Home » Modeling » GMF (Graphical Modeling Framework) » Link Mapping to shortcuts
Link Mapping to shortcuts [message #482205] Tue, 25 August 2009 12:56 Go to next message
Hello all,
As posted previously by others in the newsgroup, I have problems with
creation of a link mapping between "normal" nodes and shortcut nodes.
In my Editor 1, I have Class C which has a reference to a property P.
In my Sub-Editor I am able to create a shortcut to Class C()
Now I want to link my Elements in the sub-Editor with the property P
which does not work.
So , as read in older posts , I created a "fake" node mapping to my
model element P in my Sub-Editor.
In .graph I made a Figure Descriptor with Rectangle,Label and Child
Accessor. I made a Node and Diagram Label and in .gmfmap I added a Top
level node and did not give a creation tool.
I tried to ignore the Validation but still cannot generate diagram code.
Generation fails with an Excpetion
org.eclipse.gmf.gmfgraph.impl.FigureDescriptorImpl cannot be cast to
org.eclipse.gmf.gmfgraph.Node
Did someone else have had a similar problem?
thx for any help,
JanRed
Re: Link Mapping to shortcuts [message #482359 is a reply to message #482205] Wed, 26 August 2009 06:54 Go to previous messageGo to next message
Hello Jan,
Looks like in .gmfgraph model FigureDescriptor and Node was defined with
the same name..
Try renaming one of this elements to make a name identical.
Alex Shatalin
Re: Link Mapping to shortcuts [message #482376 is a reply to message #482359] Wed, 26 August 2009 07:40 Go to previous messageGo to next message
Alex Shatalin schrieb:
> Hello Jan,
> the same name..
> Alex Shatalin
Thx for your reply. It works now. .gmpmap complained about the
Containment feature but I ignored the Validations.
"ensure that "create shortcut" action will use this "fake" node to
visualize shortcut on creating shortcut to the element from main diagram"
- A solution from you in an old post...can you please elaborate?
I started looking into CreateShortcutAction class
Jan Red
Re: Link Mapping to shortcuts [message #482427 is a reply to message #482376] Wed, 26 August 2009 10:05 Go to previous messageGo to next message
>> Hello Jan,
>> with the same name..
>> Alex Shatalin
> Jan Red
It works now atleast partially. The "create shortcut" action is using
the "fake node" to visualize the element in the main diagram.
But 1 side effect is that a copy of my Element(only in the diagram not
in model) is created my sub-editor when it is created in the main editor.
I want to remove this functionality...any clues?
thx
Jan Red
Re: Link Mapping to shortcuts [message #482604 is a reply to message #482427] Thu, 27 August 2009 05:23 Go to previous messageGo to next message
Hello Jan,
> editor.
Do you mean, shortcut will be automatically created for newly created element
on the main diagram?
Alex Shatalin
Re: Link Mapping to shortcuts [message #482609 is a reply to message #482604] Thu, 27 August 2009 05:37 Go to previous messageGo to next message
> Hello Jan,
>> editor.
> element on the main diagram?
> Alex Shatalin
Yes, the shortcut is automatically created.
When the Element is created in the main editor , the following happens
in the code of sub-Editor :
refreshSemanticChildren method is called from **CanonicalEditPolicy
which in turn calls get**MyCanvasElement**_SemanticChildren method(in
**DiagramUpdater)
This method thinks that the Element created is its own element and
issues a create command for it.
I compared the code of different **DiagramUpdaters and there is an extra
getPhantomNodesIterator method in the sub-Editor.
The problem is that the same sequence of operations is called from the
handleNotificationEvent of **CanonicalEditPolicy during the actual
shortcut process and therefore it is difficult to comment out this code.
thx for the help
Jan Red
Re: Link Mapping to shortcuts [message #482612 is a reply to message #482609] Thu, 27 August 2009 05:41 Go to previous messageGo to next message
Hello Jan,
I think you need to comment your this method.
