Home » Eclipse Projects » Rich Client Platform (RCP) » Blocking command execution (wainting for results)
Blocking command execution (wainting for results) [message #481728] Mon, 24 August 2009 02:37 Go to next message
Originally posted by: eclipsercp.nurfuerspam.de
I am wondering how it is possible to execute a command in a way that the
application waits for the command to complete.
At the moment I execute the command like this:
IHandlerService service = (IHandlerService) Workbench.getInstance()
getService(IHandlerService.class);
result = service.executeCommand(commandName, event);
// do something with the result
This makes the command to be executed in another thread some time later.
What I want is to execute the command immediately and wait for it to
complete. Then I want to continue working with the commands result.
Is this possible?
Krid
Re: Blocking command execution (wainting for results) [message #481733 is a reply to message #481728] Mon, 24 August 2009 03:06 Go to previous messageGo to next message
Hello Krid,
See the "Jobs" API, in particular workspace job.
Jobs run asychronously from the UI thread.
You will need a "JobAdapter" to process your results
(possibly using an AsynchExec to update UI elements).
Charlie
Krid wrote:
> Is this possible?
> Krid
Re: Blocking command execution (wainting for results) [message #481756 is a reply to message #481733] Mon, 24 August 2009 04:22 Go to previous messageGo to next message
Hi and thanks for your reply,
my problem is not to execute a job asynchronously but to execute a Eclipse
command synchronously!
Krid
Charlie Kelly wrote:
> Hello Krid,
> Charlie
Re: Blocking command execution (wainting for results) [message #481769 is a reply to message #481756] Mon, 24 August 2009 05:13 Go to previous message
I think you've some miss on tracing your code flow.
Why do you think command will be executed on separated thread?
Command is not executed on separated thread except you invoke that in
separated thread. At almost, They are executed on main UI thread,
because handlers have high chance to fire event that needs to updating UI.
If you just give complicate and slow codes in handler then You can see
UI which is not respond while.
So, just describe your command execution and handling result in same
code block in sequence. that's no problem. Whatever job or not.
> Eclipse command synchronously!
> Krid
>> Hello Krid,
>> Charlie
Previous Topic:PropertTester
Next Topic:Coolbar layout
Current Time: Sat Jul 19 14:50:15 EDT 2025
Powered by FUDForum. Page generated in 0.04329 seconds
