Building mylyn from source on command-line [message #481187] |
Thu, 20 August 2009 00:07 |
Originally posted by: china.thewrittenword.com
Are there instructions anywhere on how to build mylyn from source on the
command-line? I've fetched eclipse-mylyn-3.1.0-3.fc11.src.rpm from the
Fedora 11 repository and tried parsing the eclipse-mylyn.spec file but
am running into problems. I'm basically using a command-line like the
following:
JAVA_HOME=/opt/java1.6 ANT_HOME=/opt/ant171 \
PATH=${JAVA_HOME}/bin:${ANT_HOME}/bin:$PATH \
/opt/java1.6/bin/java \
-cp /opt/eclipse342/lib64/eclipse/startup.jar \
org.eclipse.core.launcher.Main \
-application \ org.eclipse.ant.core.antRunner \
-Dtype=feature \
-Did=org.eclipse.mylyn.tasks \
-DbaseLocation=/opt/eclipse342/lib64/eclipse \
-DsourceDirectory=/opt/build/mylyn-3.1.0/org.eclipse.mylyn \
-DbuildDirectory="/opt/build/mylyn-3.1.0/org.eclipse.mylyn/build " \
-Dbuilder=/opt/eclipse342/lib64/eclipse/plugins/org.eclipse. pde.build_3.4.1.R34x_v20081217/templates/package-build \
-DorbitDepsDir="/opt/build/mylyn-3.1.0/org.eclipse.mylyn/orbitDeps " \
-Dtesting=false \
-DjavacSource=1.5 \
-DjavacTarget=1.5 \
-DforceContextQualifier=v20090315-1500-e3x \
-DmylynQualifier=v20090315-1500-e3x \
-f /opt/eclipse342/lib64/eclipse/plugins/org.eclipse.pde.build_ 3.4.1.R34x_v20081217/scripts/build.xml \
-vmargs \
-Duser.home=/opt/build/mylyn-3.1.0/home \
-DJ2SE-1.5=/opt/java1.6/jre/lib/rt.jar
And the result is:
preGenerate:
[exec] preparing files in /opt/build/mylyn-3.1.0/org.eclipse.mylyn for buildfile generation ...
[exec] making the 'features' and 'plugins' directories
[exec] making symlink: /opt/build/mylyn-3.1.0/org.eclipse.mylyn/build/features/org. eclipse.mylyn.pde_feature -> /opt/build/mylyn-3.1.0/org.eclipse.mylyn/org.eclipse.mylyn.p de-feature
[exec] making symlink: /opt/build/mylyn-3.1.0/org.eclipse.mylyn/build/features/org. eclipse.mylyn.team_feature -> /opt/build/mylyn-3.1.0/org.eclipse.mylyn/org.eclipse.mylyn.t eam-feature
[exec] making symlink: /opt/build/mylyn-3.1.0/org.eclipse.mylyn/build/features/org. eclipse.mylyn.wikitext_feature -> /opt/build/mylyn-3.1.0/org.eclipse.mylyn/org.eclipse.mylyn.w ikitext-feature
generateScript:
[eclipse.buildScript] Some inter-plug-in dependencies have not been satisfied.
[eclipse.buildScript] Bundle org.eclipse.mylyn.bugzilla.core:
[eclipse.buildScript] Missing required plug-in org.eclipse.mylyn.tasks.core_[3.0.0,4.0.0).
[eclipse.buildScript] Missing required plug-in org.eclipse.mylyn.commons.net_[3.0.0,4.0.0).
[eclipse.buildScript] Bundle org.eclipse.mylyn.bugzilla.ide:
[eclipse.buildScript] Bundle org.eclipse.mylyn.bugzilla.ui:
[eclipse.buildScript] Missing required plug-in org.eclipse.mylyn.bugzilla.core_[3.0.0,4.0.0).
[eclipse.buildScript] Missing required plug-in org.eclipse.mylyn.tasks.ui_[3.0.0,4.0.0).
[eclipse.buildScript] Bundle org.eclipse.mylyn.commons.net:
[eclipse.buildScript] Missing required plug-in org.apache.commons.codec_1.3.0.
[eclipse.buildScript] Missing required plug-in org.apache.commons.httpclient_3.1.0.
[eclipse.buildScript] Missing required plug-in org.apache.commons.lang_2.3.0.
Any ideas on how to fix these problems? I'm performing the build with
Sun's JDK 1.6u16 on a RHEL4/5 system. I'm not using the RHEL-provided
Java on purpose.
albert chin (china @at@ thewrittenword .dot. com)
FUDForum. Page generated in 0.05436 seconds