In case of shortcuts corresponding diagram element will have special annotation
showing this is a shortcut, so it will not be removed by CanonicalEditPolicy
See <diagram>CanonicalEditPolicy.isOrphaned() method:
if (view.getEAnnotation("Shortcut") != null) { //$NON-NLS-1$
return EcoreDiagramUpdater.isShortcutOrphaned(view);
Alex Shatalin
Re: Link Mapping to shortcuts [message #482618 is a reply to message #482612] Thu, 27 August 2009 06:29 Go to previous messageGo to next message
--------------050904040805030807000900
Hi Alex,
The duplicate shortcut behaviour is now eliminated.This works partially
but not completely how I wanted it.
Please see the attached picture.
Initially i wanted to create Shortcuts in my sub-editor and make link
mappings between the Name node on the left hand figure and NameValue
object on the right hand side (inside the person), both objects are
inside Compartments.
Since it is possible to create Link mappings only to top-level nodes
inside shortcuts , I created a fake Top-level node for the Object
NameValue.So as you can see in the picture the Mapping works since I now
can create a shortcut directly to the nameValue object.
But is it possible to somehow make a Link to the nameValue inside the
Person object? I hope I was able to explain my problem clearly...
thx for the help
Jan Red
Content-Type: image/png;
name="problem.PNG"
Content-Disposition: inline;
filename="problem.PNG"
iVBORw0KGgoAAAANSUhEUgAAAfMAAAEUCAIAAACwLEgmAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
GV1JREFUeF7tnc2rHMUWwPP+nedKl3EZV0+jbsxSV25c6ANdmIUmDzUrXZiF gqu3FASNiTdq
IB8EQQQRRFAQQYLBD/x4oi/m5prrvHNvaadfd09PV1d11ak6v2G4zJ2prjr1 O6d+t1Mz6fnb
arU6wA0CEIAABGoiIGbnBgEIQAACNRE4UNNkmAsEIAABCOztxEABAhCAAAQq I4DZK0so04EA
BCDAOTs1AAEIQKA6ApyzV5dSJgQBCJgngNnNlwAAIACB6ghg9upSyoQgAAHz BDC7+RIAAAQg
