Home » Eclipse Projects » Standard Widget Toolkit (SWT) » suggestBox
suggestBox [message #482718] Thu, 27 August 2009 12:43 Go to next message
I'm trying to make some kind of a suggestBox with Text(where user writes
his search) and Shell(list of suggestions).
The code is bellow.
I want the shell to disappear when the textbox loses focus, but i'm facing
some problems with this.
If the user clicks somewhere in the shell, the textbox loses focus, and
the shell disappears.
I tried to get around this with a flag, when the mouse enters the list of
suggestions the flag
gets to true, preventing the shell to close, and when the mouse leaves the
shell the flag goes to
false, so the shell can be closed.
This would work, if it wasn't for the scrollBar in the list of
suggestions... If the user takes the
mouse directly to the scrollbar without passing on the top of the list,
that flag never gets to true,
and i can't get the scrollBar to capture the mouseEnter or mouseOver
event!!
Is is possible to capture that mouseOver event from a scrollBar?
Is there some kind of event manager that i can use on the focusLost method
of the textbox to
determine the next focused control??
HC
//Create textbox
protected Control createControl(Composite parent) {
text = new Text(parent, SWT.BORDER);
GridLayout gl = new GridLayout();
gl.numColumns = 1;
GridData gd = new GridData(GridData.FILL_BOTH);
gd.minimumWidth = 200;
text.setLayoutData(gd);
//Select items from list using arrowKeys in textbox
text.addKeyListener(new KeyAdapter() {
public void keyPressed(KeyEvent e) {
boolean isUpKey = (e.stateMask == SWT.NONE) && (e.keyCode ==
16777217);
boolean isDownKey = (e.stateMask == SWT.NONE) &&
(e.keyCode == 16777218);
boolean changed = false;
List suggestList = suggestListViewer.getList();
int selIndex = suggestList.getSelectionIndex();
if(isUpKey){
if(selIndex > 1){
suggestList.setSelection(selIndex - 1);
changed = true;
else if(isDownKey){
if(selIndex < suggestList.getItemCount()){
suggestList.setSelection(selIndex + 1);
changed = true;
if(changed){
String selected = suggestList.getSelection()[0];
text.setText(selected);
text.setSelection(0, text.getCharCount());
text.addListener(SWT.MouseDown, new Listener() {
public void handleEvent(Event event) {
if(shell != null && !shell.isDisposed() && !shell.getVisible()){
showSuggestBox();
else{
createShell();
onShell = false;
text.addFocusListener(new FocusAdapter() {
public void focusLost(FocusEvent e) {
!shell.isFocusControl() && shell.getVisible() &&
!onShell && suggestListViewer != null &&
!suggestListViewer.getList().isFocusControl()){
shell.dispose();
return text;
private void createShell(){
shell = new Shell(parentComposite.getDisplay(), SWT.NO_TRIM);
gl.numColumns = 1;
shell.setLayout(gl);
shell.setLayoutData(gd);
shell.setSize(300, 150);
shell.setLocation(text.toDisplay(text.getLocation().x - 10,
text.getLocation().y + text.getSize().y - 10));
gl.numColumns = 1;
suggestListViewer = new ListViewer(shell, SWT.NO_SCROLL | SWT.V_SCROLL |
SWT.SINGLE);
suggestListViewer.setContentProvider(new SuggestBoxContentProvider());
suggestListViewer.setLabelProvider(new SuggestBoxLabelProvider());
suggestListViewer.setInput(selectableValues);
suggestList.setLayoutData(gd);
//copy selected text to textBox
suggestListViewer.addSelectionChangedListener(new
ISelectionChangedListener() {
public void selectionChanged(SelectionChangedEvent event) {
List list = suggestListViewer.getList();
if(list.getSelectionCount() == 1){
String selected = list.getSelection()[0];
shell.setVisible(false);
suggestList.addListener(SWT.MouseEnter, new Listener() {
onShell = true;
System.out.println("onList");
//THIS DOESN'T WORK...:(
suggestList.getVerticalBar().addListener(SWT.FocusIn, new Listener() {
onShell = true;
System.out.println("onList_|");
shell.open();
text.forceFocus();
shell.setVisible(true);
shell.moveAbove(null);
onShell = false;
shell.addListener(SWT.MouseExit, new Listener() {
onShell = false;
System.out.println("offTHEShell!!");
//make shell visible
public void showSuggestBox(){
text.getLocation().y + text.getSize().y - 6));
text.forceFocus();
onShell = false;
Re: suggestBox [message #482733 is a reply to message #482718] Thu, 27 August 2009 13:27 Go to previous messageGo to next message
I found a solution...
text.getDisplay().getCursorControl() gives me the control where the mouse
event occurred even if the click was in the scrollbar, so before disposing
the shell on the focusLost event, i can test if the click was in the List.
Thanks a lot!
hc
Re: suggestBox [message #482917 is a reply to message #482733] Fri, 28 August 2009 10:30 Go to previous messageGo to next message
The getCursorControl() approach sounds pretty hacky. The snippet below
demonstrates how to get the new focus control when FocusOut is received:
public static void main (String [] args) {
final Display display = new Display ();
final Shell shell = new Shell (display);
shell.setLayout(new RowLayout(SWT.VERTICAL));
Listener listener = new Listener() {
display.asyncExec(new Runnable() {
public void run() {
if (display.isDisposed()) return;
System.out.println("new focus control: " +
display.getFocusControl());
new Text(shell, SWT.SINGLE).addListener(SWT.FocusOut, listener);
new Button(shell, SWT.PUSH).addListener(SWT.FocusOut, listener);
shell.pack();
shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
Grant
" hc" <hcosta@portoeditora.pt> wrote in message
news:511d1515016bab985188baa5dfc53783$1@www.eclipse.org...
> Thanks a lot!
> hc
Re: suggestBox [message #483202 is a reply to message #482718] Mon, 31 August 2009 10:45 Go to previous messageGo to next message
Hi hc,
May you want to have a look at the
org.eclipse.jface.fieldassist.AutoCompleteField class (Sample:
http://javawiki.sowas.com/doku.php?id=swt-jface:autocomplete field).
Remo
Re: suggestBox [message #483225 is a reply to message #483202] Mon, 31 August 2009 12:20 Go to previous message
Remo Loetscher wrote:
> Hi hc,
> Remo
Silly me...
I've been looking for suggestBox, didn't remember of autoComplete...:p
Anyway... I managed to get what I wanted.. The result is pretty similar,
and i get a better control.
hc
Previous Topic:Table selection via checkboxes
Next Topic:Accessing composite componets from another composite
Current Time: Sat Jul 19 06:32:42 EDT 2025
Powered by FUDForum. Page generated in 0.07465 seconds
