Home » Archived » MOFScript » Executing Problem with Java API
Executing Problem with Java API [message #480673] Tue, 18 August 2009 04:09 Go to next message
I'm defining some textual tranformations for models based on the
Jadex metamodel. It works fine! However, when I try to
integrate my MOFScript transformation in a Java environment, using the
example given in the MOFScript User Guide, it doesn't work.
I took these errors;
Parsing result: 213 errors
: Error: MTTParseError: Illegal/unknown context: jadex, line: 649, column: 0
: Error: MTTParseError: Can't find feature 'name' for type 'Agent'., line: 9, column: 12
: Error: MTTParseError: Can't find feature 'name' for type 'Agent'., line: 15, column: 30
: Error: MTTParseError: Can't find feature 'package' for type 'Agent'., line: 17, column: 33
: Error: MTTParseError: Can't find feature 'description' for type 'Agent'., line: 19, column: 37
: Error: MTTParseError: Can't find feature 'propertyfile' for type 'Agent'., line: 21, column: 37
I think there is a problem with metamodel setting.
Can you help me, your code doesn't work in the guide.
Bekir
Re: Executing Problem with Java API [message #480981 is a reply to message #480673] Wed, 19 August 2009 05:10 Go to previous messageGo to next message
Hello Bekir,
I am not sure this will solve the problem, but you could try adding a line
in the beginning of your code like:
JadexModelFactory _jadexModelFactory = JadexModelFactory.eINSTANCE;
If "Jadex"ModelFactory is the correct name in your case I dont know. Just
add the factory for your model.
G
Re: Executing Problem with Java API [message #481053 is a reply to message #480981] Wed, 19 August 2009 08:55 Go to previous messageGo to next message
I tried your advice but it doesn't work Sad
I think i had a same problem with this: http://www.eclipse.org/forums/index.php?t=msg&th=125320& amp;start=0&S=1d70109ac3dbe09f01b59730a4b62ddc
I tried the solution at the above link but i could not solve my problem. I took same parser errors.
Can you explain the solution at that link? where am i wrong?
Thanks for your attention,
Bekir
Re: Executing Problem with Java API [message #568234 is a reply to message #480981] Wed, 19 August 2009 08:55 Go to previous message
I tried your advice but it doesn't work :(
Bekir
Previous Topic:Executing Problem with Java API
Next Topic:[MOFScript] MOFScript and Eclipse Galileo
Current Time: Sun Jul 20 15:44:59 EDT 2025
Powered by FUDForum. Page generated in 0.04208 seconds