UB0BzF5dSpkQBCBgngBmN18CAIAABKojgNmrSykTggAEzBPA7OZLAAAxCFy4 cObUqVP//Pd7
9z979v5n35af9+39fPu+596+f/8uv7q7tJGW3NITkBzFSHUZfWD2MvJElMoJ iKd2di7c98zZ
K9/9d/x+7zNb0pJ7egKSI+VVFDE8zB4RJl3ZJeDMfvj4W9/+5/r4/d5/vZVe aowoBDC73fXJ
zCEwj0Bj9h9+uTF+x+y5/sxg9nm1zVEQsEugMfvP13bG7x2zd77sIZf1LIyL 2Weuz4sXL6Z/
V4QRdRKQYphZRmUe1pj92vbN8Xvf7G2riugtSDbLHDH7zLVlCtxMRmYOs1YM f5r92Jmd33fH
7/dIm9Y7qB2VN7+2z+Vde/dSv0HzanNIp717PotMVQ1qqiZjvoNqCpwZRc+c qLVicGa/5+k3
d3f/GL/f/fTpjWYf1H1b0Ov+HvSd3oyF3E3VZEyzd3YMZyqBw6ogYGoVScYa s9/91Km7n3rz
H0+92TyQx/u/yk956ZTYf7bZ12l63V8C9nnaBEzVZGSzt6Uk1VaFo5jEHAKm VlHb7BvfQe2b
fXDjpf/Oal/f7Z2ZvsTHz+tV7ZOkCcZUTcaUb0flza/tGnWScC/1GzSvNod0 2rvn55iGY9IS
MLWKAs3e99rgzsnIk5yzT/nbYKomY1py0OzrnmxrfeRMv/kb0O4Huae19JzR TK2ittnllHzj
feMmyRRTD76tuvHJKQastY2pmsxm9sYW6870B8/u20/O8Q3HpCJgahVFP2d3 n4Fpbm1fdz4J
0955H2nf/lBNreLeOC9TNRnZ7IMbL50dw/Y+THv7ZdDanX0bzJ7KzKHjmFpF IWbf6CMaxCJg
qiYjm73vg8Gdk5Enp2/phLqH45ckYGoVNWaX6zhu3IqRNrFURT9eBEzVZGqz D56Db9x4Gd+x
WVJQ9D2TgKlV1JjdSzQ0TkzAVE0ubna39zL4WZf2VkznDdKR9v3NnJnu4bAl CZhaRc7s3PQT
WLLkdfUd0+zWFrOuTCqLxloxuP+pxF0zAVM1idmVGbGWcEytInZjNAu9ic1U TWL2WlSqbB6m
VhFmx+zK1t8Ks2vLSCXxYPYiZGcqSFM1idkrMam2aZhaRTbP2QevdqD5T4Wp msTs2pRYSTym
VtGg2R955fKUuzYV9n29zuCYXfNaxeyas1NwbJj94Zcu7f6xGr8//PIlzJ6M gKmajGx2/R9o
JcJkBAr+u+Qfev9Tjw+evLCzu3rw5Pm9+4v7P9sPTp6XVx+Sn7M+K+nOlzsX iuk/07n4zEj7
9gn4yGPXQ/s6Np0z9/ar/eHmTTbWUZjdv673jzAFbiYjM4dZK4a+2Y88f+63 3dWR59+9cn3V
vz8gr95cHXnh3DxttQ07eLWvRv1N/31fj0h58KjOk/0hmkjW9TxvsrGOMlWT kc/ZzYiLiW4g
YGoVDe6zH37u7C+/r+SnaF0e7N1v3vp5+MT+qyfODmprorhH/IvZ+2BN1SRm x9GLEDC1igbN
fujY6R92VoeOnxaz/7izksdylwd79xt7z8uvdx37v+9Ebe9ytM/EN76ruW4P ZHyPpb1XM/i3
pH/q3d5gGT9n73Qe67w7pB9TNYnZF/EanZpaRYNmP3j0jW9urA4++frBo937 nftPfiuvHn29
r6qOjgc/gjK43TG+37JxN6YdyfRT/o2RhLg47rGmahKzI+FFCJhaRYNmv/2J 165ur77aXl29
vpIHt+77v+49v7264/HX5slro0+nq3niRvy6PwyDf4fYZ19kUfl0itl9aNF2 MgHMfttjr/79
