyn which
belong to current project.
But they always show up all, in all projects.
I mean I created task working with project X. It placed under
Uncategorized, for example. Then I switch to project Y and still see
that task under Uncategorized. But it should be hidden in project Y.
How can I achieve this?
Thanks.
Re: Project tasks [message #485150 is a reply to message #482997] |
Thu, 10 September 2009 11:42  |
Sergei wrote:
> I tried to create repos but couldn't. The only choice Eclipse give me to
> create Bugzilla repository, not Local. Seems like Local repository can
> be created only once and it handles all projects.
When you use the Industrial SQL Connector (see
https://bugs.eclipse.org/184532) you can create a more elaborate system
using a Derby or other type of database with a Product category as field.
Maarten
Re: Project tasks [message #598888 is a reply to message #482792] |
Fri, 28 August 2009 10:15  |
Hello Sergej,
This is not the way Mylyn is working. You cannot assign tasks to project.
But you can assign a task repository to project in the project specific settings.
So the behaviour you are observing is perfectly correct.
Cheers, Jörg
> Thanks.
Re: Project tasks [message #598899 is a reply to message #482918] |
Fri, 28 August 2009 11:27  |
Jörg Thönnes пишет:
OK thank you. I'll try to create repositories then for every project.
S.
Re: Project tasks [message #598909 is a reply to message #482940] |
Fri, 28 August 2009 18:03  |
> S.
This will not have any effect on hiding the tasks I think. Probably your
best bet is to use categories to group tasks based on project.
Re: Project tasks [message #598928 is a reply to message #482988] |
Fri, 28 August 2009 20:59  |
Vladimir Grishchenko пишет:
>> S.
OK, will have to use categories. Spasibo.
S.
Re: Project tasks [message #599058 is a reply to message #482997] |
Maarten
FUDForum. Page generated in 0.06656 seconds
