DecorationNode repositioning [message #482338] |
Wed, 26 August 2009 05:49  |
Originally posted by: carl.wannheden.paranor.ch
I am implementing a custom provider for the Layout Service using
Graphviz to provide the algorithm. I have no problem repositioning nodes
and edges using SetBoundsCommand and SetConnectionBendpointsCommand,
respectively.
The problem I have is that I am unable to position the edge's label, the
DecorationNode, using absolute coordinates. Using a SetBoundsCommand to
reposition the DecorationNode does not seem to produce a deterministic
result.
The question:
How do I create a command in my Layout Service implementation which
allows absolute positioning of a DecorationNode?
Thanks in advance,
Carl
Show referenced Node name on label [message #482428 is a reply to message #482338] |
Wed, 26 August 2009 10:07  |
Thank you for your reading.
I have an ecore model.
<eSubpackages name="Some" nsURI="http:///Some.ecore">
<eClassifiers xsi:type="ecore:EClass" name="Sort">
<eStructuralFeatures xsi:type="ecore:EReference" name="scalarAttribute" upperBound="-1"
eType="#//Some/ScalarAttribute" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ScalarAttribute">
<eStructuralFeatures xsi:type="ecore:EReference" name="valueSort" lowerBound="1"
eType="#//Some/ScalarSort"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ScalarSort">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="type" defaultValueLiteral="String"/>
</eClassifiers>
</eSubpackages>
I want to generate an editor which looks like this, for example, there are two nodes on the canvas: (ScalarSortB, SortA)
| ScalarSortB |
| SortA |
|attribute : ScalarSortB |
To make this goal, I change the view pattern, editorPattern and editPattern on corresponding .gmfmap file by adding {0} : {1}. However, the scalarSort is not a feature of Sort, and it is impossible to change the model. Then I modify the generated code in SomeParserProvider.java (Replacing EAttribute by EStructuralFeature and add a new line "ModelPackage.eINSTANCE.getScalarAttribute_ValueSort()"). However, the text shown on label is:
"attribute : Some.ScalarSortImpl@2ce32ce3 (name: ScalarSortB, description: null, id: _1gaV8JJIEd6WEZ4cXo6aGQ) (type: String)"
But what I want is "attribute : ScalarSortB", how can I make it? :-(
protected IParser createScalarAttribute_3001Parser() {
EStructuralFeature[] features = new EStructuralFeature[] {
ModelPackage.eINSTANCE.getNamedObject_Name(),
//I make change here
ModelPackage.eINSTANCE.getScalarAttribute_ValueSort()};
Editor.Sorts.parsers.MessageFormatParser parser = new Editor.Sorts.parsers.MessageFormatParser(
features);
parser.setViewPattern("{0} : {1}");
parser.setEditorPattern("{0} : {1}");
parser.setEditPattern("{0} : {1}");
return parser;
Any help is a great favor for me!
William
FUDForum. Page generated in 0.03208 seconds