sVfl522P/nXvPN7/NaLZ25+NmWL2fvv+aXvnmf5uTOcDOev2heZNM+5RpmoS s092FQ19CJha
RYPn7HGtRG/hBEzVJGb30RVtJxMwtYowe7h2E/RgqiYx+2RX0dCHgKlVhNkT eDl8CFM1idl9
dEXbyQRMrSLMHq7dBD2YqknMPtlVNPQhYGoVObNz00/Ap4TLbovZy86f2ugN mj3BWSdDhBAw
VZOYXa0byw7M1CpiNyZEuMmONVWTmL1sgaqN3tQqwuzJ7BwykKmaxOxq3Vh2 YKZWEWYPEW6y
Y03VJGYvW6Bqoze1ijB7MjuHDGSqJjG7WjeWHZipVYTZQ4Sb7FhTNYnZyxao 2uhNrSLMnszO
IQOZqknMrtaNZQdmahVh9hDhJjvWVE1i9rIFqjZ6U6sIsyezc8hApmoSs6t1 Y9mBmVpFmD1E
uMmONVWTmL1sgaqN3tQqwuzJ7BwykKmaxOxq3Vh2YKZWkTM7N/0Eyl5UPtFj dh9atJ1MwKDZ
Q04nOTYBAVM1idknu4qGPgRMrSJ2YxJ4OXwIUzWJ2X10RdvJBEytIswert0E PZiqScw+2VU0
9CFgahVh9gReDh/CVE1idh9d0XYyAVOrCLOHazdBD6ZqErNPdhUNfQiYWkWY PYGXw4cwVZOY
3UdXtJ1MwNQqwuzh2k3Qg6maxOyTXUVDHwKmVhFmT+Dl8CFM1SRm99EVbScT MLWKMHu4dhP0
YKomMftkV9HQh4CpVYTZE3g5fAhTNYnZfXRF28kETK0izB6u3QQ9mKpJzD7Z VTT0IWBqFTmz
c9NPwKeEy26L2cvOn9roDZo9wVknQ4QQMFWTmF2tG8sOzNQqYjcmRLjJjjVV k5i9bIGqjd7U
KsLsyewcMpCpmsTsat1YdmCmVhFmDxFusmNN1SRmL1ugaqM3tYowezI7hwxk qiYxu1o3lh2Y
qVWE2UOEm+xYUzWJ2csWqNroTa0izJ7MziEDmapJzK7WjWUHZmoVYfYQ4SY7 1lRNYvayBao2
elOrCLMns3PIQKZqErOrdWPZgZlaRZg9RLjJjjVVk5i9bIGqjd7UKsLsyewc MpCpmsTsat1Y
dmCmVhFmDxFusmNN1SRmL1ugaqM3tYowezI7hwxkqiYxu1o3lh2YqVWE2UOE m+xYUzWJ2csW
qNroTa0izJ7MziEDmapJzK7WjWUHZmoVYfYQ4SY71lRNYvayBao2elOrCLMn s3PIQKZqErOr
dWPZgZlaRZg9RLjJjjVVk5i9bIGqjd7UKsLsyewcMpCpmsTsat1YdmCmVhFm DxFusmNN1SRm
L1ugaqM3tYowezI7hwxkqiYxu1o3lh2YqVWE2UOEm+xYUzWJ2csWqNroTa0i zJ7MziEDmapJ
zK7WjWUHZmoVYfYQ4SY71lRNYvayBao2elOrCLMns3PIQKZqErOrdWPZgZla RZKqra03Zcrc
NBOQHJW9qHyix+w+tGg7mYA1s08GQ0MIpCCA2VNQNjgGZjeYdKashwBm15OL qiKpw+zHR28H
DsRcPlWln8nkJhCzNOtYzLkzUsn4dRSDiH0kH5i9kmKtcRqYvcasKphTfWYX jzc3BxizKyg0
QhgmgNmpjEUI1Gd2p3J3w+yLFA2dxiOA2eOxpKcWgfrMzjk7BV4QAcxeULJK CrUys7fP1jln
L6kQrcaK2a1mfuF5V2n2DjP22RcuIrqfTwCzz2fHkSME6jN7f7KYnSWglgBm V5uasgOrzOzu
7VPO2csuSkvRY3ZL2U441/rMzjl7wvJhqFACmD2UIMcPEqjD7O3Pwww+JvsQ 0EkAs+vMS/FR
