Home » Eclipse Projects » Babel » Babel Build
Babel Build [message #482035] Tue, 25 August 2009 04:07 Go to next message
Hello all together,
I have a small question, when will babel build the next time (no nightly
build)?
In advance thank you for the response times.
Sincerely
Re: Babel Build [message #485736 is a reply to message #482035] Mon, 14 September 2009 13:22 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
On 08/25/2009 04:07 AM, Michael Schneider wrote:
> Hello all together,
> build)?
> Sincerely
We will rebuild the Galileo language packs when Galileo SR1 is released
(which will be soon) and the Helios stream of Nightly Builds is
currently planned via bug http://bugs.eclipse.org/289376 .
Denis
Re: Babel Build [message #485762 is a reply to message #485736] Mon, 14 September 2009 16:56 Go to previous messageGo to next message
Is SR1 also going to address this bug (which affects Babel significantly,
but its source lies elsewhere according to follow-up links I put there, the
issue was "closed" by WTP, but the problem is still out there for all of
Eclipse, especially Babel ;-/)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=288030
Werner
Fw: Re: Babel Build [message #485790 is a reply to message #485762] Mon, 14 September 2009 22:25 Go to previous messageGo to next message
I reopened 288030 but phrased the WTP relation out.
Since it happens in other places, too. And every Galieo distro that is
applied the "basic" Babel translations (tried that with German, I don't
suppose it is language-dependant though)
Werner
Re: Babel Build [message #488479 is a reply to message #485736] Mon, 28 September 2009 16:31 Go to previous messageGo to next message
Hi Denis,
any updates here?
TIA,
Marco
>> Hello all together,
>> build)?
>> Sincerely
> Denis
Re: Babel Build [message #489222 is a reply to message #488479] Thu, 01 October 2009 18:19 Go to previous messageGo to next message
I saw Galileo went 3.5.1, but as the mentioned bug has not been closed, I
assume it is still in there, too?;-)
(unless it was fixed elsewhere without notifying Babel or checking
Bugzilla...?)
Werner
Re: Babel Build [message #489611 is a reply to message #489222] Mon, 05 October 2009 06:36 Go to previous messageGo to next message
we stumbled across this bug, too. Right now, I fixed the language pack
manually and rebuilt it here. Do you have a date for the 3.5.1 language
packs already?
I wouldn't roll out a new target if the next lang packs are a week away.
Thanks and regards,
Stefan
> I assume it is still in there, too?;-)
> Bugzilla...?)
> Werner
Re: Babel Build [message #489667 is a reply to message #489611] Mon, 05 October 2009 10:10 Go to previous messageGo to next message
Stefan, Galileo (Eclipse 3.5.0) language packs should work for Galileo SR1 (Eclipse 3.5.1) also. The rebuild of language packs for Galileo SR1 is just to pick up newer translations since Galileo.
What and how did you fix the language packs manually? Can you share that with us? Maybe you can contribute to the Babel project?
Re: Babel Build [message #489684 is a reply to message #489667] Mon, 05 October 2009 10:46 Go to previous messageGo to next message
Hello
We currently use the Babel packs with build id '3.5.0.v20090620043401'.
There is a bug, where the format-type string was translated into German,
which causes an Exception when opening the problems view. This bug is
known: https://bugs.eclipse.org/bugs/show_bug.cgi?id=288030 and
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282139
The valid translation is available, too. There was suspicion that this
problem might occur in other places as well, and therefore the bug
wasn't solved.
Right now this causes us some trouble, thats why I edited the
message-file in the JAR of the lang-pack and repaired the corrupted string.
If you plan to build within a week or so, I will not roll out my
manually fixed JAR. If you do not plan to release a build for a while, I
will use my fixed JAR and hope the bug won't reappear in other places.
Stefan
Re: Babel Build [message #492110 is a reply to message #489684] Sun, 18 October 2009 15:30 Go to previous messageGo to next message
I know one of them, as I filed or at least re-assigned it to Babel (after
WTP correctly assumed, it had no direct relation to their project)
How would a particular translation get broken or corrupted? It is basically
just strings in the first place. And while encoding or special characters
matter in some RCP apps, that should not be a problem here either. As it is
common to all translations.
Or are the scripts for "Genie" or similar tasks different for some languages
from others?
I'd be happy to understand this or even see Galileo SP1 have fewer of these
issues before I speak at ESE in about 10 days.
The challenges are certainly an interesting topic if the short session even
allows such details?
On a slightly different Babel "front" which is Multimedia Localization I am
making good progress with STEM. They got a Spanish translation and I'm
currently working on the German one with a partner who's a professional
speaker and voice over.
Werner
Re: Babel Build [message #496187 is a reply to message #485736] Mon, 09 November 2009 05:23 Go to previous messageGo to next message
Is there anything new ?
We have already November.
Thank you
Re: Babel Build [message #504004 is a reply to message #496187] Wed, 16 December 2009 14:14 Go to previous messageGo to next message
Babel Language Packs 0.7.1 are now available at: http://www.eclipse.org/babel/downloads.php for a few weeks. Forgot to cross post here at the forum Smile
Re: Babel Build [message #579671 is a reply to message #482035] Mon, 14 September 2009 13:22 Go to previous messageGo to next message
> Hello all together,
> build)?
> Sincerely
Denis
Re: Babel Build [message #579713 is a reply to message #485736] Mon, 14 September 2009 16:56 Go to previous messageGo to next message
Werner
Fw: Re: Babel Build [message #579732 is a reply to message #485762] Mon, 14 September 2009 22:25 Go to previous messageGo to next message
Werner
Re: Babel Build [message #579802 is a reply to message #485736] Mon, 28 September 2009 16:31 Go to previous messageGo to next message
Hi Denis,
any updates here?
TIA,
Marco
>> Hello all together,
>> build)?
>> Sincerely
> Denis
Re: Babel Build [message #579812 is a reply to message #488479] Thu, 01 October 2009 18:19 Go to previous messageGo to next message
Bugzilla...?)
Werner
Re: Babel Build [message #579824 is a reply to message #489222] Mon, 05 October 2009 06:36 Go to previous messageGo to next message
packs already?
Thanks and regards,
Stefan
> Bugzilla...?)
> Werner
Re: Babel Build [message #579836 is a reply to message #489611] Mon, 05 October 2009 10:10 Go to previous messageGo to next message
Re: Babel Build [message #579852 is a reply to message #579836] Mon, 05 October 2009 10:46 Go to previous messageGo to next message
Hello
wasn't solved.
Stefan
Re: Babel Build [message #579890 is a reply to message #489684] Sun, 18 October 2009 15:30 Go to previous messageGo to next message
from others?
Werner
Re: Babel Build [message #580085 is a reply to message #485736] Mon, 09 November 2009 05:23 Go to previous messageGo to next message
Thank you
Re: Babel Build [message #580120 is a reply to message #496187] Wed, 16 December 2009 14:14 Go to previous message
Babel Language Packs 0.7.1 are now available at: http://www.eclipse.org/babel/downloads.php for a few weeks. Forgot to cross post here at the forum :)
Previous Topic:Language pack/Feature for RCP runtime
Next Topic:Babel Next Gen ?
Current Time: Sun Jul 20 06:12:16 EDT 2025
Powered by FUDForum. Page generated in 0.07101 seconds