1WH24tPABKwSwOxWM7/wvDH7woDpHgJjBDA79bEIAcy+CFY6hcA0Aph9Gida eRLA7J7AaA6B
mAQwe0ya9NUQwOwUAwQyEsDsGeHXPDRmrzm7zE09AcyuPkVlBojZy8wbUVdC ALNXkkht08Ds
2jJCPKYIYHZT6U43WcyejjUjQaBHALNTFIsQwOyLYKVTCEwjgNmncaKVJwHM 7gmM5hCISQCz
x6RJXw0BzE4xQCAjAcyeEX7NQ2P2mrPL3NQTwOzqU1RmgJi9zLwRdSUEMHsl idQ2DcyuLSPE
Y4oAZjeV7nSTxezpWDMSBHoE6jf7xYsXxTKJbzKo8WLD7MYLgOnnJVC/2bMo JsugeSupMzoE
VKWDYKwRwOyLZByvQWCRwqJTCEwjgNmncfJshdcg4FkyNIdATAKYPSbNpi+8 BoFFCotOITCN
AGafxsmzFV6DgGfJ0BwCMQlg9pg0OWeHwCL1RKcQ8CSA2T2BTWvOGSsEplUK rSCwCAFzZj+w
f2uz7PwaBTNeg0CUQqITCMwjgNlXmH1e6YwfhdmXoEqfEJhIwKLZBU3b5s1j dzrf/9U903m1
/Uz/bwNeg8DEFUgzCCxBALMPnLM3Km+I9/8SjG/p4DUILLFc6RMCEwkYNXv7 tL1/xo3ZJ1bP
SDPMHs6QHiAwm4BdszdyH9l+GT9nb/Zn+u/K4jUIzF6THAiBcAKY/c/dmPH9 lo27MZ1M4DUI
hC9OeoDAbAKmzd68Czr4nurgu6z9M32HvrOlI1776KOP3nvvvc8+++zq1as/ //zz7AwVeiBm
LzRxhF0HAcw+9mGYkd2Y5q9CfytGXhKvXbt27fvvvxezf/jhh+4a8fJTHssz 8ry8WkcBrZsF
Zq87v8xOOQFzZk+Tj0GvyZm7nL+L2eVc/ty5c2fOnJEHn3zyyZdffimu393d TRNbmlEwexrO
jAKBQQKYfZHCmOI1UbkI/Ysvvvj4449F8SJ60f37779fxwbOFAKLoKdTCEBA 9ocjQtC5mLNE
NW9Q2aL57rvv2hs4ly9flv16t4Gzvb0dMVlLdzWPwNJR0T8EjBDA7IskOpbX fvrppytXrrgN
nHfeeWdra6u9gbNI6JE6jUUgUjh0AwFbBDD7IvleyGs7OzvtDRwZ5fz5824D 5+uvv/71118X
mcysThciMCsWDoKAOQKYfZGUJ/Oa2Nxt4HzwwQdieRnXbeB8/vnn8jdA/hIs Mr0JnSYjMCEW
mkDAHIH6zS47GGKZxDcZNFcpuQ2cTz/9VPZtJAy3gSO/ypPi+mRRYfZkqBkI An0C9ZvdeNbd
Bo6cwrv/OeU2cOQEf+kNHMxuvPCYfl4CmD0v/wyjywaObMq3N3DE+PLJy7gb OJg9Q2oZEgJ/
EcDs1MJKTurlf0s1GzjyIZxmA0f2duYBwuzzuHEUBKIQwOxRMFbViXxwvtnA kfdj3XUR3AaO
vFs78boImL2qmmAypRHA7KVlLEe8cl0Et4Ejn7CU/ygr1nYbOPIfaNddFwGz 50gUY0LgTwKY
nVKYQ8Bt4MhFb9x1EdwGjrsugtvAwexzsHIMBCIRwOyRQNruxm3guOsiuA0c udm5sKXt5DN7
jQQwu8asVBCTmH3wwpYjGzgVzJopQEAJAcyuJBG1hdHZjWkubNls4Mh+veVv Jqkt38xHGQHM
riwhtYSzcZ+9/80kso3TbOCUdWHLWpLGPOohgNnryaWqmWw0ez9aeeu12cCR t2Q730yianYE
AwHlBDC78gSVGt4Ms3em2vlmEumw+WYS+Qimwa+WLbUUiDsHAcyeg7qBMcPN 3ofUfDOJ/Lcp
99Wy7QtbsoFjoKyY4lQCmH0qKdp5EVjC7IMbOM2FLZtvJpHLJLivlvUKmMYQ qIkAZq8pm4rm
ksbsnQk3F7Z0Xy2b7MKWI9wPtG6+6cl1rG+ctFdIALMrTEoNIWUxex/c4IUt U34zScfO7V/H
H8tcIh5bQ0kxBx8CmN2HFm0nE1Bi9n68skuz7ptJZl/YknP2yXVBw0QEMHsi 0NaGUWv2dRs4
ciLvrovQfDOJXNgy/Ktlc+2ohIxrrVarnC9mrzKt+SdVitlHNnDkwpbuq2Xb F7bM+NWy+ZNK
BOUQwOzl5KqoSMs1++AGTnNhS/le2ebClrKrM2UDR06fc6Uu49C5psy4jkDM mqtpMVMfgQQq
LobmwpbNBo58uN5dF2Hwm0ky6jXj0IH1w+GBBDB7IEAOHyZQsdn7E5b/EOuu i+C+mcRdF6H5
ZpKMes04NAsjLwHMnpd/taObMnsni+66CM0GjuhVRJ8l05g9C3YNg2J2DVmo MAbLZu+kM6Ne
Mw5dYU0XNSXMXlS6ygkWsze5yqjXjEOXU6p1RorZ68xr9llhdsyevQgtB4DZ LWd/wbljdsy+
YHnR9SYCmH0TIV6fRQCzY/ZZhcNBcQhg9jgc6aVDALNjdhZFRgKYPSP8mofG 7Ji95vpWPzfM
rj5FZQaI2TF7mZVbSdSYvZJEapsGZsfs2mrSVDyY3VS6000Ws2P2dNXGSD0C mJ2iWIQAZl8E
K51CYBoBzD6NE608CWB2ByzXN2DkGtezTGi+FAHMvhRZ4/1idsxufAnknT5m z8u/2tExO2av
trhLmBhmLyFLBcaI2TF7gWVbT8iYvZ5cqpoJZleVDoKxRgCzW8t4ovli9gZ0 xkvpZhw6UZ0x
zBoCmJ3SWIQAZsfsixQWnU4jgNmncaKVJwHMjtk9S4bmMQlg9pg06ashgNkx O8shIwHMnhF+
zUNjdsxec32rnxtmV5+iMgPE7Ji9zMqtJGrMXkkitU0Ds2N2bTVpKh7Mbird 6SaL2TF7umpj
pB4BzE5RLEIAs2P2RQqLTqcRwOzTONHKkwBmx+yeJUPzmAQwe0ya9NUQwOyY neWQkQBmzwi/
5qExO2avub7Vzy2m2be2tmQ9c4OAEJBiUF/8iQLMePGWjEMngsswawjENDuQ IQCBPoGMes04
NJWQlwBmz8uf0SEAAQjEJ4DZ4zOlRwi0N9mbryT1xRLyXaYhx/rGSXuFBDC7 wqQQUj0EQgyb
69h66BueCWY3nHymvjyBjp3bv44/ltAiHrv8RBlBFwHMrisfRFMZgVzn3SHj VpYCm9PB7Dbz
zqwjEDg+euNzKREQ08VcAph9LjmOM09AxD7CALObL5CcADB7TvqMXTSBttn7 ux+Yvejklh48
Zi89g8SfjUDnnL3z6UbMni0xDCxvvwMBAhCYR4Bz9nncOCoBAcyeADJD1Emg MXv7bL05Veec
vc6sFzIrzF5IoghTH4GO2TsBYnZ9GTMUEWY3lGymGpdA2+z9njF7XNr05kUA s3vhojEEbhHo
7LNzzk5x6CGA2fXkgkgKI8Dn2QtLmKVwMbulbDPXqAQ2XgQm6mh0BgEPApjd AxZNIQABCBRB
ALMXkSaChAAEIOBBALN7wKIpBCAAgSIIYPYi0kSQEIAABDwIYHYPWDSFAAQg UAQBzF5EmggS
AhCAgAcBzO4Bi6YQgAAEiiCA2YtIE0FCAAIQ8CCA2T1g0RQCEIBAEQQwexFp IkgIQAACHgQw
uwcsmkKgaAJcfrLo9HkFj9m9cNG4ZgKPvHJ5yl0bgr6v1xkcs2vL3XLxYPbl 2NJzYQQefunS
7h+r8fvDL1/SNivMri0jGuLB7BqyQAwqCDx48sLO7urBk+f37i/u/2w/OHle Xn3o5Pl5sTr/
dr4Fu/9M+/qR4+3bQh957Dp0MTcxtKfQfrUf3rzJclR2Apg9ewoIQAuBI8+f +213deT5d69c
X/XvD8irN1dHXjg3L9y2YRvJ9g077uvO6fngd64Obrm0nT7Yybqe502Wo7IT wOzZU0AAWggc
fu7sL7+v5KdoXR7s3W/e+nn4xP6rJ84OhjtR3M2x67ZQMLuWaig8DsxeeAIJ Px6BQ8dO/7Cz
OnT8tJj9x52VPJa7PNi739h7Xn6969jp/oD9c+eNe9/r9kA2mr29XdNv3D/1 bm+wjOzGdLod
PPGPR5qeFieA2RdHzAClEDh49I1vbqwOPvn6waPd+537T34rrx59fcTsbptl ZD+kc84+ruaN
4p63mTNlN6aUlBHnOgKYndqAwJ8Ebn/itavbq6+2V1evr+TBrfv+r3vPb6/u ePy1ebw2+rR/
Qr3R7PP+MHSOGjmRnzdTjtJAALNryAIxqCBw22Ov/v2xV+XnbY/+de883v91 Xqzr3qJsb4O4
U/7Bvfh1uzf90/bOM/3dmOYfFh2ndyKZN02OUkIAsytJBGFAAAIQiEYAs0dD SUcQgAAElBDA
7EoSQRgQgAAEohHA7NFQ0hEEIAABJQQwu5JEEAYEIACBaAQwezSUdAQBCEBA CQHMriQRhAEB
CEAgGgHMHg0lHUEAAhBQQgCzK0kEYUAAAhCIRgCzR0NJRxCAAASUEMDsShJB GBCAAASiEcDs
0VDSEQQgAAElBDC7kkQQBgQgAIFoBDB7NJR0BAEIQEAJAcyuJBGEAQEIQCAa AcweDSUdQQAC
EFBCALMrSQRhQAACEIhGALNHQ0lHEIAABJQQwOxKEkEYEIAABKIRwOzRUNIR BCAAASUEMLuS
RBAGBCAAgWgEMHs0lHQEAQhAQAkBzK4kEYQBAQhAIBoBzB4NJR1BAAIQUEIA sytJBGFAAAIQ
iEYAs0dDSUcQgAAElBDA7EoSQRgQgAAEohHA7NFQ0hEEIAABJQQwu5JEEAYE IACBaAQwezSU
dAQBCEBACQHMriQRhAEBCEAgGgHMHg0lHUEAAhBQQgCzK0kEYUAAAhCIRgCz R0NJRxCAAASU
EMDsShJBGBCAAASiEfgf1ia4UlMYulEAAAAASUVORK5CYII=
--------------050904040805030807000900--
Re: Link Mapping to shortcuts [message #482859 is a reply to message #482618] Fri, 28 August 2009 06:49 Go to previous message
Hello Jan,
Well, you need to perform the same trick with child node - create fake node
on a diagram visualizing this child one and use it for child node...
Never tried this but it looks like it should work.
Alex Shatalin
Previous Topic:Handling changes outside of editor
Next Topic:postLoad function for gmf
Current Time: Sun Jul 20 04:40:24 EDT 2025
Powered by FUDForum. Page generated in 0.05292 seconds
